There are 2 big news items in this Black Hole release.
- Meoboot Version 1.0
- Full Backup utility
1) Meoboot version 1.0 is a NEW VERSION entirely recoded for kernel 3.1.1 images.
This version of Meoboot is 50% faster than the old version and only compatible with images that share the new kernel 3.1.1.
As you know the new kernel 3.1.1 based images have a new filesystem (Ubifs).
Meoboot can extract a Ubifs filesystem and install a full image in about 4 minutes on Vu+ boxes and is much faster than old versions at startup.
WARNING: THERE IS AN IMPORTANT CHANGE IN MEOBOOT 1.0: This version of Meoboot accepts images in USB.zip format and NOT in NFI format. This is because images in USB format are easier to find and much more readily available.
WARNING2: This version of Meoboot accepts only 3.1.1 kernel based images.
2) New Full Backup Utility.
This new Black Hole utility will complete the Black Hole tools. You can find it in the main menu. The Black Hole Full Backup will allow you to backup all your images in the original USB.zip format. This means that after you make a backup you can restore it in it's entirety, you flash your set top box with your own backup.
This new feature is based on the original script of Pedro_Newbie.
What is New ?
New Skin Army MooD HD
Default Lcd skin with picons support by Matrix10
Drivers: 04.jan.2012
Dvbapp updated to o7.jan.2012
Genuine Vuplus plugin
Vuplus plugins updated
Meoboot 1.0
Bh Full Backup
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to ambrosa (Pli Board) for ready-to-go A867 driver patch
DISCLAIMER
LICENSE (TERM OF USE)
http://www.multiupload.com/98K97GYT93
