Results 1 to 1 of 1
Thread: dm 800se
    19 Dec 2010
    Drobeta Turnu Severin
    Default dm 800se
    Produs: DM800SE
    Descriere: * 10/100MBit compatible Ethernet Interface
    * HDMI connector
    * plug & play Tuner
    * colored OLED display
    * plug & play slot for an internal 2,5" SATA hard disk
    * additional an eSATA connector
    Technical Features
    * 400 MHz MIPS Processor
    * Enigma 2, Linux Operating System
    * colored OLED - Display
    * MPEG-2 / H.264 Hardware decoding
    * Tuner: DVB-S, optional: DVB-C, DVB-T
    * Tuner Module, Plug&Play
    * 2 x Smartcard-Reader (Dreamcrypt CA)
    * Mini USB for Service and software update
    * 10/100Mbit Ethernet Interface
    * 1 x Scart (RGB, FBAS or S-Video)
    * HDMI
    * 2 x USB 2.0
    * analog modem
    * S/PDIF Interface for digital bit stream out (AC-3)
    * 64 MByte Flash, 256 MByte RAM
    * 2 x SATA
    - for internal HDD 2,5“
    - one external eSATA
    * unlimited channel lists for TV/Radio
    * channel-change time < 1 second
    * automatic service scan
    * directly bouquet-lists
    * EPG (electronic program guide)
    * multiple LNB-Switching control (supports DiSEqC)
    * OSD in many languages and skin-support
    * Videotext Decoder
    * extern 12V power supply
    DreamBox DM 800 HD se technical data
    DBS-Tuner mit DVB-S2:
    Frequency Range 950 .... 2150 MHz
    Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
    Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
    DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)
    Video decoder:
    Video Compression MPEG-2 and MPEG-1 compatible, H.246
    Video Formats 4:3 / 16:9
    Letterbox for 4:3 TV-Device
    Audio decoder:
    Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
    Audio Mode Dual (main/sub), Stereo
    Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Output analog:
    Output Level L/R 0,5 Vss on 600 Ohm
    THD > 60 dB (1 kHz)
    Crosstalk < -65 dB
    Output digital:
    Output Level 0,5 Vss on 75 Ohm
    Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Output optical, Toslink
    Ausgang Video:
    Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
    Video parameter:
    Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
    Teletext filter in conformity with ETS 300 472 Standard
    TV-Scart:
    Output: FBAS, RGB, S-Video
    Mini USB service connector:
    Function: Update of Firmware
    Ethernet:
    10/100 MBit compatible interface
    Analoge modem:
    analoge modem for Internet connection
    SATA Interface:
    for internal 2,5" HDD and one eSATA
    USB
    2 x USB 2.0 Host
    LNB power and polarisation per tuner:
    LNB Current 500mA max.; short-circuit-protected
    LNB Voltage vertical < 14V no load, > 11,5V at 400mA
    LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
    Count of active satellite position:
    DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
    Power consumption:
    < 15W at 12V
    External PSU
    Input:
    110-240V AC / 50-60Hz / 0,6A
    Output:
    12V = / 3,0A
    Physical specification:
    Ambient Temperature +15°C...+35°C
    Humidity < 80%
    Size (W x D x H): 225 mm x 145 mm x 52 mm
    Weight: 940 g without HDD
    Accesorii: DA
    Pret: 1000 RON
    Garantie: DA
    Alte detalii: nou
    Schimb cu:
    Contact: P.M
