ChangeLog
-add seca tunneled nagra card support (may need card reset to see new revision after updating)
-add SID LIMIT (see CCcam.cfg for details)
-several smartcard fixes
-several network fixes
DOWNLOAD
ChangeLog
DOWNLOAD
cum lucreaza cu oscam?
din ce scrie aici se pare ca da
# connections #
# syntax for to add a client connection to other CCcam
# add yes on end to use friends emus (non public private key/emu,etc...),
# but only works when corresponding F line on server has '1' for <shareemus>
# optional limits just like F line, but for incoming shares (ignore shares more than 'uphops' away)
#C: <hostname> <port> <username> <password> <wantemus> ( { caid:id(:uphops), caid:id(:uphops), ... } )
#note: if {} limits are added, <wantemus> cannot be omitted. Use either yes or no.
# example:
# C: someserver.somedomain 12000 user1 pass1
# C: 192.168.1.2 12000 user2 pass2
# connects to CCcam without use of friends emus
# C: 192.168.1.2 12000 user3 pass3 yes
# connects to CCcam, and receives friends emus also.
# syntax for to add newcamd server connection
#N: <ip> <port> <username> <pass> <des(14byte)> <nr_of_hops_away (default: 1)> <stealth mode (default: 0)>
# example:
# N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
# add a newcamd card, give it an offset of 2 hops, in the share list
# N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 2
# stealthy login on newcamd server:
# N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 1 1
# stealth modes: 0 = disabled, 1 = mgcamd new, 2 = mgcamd old, 3 = evocamd, 4 = generic
prima concluzie
in continuare nu merge treaba cu 256 la urma#
PS1:Merge cardu hd+ 1843 in CCcam
PS2:noutatea este ca daca ai o line n poti sa alegi sa bui in hop2 , hop1 e default
# example:
cu siguranta tre sa existe o varianta pt cercuri restrance sare sa accepte N: 127.0.0.1 10000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 0 cea ce ar face cardu sa apara ca local
o arhiva cu versiunea E2 si scriptul necesar
CCcam_2.3.0.rar
a incercat cineva daca merge si dolce?
Nu merge
