Dislikes:
- Rep Power
- 62
Black Hole Vu+ Duo 1.7.0 Multiboot Full Version
This is the same image 1.7.0 with Web Browser for all the ppl that use it.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
http://www.vuplus-community.net/boar..._usb-zip.6110/
