Black Pole Vu+ Duo 0.1.3
What's new:
Added Swap Manager
Fixed bug that cause many plugins thumbnails not working (Mytube Imdb Apple Trailers ecc...)
Vtuner removed (now usb tuners are managed internally enigma2)
Fix device panel bug
Black Pole can not support images not installed in the flash.
Yellow button = Time Shift
Button Red = Start Record
Addons
Dedicated server for Black Pole addons Feeds
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Characteristics of Black Pole Panels
Blue Panel
Extra Settings
Devices Manager & Mountpoints
Network Browse & Mountpoints
Usb Format Wizard
Swap File settings
OSD Settings
OSD Position setup
OSD 3D setup
Internal Epg Settings
Record settings
Recording paths
Subtitle settings
Auto Language Settings
Http stream settings
Info Panel
Box Info
Memory info
Storage info
Software info
EPG Panel
Crossepg settings
Green Panel
Addons (added)
Online Feeds Extensions
Online Feeds all Packages
Online Black Pole image update
Manual install Bh Packages
Manual install Ipk Packages
Addons Uninstall Panel
Credits
Special Thanks to Pli team and expecially to pieterg Milo and hemertje for their support and for the big work they are making for all us.
Thanks to Skaman (Sif) andyblac (Vix) e plnick (Vti) for their friendly support and suggestions.
DISCLAIMER
THE BLACK POLE IMAGE IS BASED ON THE OPENPLI DISTRO AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK POLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK POLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE
THIS IS OPEN SOURCE SOFTWARE.
YOU CAN REDISTRIBUTE IT AND/OR MODIFY UNDER THE TERMS OF THE
GNU GENERAL PUBLIC LICENSE VERSION 2 AS PUBLISHED BY THE FREE
SOFTWARE FOUNDATION.
