Results 1 to 11 of 11
Thread: Argolis Smargo Smartreader Triple Reader
    24 Jun 2009
    Hamburg
    Default Argolis Smargo Smartreader Triple Reader
    m-am interesat de un smargo si am dat peste acest reader care pare interesant , un card reader 3 in 1 , aveti mai multe informatii legate de acest produs, face ceia ce spune ?
    din poza pare ca se conecteaza pe usb fara alta alimentare externa
    toate cele bune
    Sucesorul lui Smargo 3in1 aproape aceleasi calitati ale sucesorului inbunatatiria a venit din partea procesorului ARM care a eliminat unele probleme de deconectare...
    24 Jun 2009
    Hamburg
    merge folosit impreuna cu vu+ duo, ma refer daca e compatibil ca drivere?
    @fery21poti sa dai m,ai multe detalii despre cum se configureaza /dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2
    mersi pt detalii
    smartreader 001:002
    smartreader 001:003
    smartreader 001:004
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    nu stie smartreader, probabil pe viitor, insa merge in mouse /smargo protocol
    ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
    T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
    D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
    P: Vendor=0403 ProdID=6011 Rev= 5.00
    S: Manufacturer=Argolis
    S: Product=Triple Reader+
    S: SerialNumber=00000007
    C:* #Ifs= 3 Cfg#= 1 Atr=a0 MxPwr=150mA
    I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
    E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
    E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
    E: Ad=85(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    E: Ad=06(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
    FTDI :: smargo/ mouse ???
    /dev/ttyUSB0-1-2
    CCcam.cfg:
    SERIAL READER : /dev/ttyUSB0 smartreader+
    SERIAL READER : /dev/ttyUSB1 smartreader+
    SERIAL READER : /dev/ttyUSB2 smartreader+
    Pai si cum spui ca nu suport smartreader ? ai testat tu pe ce ?
    24 Jun 2009
    Hamburg
    mi-am comandat readeru si a ajuns
    am folosit setarile date de @qwess si au mers ok din prima , multumesc
    am testat cu un card de focus de pe care se deskide ok.
    am incercat sa folosesc in oscam un care de tvr si hd+ si dupa ce sta putin in needinit trece in error. probabil nu am configurat ceva ok
    in fine o sai dau de cap , ca prea ma plictiseam cu vu duo
    26 Oct 2009
    Walachia / Paname
    incearca la cele 2 in cauza:
    [reader]
    ambele pe acelasi protocol sau unul in mouse si celalalt in smargo
    protocol = mouse
    #protocol = smargo
    device = /dev/ttyUSB0
    smargopatch = 1
    deprecated = 1
    cere totusi si un lsusb poate le vede totusi (id 0403:6011)
    05 Mar 2010
    Ma tenteaza si pe mine sa iau unu. Dispun de de un server ubuntu linux la care am conectat un USB Infinity Phoenix si un receptor VU+ Solo. Trebuie sa instalez drivere sau dupa ce il conectez, pun direct in oscam caile corecte? Ma refer la ambele situatii (ubuntu si vu+)
    Multumesc!
    Member Special Member
    08 Mar 2007
    pi acasi
    am o curiozitate, cit costa ?
    29 Nov 2008
    Cu capu' in nori
