Black Pole Vu+ Duo 0.1.2
This is the new version of Black Pole image.
WARNING: ALL USERS THAT HAVE ALREADY INSTALLED BLACK POLE IMAGE 0.DON'T NEED TO REFLASH THE BOX.
JUST UPDATE YOUR BLACK POLE IMAGE FROM GREEN PANEL (BLACK POLE IMAGE UPDATE).
The Black Pole project is fully Open Source and accessible to all
There are too many updates in this 0.1.2 version.
Please look at git log @https://github.com/organizations/BlackPole for a detailed list of all the changes.
The main news in this version are:
1) NEW Black Pole device panel:
You can mount all your hdd and usb mass storage in your preferred mountpoints.
There are many mountpoints available by default (hdd, usb, personal, music, photo, video..) and you can also add your own customized mount points simply adding the folder under the /media/ directory
2) New Black Pole Usb Format Wizard:
An easy and very helpful way to format all your Usb stick or hdd with Linux filesystem.
Black Pole can not support images not installed in the flash.
Yellow button = Time Shift
Button Red = Start Record
Addons
Dedicated server for Black Pole addons Feeds
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Characteristics of Black Pole Panels
Blue Panel
Extra Settings
Devices Manager & Mountpoints
Network Browse & Mountpoints
Usb Format Wizard
OSD Position setup
OSD 3D
Internal Epg Settings
Record settings
Recording paths
Subtitle settings
Auto Language Settings
Http stream settings
Info Panel
Box Info
Memory info
Storage info
Software info
EPG Panel
Crossepg settings
Green Panel
Addons (added)
Online Feeds Extensions
Online Feeds all Packages
Online Black Pole image update
Manual install Bh Packages
Manual install Ipk Packages
Addons Uninstall Panel
Credits
Special Thanks to Pli team and expecially to pieterg Milo and hemertje for their support and for the big work they are making for all us.
Thanks to Skaman (Sif) andyblac (Vix) e plnick (Vti) for their friendly support and suggestions.
DISCLAIMER
THE BLACK POLE IMAGE IS BASED ON THE OPENPLI DISTRO AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK POLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK POLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE
THIS IS OPEN SOURCE SOFTWARE.
YOU CAN REDISTRIBUTE IT AND/OR MODIFY UNDER THE TERMS OF THE
GNU GENERAL PUBLIC LICENSE VERSION 2 AS PUBLISHED BY THE FREE
SOFTWARE FOUNDATION.
