3
Dislikes:
Optibox Gekko HD - Enigma 2!
Optibox Gekko HD
Main features
- Supports MPEG4 /MPEG2 - HD/SD and Fully DVB-S2 /DVB-S Compliant
- Intelligent Blind Scan for both SD and HD TV & Multi-Satellite Search
- Multi-LNB Controlled by DiSEqC Control Version 1.0, 1.1, 1.2 and USALS
- HDTV PVR Receiver ( H.264/ MPEG4 HD )
- Embedded Linux OS
- Time Shifting, Recording & Playback with External HDD (USB 2.0)
- Simultaneously Records of Services and allows Watching 2 others (PIP)
- Powerful Extended EPG supports and Event Recording
- One USB 2.0 Host ports (MP3 Player & JPEG Viewer)
- Xvid file play back supported
- Ethernet port Supported
- On-Screen Display with Full Color & Resolution
- Favorite Groups
- Powerful Service List Manager for Favorites, Lock, Skip, Move, Edit and Delete
- Service Sorting by Alphabet, Transponder and CAS
- User Friendly & Multi-language Supported (OSD & Menu)
- Teletext / Subtitle Supported
- Maximum 10,000 Services(TV & Radio) Programmable
- Picture-in-Picture (PIP) & Multi-picture Display
- Parental Lock / System Lock / Installation Lock
- HDMI Video & Audio Output (576i, 576p, 720p, 1080i, 1080p)
- CVBS(composite) Video & Audio Output via RCA
- Optical Output for Digital Audio(SPDIF)
- Software & Service channel Database upgrade via USB & RS-232C port
- 1 Smart card reader and 1 Common Interface Slots
Technical Specifications
Tuner & Channel Decoder
Input Connector: F-type, IEC 169-24, Female
Loop through out: F-type, IEC 169-24, Female
Frequency Range: 950MHz ~ 2150MHz
Input Impedance: 75Ohm, unbalanced
Signal Level: -65 to -25dBm
LNB Power: 13/18VDC, max.400mA
22KHz Tone: (22±2)KHz, (0.6±0.2)V
DiSEqC Control: V1.0/1.2/USALS Compatible
Demodulation: QPSK / 8PSK
Input Symbol Rate: 2 ~ 45 Ms/s(QPSK of DVB-S)
2 ~ 45 Ms/s(QPSK of DVB-S2)
2 ~ 35 Ms/s(8PSK of DVB-S2)
FEC Decoder: 1/2, 2/3, 3/4, 5/6 and 7/8 with
Constraint Length K=7(DVB-S)
1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9 and 9/10 (DVB-S2/QPSK)
3/5, 2/3, 3/4, 5/6, 8/9, 9/10(DVB-S2/8PSK)
MPEG Transport Stream A/V Decoding
Transport Stream: H.264(MPEG-4 part 10, MPEG-4/AVC and H26L)
MPEG-II ISO/IEC 13818-2/11172-2
Profile Level: MPEG-4/AVC MP@L4, MPEG-II MP@HL
Input Rate: Max. 80Mbit/s
Video Formats: 4:3 Letter Box, 4:3 PanScan, 16 : 9
Video Resolution: 720 x 576i, 720 x 576p, 720 x 480i, 720 x 480p
1280 x 720p, 1920 x 1080i, 1920 x 1080p(supports only HDMI)
Audio Decoding: Dolby Digital, MPEG-1 Layer 1,2 and 3
Audio Mode: Stereo/Joint stereo/Mono, Dolby Digital bitstream
Sampling Rate: 32KHz, 44.1KHz and 48KHz(According to input)
Main System
Main Processor: STi chipset
Flash-ROM : 32 Mbyte
SDRAM : 256 Mbytes
EEPROM : 256 bytes
Audio / Video & Data IN/OUT
RCA: Video & Audio Output (Jack Type)
OPTIC: Dolby Digital (SPDIF)
RS-232C: 9 pin D-SUB (Male) type, Transfer rate 115Kbps
USB: USB 2.0 Host Front & Rear Support. (5V DC 500 mA Max.)
Ethernet: RJ45 connector, 100 Mbps
1 Common interface PCMCIA slot
1 Smart Card Slot
Front Panel
Buttons: 3 Buttons (Standby, CH UP/DOWN)
Power Supply
Input Voltage: AC 100 ~ 250V, 50/60Hz
Power Consumption: Max. 30W
Physical Specification
Size (W x H x D): 220mm X 43mm X 180mm
Weight (Net): 1.1 Kg
Operating Temp.: 0°C ~ +45°C
Storage Temp.: -10°C ~ +70°C
Image is designed for installation in USB device - Enigma 2 !
Support receiver:
OPTIBOX GEKKO and other HS7110, Fortis Modellreihe HS-7110 "Light" (STi7110) Kernel stm24-207
Added by sh4 Duckbox Team:
- [eplayer3] playback aac-he streams with aac-lc
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- new BusyBox 1.19.2 (stable) config and patches
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [player191] adoptions from p179; bugfix for 710x receiver (HD channel problems)
- [player2_191] fsynth bugfix
- fix ufs910 audio on scart
- use utf8 as python default
- adapt wrong page_offset and improve mem
Added by PKT:
- new function "live ecm" in infobar
- show Channel Number on Front Pannel + ON/OFF in setup menu
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update EmuManager v1.0.6: add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- add support for fake cccam
+ change only in HAARP V3c version
- picons update
- added BPanel activation in MoviePlayer ( key blue )
- added compatibility to standard non PKTeams skins
- fix dot on VFD if channel number is not available
- fix for radio mode wallpaper
- fix showing picons on channels list, when are located in /hdd/picon folder
- added /media/usb/picon to picons search folders
- 2nd generation of speed up channels zap
- add standby smooth extingushing TV
- channel list update 16-12-11
- display quality improvement
- new BluePanel 2D v3.1.21 with graphic interface:
-- added function to check update is needed
-- added color & numeric keys actions support to immidiate plugin/function/menu activation
-- 1st row - keys: 1, 2, 3, 4
-- 2nd row - keys: 5, 6, 7, 8
-- 3rd row - keys: red, green, yellow, blue
-- added menu key action support
-- added changelog information menu
-- added synchronization of local time and date from NTP server
-- added on/Off the smooth extinguish TV while switching to standby mode
- fix missing reference.dat
- fix international fonts switch in Skin Setup
- screenshot OSD fix
- fix GS on GlassHD skin
- upgrade e2 to 2011-09-13-experimental
- add % loaded e2 process on VFD
- fix exception on hddtemp running on box with no sata port
- fix GS in TimeShift path Menu
- fix sata HDD sleep in standby
- add new Webinterface v1.6.8
- add WebMedia 4.0
- add new Multimedia items in BP
- fix firmware update checking
- [ALL] extinguishing fix
- [ALL] MediaPlayer GS fix - RuntimeError
- [ALL] fix crash system after Factory reset
FTP login: root
passwd: pkteam
All manual included in image pack
Download : Link 1 Link 2
- Rep Power
- 0
Nu pot sa deschid manualul. Nu cunosc formatul ird
- Rep Power
- 0
optibox
ala e doar soft nu si manual
- Rep Power
- 0
ok. mersi. si manualul de unde pot sa descrac?
@battila - manual pentru acest receiver gasiti aici pe pagina producatorului.
- Rep Power
- 0
OK.Atunci intrebarea altfel.... Un tutorial cu instalare enigma2 unde gasesc?
Member
Visitor
- Rep Power
- 0
Salut,
Si eu sunt interesat de cum se face up-date.
Urmeaza sa-mi vina maine pachetul si vreau deja sa-l conectez in reteaua RCS&RDS
- Rep Power
- 62
Optibox Gekko HD teste
Salut,
Vreau sa cumpar asa ceva si vreau sa intreb cunoscatorii care folosesc sau au folosit acest receptor.
Ce parere aveti despre acest receptor, merita cumparat?
Cum merge in retea?
Utilizand imaginea originala, se pot instala "utilitare"?
Cum se descurca cu blind scan-ul?
Care este diferenta intre Optibox Gekko HD si Optibox Gekko Plus?!
