Results 1 to 5 of 5
Thread: scam & focussat
    04 Mar 2011
    Default scam & focussat
    Hi,
    poate sa ma ajute si pe mine cineva cu o configurare de scam 3.60 ptr. un card focussat pe slot intern la un azbox elite cu E2?; eventual cineva care are cardul config in scam?
    Mersi!
    dMd
    Guest
    SCAM
    ### scam host
    #/net/ecm_server/foobar/port=4321
    #/net/ecm_server/foobar/pass=passwort
    ### scam client
    #/net/ecm_client/foobar/host=192.168.0.xxx
    #/net/ecm_client/foobar/port=4321
    #/net/ecm_client/foobar/pass=passwort
    ### newcamd connect
    #/net/newcamd/foo/host=192.168.0.xxx
    #/net/newcamd/foo/port=1234
    #/net/newcamd/foo/user=username
    #/net/newcamd/foo/pass=password
    #/net/newcamd/foo/key=1234567890123456789012345678
    ### serial port smartcard readers (3.51a)
    # device node
    #/sc/serial/<name>/device=<string>
    #<>e.g.: /dev/ttyUSB0
    # type
    #/sc/serial/<name>/type=<string>><><><><>[default: phoenix]
    #<>valid types: mastercrd2, phoenix, smartreader+
    # clock frequency in Hz
    #/sc/serial/<name>/fs=<num><><><><><>[default: 3571200]
    # example
    #/sc/serial/usb0/device=/dev/ttyUSB0
    #/sc/serial/usb0/type=smartreader+
    ### cccam share (3.52)
    #/net/cccam/home/user=username
    #/net/cccam/home/pass=password
    #/net/cccam/home/host=192.168.0.xxx
    #/net/cccam/home/serv=12000
    Daca nu s-a gasit o rezolvare - in folderul scam exista fisierul asta de configurare (a se vedea arhiva scam), .. personal consider mai "comod" oscam pt cardul de focus si nu am folosit scam asa de des, cu atat mai putin pt sh@r3.
    23 Apr 2007
    P3X-888
    Am curatat topicul de postarile "la numar"
    ms dMd, dar cum face fcs AU lunar, nu vad cum trebuie setat ECM pt AU?
    te rog mai multe detalii dupa experiment!
    dMd
    Guest
    Consider necesar sa precizez ca nu am Azbox, dar prin analogie cu alte receptoare... pt AU pur si simplu nu setezi nimic, il instalezi si atat. Eu am postat mai sus posibilitatile de configurare la scam pt a-l folosi pe post de server-emu ( a fost sters postul unde se cereau lamuriri in sensul asta). Cat de bine merge scam in retea...nu stiu, de aia am dat ca alternativa oscam, pentru ca face update la card garantat si pe deasupra il poti folosi ca server fara probleme daca este configurat corespunzator.
