Thanks Thanks:  10
Likes Likes:  5
Page 1 of 3 123 LastLast
Results 1 to 15 of 40
Thread: Amiko Alien 2
    01 Sep 2010
    Andromeda
    Default Amiko Alien 2
    Intre timp se coace in cuptoarele Fulan un nou receptor. Se doreste a deveni 'noua generatie' si incearca sa se aplice si in pret acest deziderat. Va avea un procesor STi 7162, SH40 la...540 MHZ. Plus 256 DDR 2 la 800 MHZ si 512 Mb de Flash! Doua tunere DVB-S2 si un tuner DVB-C/T. Ma surprinde placut ca nu are un slot de usb, ci doua!
    Spark preview Combo - Alien2
    The new handset is called the Fulani Spark Combo ... and comes to stand
    rival claims to the user bar at Fortis ... We're talking
    About Optibox Raptor! Spark is advertising as belonging receivers Combo
    with claims ... class "high end" ... that it is another quality ... evident
    with implications for novel about the price ... but .. give money and stay in the face
    Let's attention!
    And things to be clear in terms of technical
    - STi7162 processor at 540MHz a SH40!
    - The 256Mb DDR2 at 800MHz
    - And 512 Mb of Flash!
    - Two DVB-S2 Tunne
    - A tunner DVB-C / T
    More information about Amiko Alien 2
    Linux OS supported
    Fully DVB-S2/DVB-S, DVB-T, DVB-C Compliant
    MPEG-4/H.264, MP@ML, MP@HL, MP@L4.1, HP@L4.1, XVID, DivX
    Video solution 1080p, 1080i, 720p, 576p, 480p, 576i, 480i
    2xCard Reader with CONAX CAS7 embedded
    HDMI HD Video/Audio Output
    Audio Decoding: AC3, LPCM, LC-AAC, AAC, MP3, WMA, WAV
    S/PDIF interface (Optical & Coaxial) for Dolby bit stream out
    TV SCART / 2 stereo audio out and 1 CVBS
    DiSEqc 1.0, 1.1, 1.2 and USALS
    Smart LAN 10/100 Mbps Ethernet
    Software upgrade via LAN Port or USB 2.0 or OTA
    PVR function support, 2 x USB 2.0 high speed, recording and time shift
    1 channel recording and 1 channel playback
    Electronic Program Guide (EPG) for on screen channel information
    YouTube, SHOUTcastRadio and Picasa compatible
    Weather forecast and Rss Reader Functions
    Plug-in installation support the endless function
    Combination between S2/T, S2/C, C/T and S2/S2
    Support 300mm panel
    23 Apr 2007
    P3X-888
    Hardware este copt de mult timp ( cca un an ) ... problema arzatoare este softul si de aici lansarea intarziata , din partea mea pot sa aibe si 6 tunere daca merg pe aceleasi idei si nu asculta si dorintele posibililor cumparatori le doresc cale lunga .
    27 Sep 2007
    Cred ca cei care au trecut prin experienta lui 8900, din punct de vedere software, vor avea ceva rezerve vizavi de noul receptor. @stargate s-a zbatut(si a muncit) mult, fiind si un utilizator pretentios, dar a ramas dezamagit de evolutia software, motiv pentru care priveste cu neincredere spre noul receptor. Daca tot e sa facem pasul spre o noua achizitie, parca e mai tentant un receptor cu sustinere soft avansata. Dar poate ca noul receptor vine si cu un alt concept de dezvoltare software, caci pana la urma, producatorul este interesat sa-si comercializeze produsul, in conditiile unei piete concurentiale tot mai consistente. Asteptam "barza"...din China !
    23 Apr 2007
    P3X-888
    Nu sunt un utilizator pretentios , sunt mai incepator ca multi dintre voi , ce am cerut eu a fost un soft mai smecheros care sa aduca o parte din facilitatile enigma2 ( skinuri , plugins, lista canale , etc ) si asta o puteau face lasand portite pentru cei ce doreau sa sape moka la facilitati noi daca in dorinta de a pastra un pret mic nu isi pot permite echipe profesioniste care sa scoata facilitati noi software . Sunt sigur ca daca erau un pic mai smecheri si jucau la limita legalului puteau face din Alien un super receptor .
    Din pacate am fost perceput ca un inamic al Spark cu toate ca il folosesc cu placere altfel nu mai criticam ceva ce nu folosesc si in plus mi-am pierdut mult timp ( nu sunt de meserie si imi este greu sa pricep multe lucruri ) incercand sa adaptez o facilitate prezenta in alte imagini ... trecerea din RSP Enigma2 in Spark . Nu sunt multumit nici de E2 nici de Spark dar cred ca se poate mai mult , sunt putini care incearca sa aduca ceva in plus acestor imagini si asteptari mari de la aceste imagini .
    Astept sa apara monstrul , iar daca pretul va fi ok sigur vor fi useri cel vor cumpara ... din pacate mie mi-a ajuns cu Amiko .
    Intr-adevar va aveea 2 concurenti seriosi , atat in privinta pretului cat si a suportului software ( Giga Blue 800HD SE si Sunray.......)
    Amandoua receptoare concurente invartindu-se in jurul a 1000lei cu avantajele/dezavantajele specifice
    Poate nu ar fii rau ca cei care totusi au posibilitatea de a discuta/propune niste sugesti producatorului sa tina cont si de concurenta , fiindca altfel va fii un "receptor" mort din nastere ( poate e cam dura afirmatia , insa poate reflecta un adevar )
    Normal ca pt. userul de rand ( non-linux-isti ) cu cat oferta este mai variata in firme/modele din aceeasi categorie cu atat mai bine , insa timpul isi va pune amprenta pozitiva/negativa asupra fiecaruia in parte
    Insa dupa cum stim cu toti degeaba un receptor hd este ultra-performant daca nu vine/are si un suport software destul de vast/larg , va fii tras pe dreapta foarte repede daca nu va indeplini acest raport performanta/suport soft
    14 Nov 2010
    Singura mea teama este ca daca apara acest receptor, 8900 va fii pus mai mult laoparte de fabricant si de sustinatori de soft...
    Pacat de el, dar asta s-a auzit de foarte multa ori si pana acum.
    23 Apr 2007
    P3X-888
    Cu siguranta nu va fi trecut Alien pe un plan secund pentru ca vanzarile mari se fac la receptoarele ieftine ... trebuie sa-i dam o sansa si noului receptor pentru ca sigur va ridica standardul mult mai sus .
    09 Jun 2007
    Transylvania
    Standard RSP member Ovizel's Avatar
    14 Sep 2007
    Cluj Napoca
    Degeaba o sa apara acest Amiko 2.
    In opinia mea, cei cu exeprienta Alien 8900 clar nu o sa il cumpere.
    De ce degeaba?
    Cu ce ne incanta un tuner DVB-C/T in plus (respectiv pretul, care sigur o sa fie peste 700 lei) cand in aceste zile orice televizor Full HD are deja incorporat tuner DVB-T/C.
    Procesor mai puternic? Personal ma lasa rece diferenta de 90 Mhz. Flash mai mare - binevenit, memorie Ram acceptabila.
    Ramane de vazut softul.
    Daca ramane aceasi relatie ca la Amiko Alien 8900, relatia client-fabricant, posibil sa se vanda doar cand o sa fie la pret redus.
    Pacat ca la Alien nu au venit de la inceput cu varianta de telecomanda noua care este foarte confortabila si raspunde muuuult mai bine la comenzi (are 2 leduri de infrarosu).
    Varianta castigatoare multimedia ar fi un Alien 8900 pentru satelit si un media player (pana in 400 lei) pentru o adevarata experienta de filme HD rulate impecabil mai ales de cele cu chipset-ul 1186DD de la Realteck.
    Succes pe piata insa personal o sa zic pas.
    04 Apr 2009
    tv-urile desi au tuner DVB-C nu au aceeasi calitate ca si cele incorporate in recievere, spun din proprie experienta. mai ramane si posibilitate decodarii programelor codate de pe DVB-C. deci nu e chiar asa degeaba.
    23 Apr 2007
    P3X-888
    Chestie de gust ... eu nu am observat diferente .
    Vu ultimo are thuner LG tv samsug are tuner LG acelasi model (cel putin in cazul meu) chiar nu este difereta...doar...la cam...
    04 Apr 2009
    chestie de semnal. pe tv imi face intreruperi pe programele HD (nu freezuri de decodare ca-s FTA), iar pe reciever nu. la cei care aparatura din conserva Rdeesh de pe scara are bube, conteaza. chiar trecand se peste asta nu se poate spune ca tunerul dvb-c este inutil pe amiko.
    26 Aug 2010
    Default Stie Alien 2 de PIP?
    mai exact intrebarea este procesrul lui Amiko Alien 2 capabil de PIP, banuiesc ca nici spark sau enigma nu au picture in picture implementat (sau are?) dar din ce motiv, de hardware sau de software? Cine stie mai multe despre PIP pe Alien2 ? multumesc
    08 Jan 2011
    SPACE
    Default Amiko Alien 2 triple tuner
    Ce plugin punem pe Amiko Alien 2 triple tuner?
    Cel de Alien 1 este compatibil pe acest STB?
