Results 1 to 8 of 8
Thread: Driver updates for Vu+ Uno
    29 Nov 2008
    Cu capu' in nori
    Default Driver updates for Vu+ Uno
    Driver Updates - 2011-10-06
    20111006
    - improve DVB-C/T tuning(uno)
    - Fix incorrect display of DVB-C/T SNR/AGC(uno)
    - Fix high-bitrate problem in CI(uno, needs a FPGA update, New Rev  4.2 FPGA image is at http://archive.vuplus.com/download/fpga/vuuno/4.2/)
    - Support 3D framebuffer
    - Add interface for UI position setup
    - Add redundant fpga device at /dev (uno)
    - Add ioctl for hdmi_cec(get physical/logical addr.)
    - Fix audo mute in pass-through(uno)
    - Add interface to set the system code of the remote control(uno)
    - Add interface to disable REC VFD icon(uno,duo)
    - Add interface to control global alpha
    Download :
    http://archive.vuplus.com/download/d...0111006.tar.gz
    29 Nov 2008
    Cu capu' in nori
    Driver update 02-11-2011
    - Fix HDMI CEC problem(wakeup from standby)
    - Fix zapping noise in some A/V Receiver
    - Fix Recording/Playback problem
    - Fix High bitrate tuning problem(Uno, Needs a FPGA update, http://archive.vuplus.com/download/f...4.4/TS_PRO.dat )
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111102.tar.gz
    Aceste 2 update-uri ( fpga si driver ) rezolva problema de pe noul tp-ul 11411 de pe Hotbird, unde Uno nu gasea semnal. Am probat si merge.
    Pentru update de driver, se dezarhiveaza si se suprascrie in /lib/modules/2.6.18-7.3/extra.
    29 Nov 2008
    Cu capu' in nori
    Driver update 03-11-2011
    - Fix No sound problem in media playback
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111103.tar.gz
    Noul update rezolva lipsa de sonor la clipurile de pe Mytube si cele inregistrate pe hdd, bug aparut la versiunea de ieri.
    ---------- Post added at 14:48 ---------- Previous post was at 14:26 ----------
    Driver update 03-11-2011 (2)
    - Fix incorrect keycode in the remote control(ultimo)
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111103_2.tar.gz
    29 Nov 2008
    Cu capu' in nori
    Driver update 09-11-2011
    - Improve media playback
    - Add interface to control VFD in the application(ultimo)
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111109.tar
    vuplus-dvb-modules-bm750-2.6.18-7.3-4.4.3-20111109.tar
    vuplus-dvb-modules-vusolo-2.6.18-7.3-4.4.3-20111109.tar
    vuplus-dvb-modules-vuultimo-2.6.18-7.3-4.4.3-20111109.tar
    Am facut update in Vu+ Uno si totul e ok.
    29 Nov 2008
    Cu capu' in nori
    Driver update 10-11-2011
    - Fix skip problem in media playback
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111110.tar
    vuplus-dvb-modules-bm750-2.6.18-7.3-4.4.3-20111110.tar
    vuplus-dvb-modules-vusolo-2.6.18-7.3-4.4.3-20111110.tar
    vuplus-dvb-modules-vuultimo-2.6.18-7.3-4.4.3-20111110.tar
    29 Nov 2008
    Cu capu' in nori
    Driver update 11-11-2011
    - Fix VFD control interface(ultimo)
    - Fix snd playback problem(uno, ultimo)
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111111.tar
    29 Nov 2008
    Cu capu' in nori
    Driver update 14-11-2011
    - Reduce zapping noise in some A/V Receiver
    - Fix High bitrate tuning problem(Uno, MUST Need a FPGA update, http://archive.vuplus.com/download/fpga/vuuno/4.4/)
    - Change temperature calculation algorithm.(uno, ultimo)
    - Change the lowest FAN speed(ultimo)
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111114.tar
    29 Nov 2008
    Cu capu' in nori
    Driver update 22-11-2011
    - Fix video problem(at 20111114)
    Download :
    vuplus-dvb-modules-vuuno-2.6.18-7.3-4.4.3-20111122.tar.gz
