Results 1 to 15 of 22
Thread: Eutelsat W3C in curand pe orbita.....
    15 Feb 2007
    Default Eutelsat W3C in curand pe orbita.....
    Eutelsat W3C va fi pregatit pentru lansare pe orbita in luna septembrie, speram ca va fi o lansare cu final fericit dupa ce au pierdut mai multi sateliti la pozitia orbitala 16 est, iar acum la aceasta pozitie au fost relocati sateliti care nu mai sunt la capacitate optima. Daca lansarea va fi un esec pentru Eutelsat atunci posibil mai multi operatori DTH nu vor mai incheia contracte cu Eutelsat sau se vor reorienta catre alte pozitii orbitale.
    Datele tehnice compete :
    http://www.eutelsat.com/news/media_l...chures/W3C.pdf
    15 Feb 2007
    Cu data de 15 octombrie avem lansarea , sper sa fie una reusita !
    01 Sep 2010
    Andromeda
    Ar fi culmea sa se intample din nou...le propun sa se mute pe 9 sau pe 13 grade est
    15 Feb 2007
    In sfarsit avem Eutelsat w3c pe orbita...
    http://www.broadbandtvnews.com/2011/...ch-to-16-east/
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Deja suntem in 15 octombrie? Ce trece timpul!
    15 Feb 2007
    Parca ma trezesc maine cu Eutelsat W3C la 16 E cu toate transponderele active...
    15 Feb 2007
    Cei de la Eutelsat sau miscat bine si W3C este aproape de 16E, acum cica este la 15.4E
    01 Sep 2010
    Andromeda
    A new communications satellite Eutelsat W3C French satellite operator Eutelsat, which was issued October 7, 2011, will target position 16 ° E from 8 November 2011. The first major changes can we expect on the night of 8 to 9 November 2011. Eutelsat W3C at the orbital position of 16 ° E Eutelsat satellites will replace the outdated Sesat, Eutelsat W2M and Eurobird 16A. Ensure continuity of services for Central and Eastern Europe and Madagascar, and will allow expansion into new markets.
    Eutelsat W3C is equipped with 53 transponders in Ku and Ka band 3 in. Currently it is known that TV Slovenija 1 TV Slovenija 2, Kanal A and POP TV, Slovenia 3, and other stations and other channels from the former Yugoslavia will be broadcast from the new frequency - 11.366 GHz, pol V, SR 30000, FEC 3 / 4.
    Asa ca dati o scanare in noaptea de 8 spre 9 noiembrie...
    15 Feb 2007
    Sa asteptam ziua de 9 noiembrie, sa vedem ce acoperire si putere are.
    05 Feb 2008
    6 Post(s)
    cica in seara asta super tv se muta pe w3c/sa vedem acoperirea/nivel semnal
    15 Feb 2007
    Eu zic ca o sa aiba o putere mult mai mare decat rebuturile care sunt acum la 16 est.
    25 Sep 2008
    Suceava
    Teoretic, avem deja o prima frecventa pe noul satelit Eutelsat W3C, si anume 12574,64 Mhz V, SR 5925, FEC 5/6 pe care emit cateva programe ridicate de RRSat printre care si programul romanesc Top 1 TV, care anunta in partea de sus a ecranului, ca "Incepand cu data de 05.11.2011 ora 20.00 GMT, datele de receptie ale postului se vor schimba Satelit W3C, TPX F2, frecventa 12574,67 Mhz, S.R. 5,925 Msyb, FEC 5/6."
    Pe flysat si lyngsat frecventa apare ca fiind emisa de satelitul Sesat1, dar probabil e o eroare cum sa mai intamplat si altadata, semnalul totusi este destul de slab deocamdata!
    http://img98.imageshack.us/img98/4849/topiu.png
    http://img263.imageshack.us/img263/2332/top1u.png
    01 Sep 2010
    Andromeda
    A crescut semnalul[antena 90 cm]: Favorit - de la 50 % la 82 %. Frecventa 10555 3/4 10555 3/4 imi intra
    la limita si acum e semnal foarte bun. Intr-adevar un mare castig pe 16 E ! Sa ne bucuram
    si sa speram ca nu vom mai avea probleme pe acest satelit!
    Si, de asemenea, Top 1 pe noua frecventa 12.574 V SR 5925 FEC 5/6 semnalata de catre @Florynsv
    Golden Member mar1us's Avatar
    09 May 2009
    dublin
    Pune o poza cu tvr si una cu antena
