Results 1 to 7 of 7
Thread: Alien cu Enigma 2 RSP "INGHEATA" dupa ceva timp
    Standard RSP member Ovizel's Avatar
    14 Sep 2007
    Cluj Napoca
    Default Alien cu Enigma 2 RSP "INGHEATA" dupa ceva timp
    Salutare tuturor!
    Se pun in problema un receptor Amiko Alien cu enigma 2 RSP pe el varianta din 2.05.2011 mai exact rsp v3.205, oscam varianta 5367, card tvr, si o linie C, skin Vali.HD.nano (postat de stargate).
    Problema: merge ce merge totul si dintr-o data FREEZE total. Antidotul, butonul din spate on/off.
    De mentionat ca numai de la o vreme incoace face asa.
    M-am jucat putin cu imagini de la ARP si imaginea NeoProLux parca apoi am revenit la RSP, plus schimbat variante de oscam.
    Nu are o regula clara privind freezul, merge fie 5 minute fie jumatate de ora.
    O alta anomalie, din cand in cand pe 28.2 se inverzeste la oscam dar ramane negru ecranul si fara sunet sau daca apare imagine, decodeaza cateva secunde(20-30 si apoi freeze pe imagine insa receptorul raspunde la comenzi).
    Incarcare receptor in telnet:
    ALIEN login: root
    Password:
    + WWW.SATELITI.INFO +
    + Romanian Kathy Team +
    + Duckbox enigma2 +
    + RSP v3.205 GIT G2074 +
    BusyBox v1.11.2 (2011-05-02 22:38:33 EEST) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    ALIEN:~# top
    Mem: 83796K used, 9956K free, 0K shrd, 0K buff, 30704K cached
    CPU: 9% usr 0% sys 0% nice 90% idle 0% io 0% irq 0% softirq
    Load average: 14.33 14.51 13
    PID PPID USER STAT VSZ %MEM %CPU COMMAND
    1734 1731 root R 2020 2% 9% top
    754 753 root S 101m 110% 0% /var/emu/oscam_3520 -b -c /var/keys
    740 378 root S 89852 95% 0% /usr/local/bin/enigma2
    753 1 root S 2700 3% 0% /var/emu/oscam_3520 -b -c /var/keys
    888 470 root S 2456 3% 0% -sh
    1731 470 root S 2456 3% 0% -sh
    893 889 root S 2400 3% 0% /usr/bin/vsftpd
    896 894 root S 2388 3% 0% /usr/bin/vsftpd
    889 677 nobody S 2364 3% 0% /usr/bin/vsftpd
    894 677 nobody S 2364 3% 0% /usr/bin/vsftpd
    677 1 root S 2072 2% 0% /usr/bin/vsftpd
    436 1 root S 2044 2% 0% /usr/sbin/automount --timeout=5 /autof
    470 1 root S 2024 2% 0% /usr/sbin/telnetd -l /bin/login
    378 377 root S 2024 2% 0% /bin/sh /etc/init.d/rcS
    726 1 root S 2024 2% 0% udhcpc -R -n -p /var/run/udhcpc.eth0.p
    679 1 root S 2020 2% 0% /usr/sbin/inetd
    642 378 root S 1464 2% 0% /bin/evremote2 1 2 500
    477 1 root S 1428 2% 0% /usr/bin/lircd
    1 0 root S 1344 1% 0% ini
    377 1 root S 1344 1% 0% ini
    Mem: 84056K used, 9696K free, 0K shrd, 0K buff, 30700K cached
    CPU: 5% usr 4% sys 0% nice 89% idle 0% io 0% irq 0% softirq
    Load average: 13.66 14.36 13
    740 378 root R 89852 95% 5% /usr/local/bin/enigma2
    558 2 root DW< 0 0% 3% [pti_task]
    754 753 root S 101m 110% 1% /var/emu/oscam_3520 -b -c /var/keys
    1734 1731 root R 2456 3% 0% top
    389 2 root DW< 0 0% 0% [button/0]
    Mem: 75612K used, 18140K free, 0K shrd, 0K buff, 30700K cached
    CPU: 7% usr 19% sys 0% nice 72% idle 0% io 0% irq 0% softirq
    Load average: 14.01 14.42 13
    740 378 root R 89852 95% 19% /usr/local/bin/enigma2
    558 2 root DW< 0 0% 5% [pti_task]
    1734 1731 root R 2456 3% 1% top
    3 2 root SW< 0 0% 0% [ksoftirqd/0]
    899 2 root SW< 0 0% 0% [kdvb-fe-0]
    Mem: 84032K used, 9720K free, 0K shrd, 0K buff, 30700K cached
    CPU: 4% usr 17% sys 0% nice 77% idle 0% io 0% irq 0% softirq
    Load average: 14.17 14.45 13
    740 378 root S 89852 95% 15% /usr/local/bin/enigma2
    558 2 root DW< 0 0% 2% [pti_task]
    Ce-i de facut?
    Atasez si configuratia la oscam
    oscam.conf
    [global]
    serverip = 192.168.5.201
    usrfile =
    mailfile =
    logfile = stdout
    cwlogdir =
    emmlogdir =
    disablelog = 1
    disableuserfile = 1
    disablemail = 1
    loghistorysize = 4096
    usrfileflag = 0
    clienttimeout = 5000
    fallbacktimeout = 2500
    clientmaxidle = 120
    failbantime = 0
    failbancount = 0
    cachedelay = 0
    bindwait = 120
    netprio = 0
    sleep = 0
    unlockparental = 0
    nice = 99
    serialreadertimeout = 1500
    suppresscmd08 = 0
    maxlogsize = 0
    waitforcards = 1
    waitforcards_extra_delay = 500
    preferlocalcards = 1
    saveinithistory = 1
    readerrestartseconds = 5
    dropdups = 0
    lb_mode = 1
    lb_save = 100
    lb_nbest_readers = 1
    lb_nfb_readers = 3
    lb_min_ecmcount = 5
    lb_max_ecmcount = 500
    lb_reopen_seconds = 900
    lb_retrylimit = 800
    lb_retrylimits =
    lb_nbest_percaid =
    lb_noproviderforcaid =
    lb_savepath =
    lb_stat_cleanup = 336
    lb_use_locking = 0
    lb_reopen_mode = 1
    lb_max_readers = 0
    lb_auto_betatunnel = 1
    resolvegethostbyname = 0
    [monitor]
    port = 0
    serverip = 0.0.0.0
    nocrypt =
    aulow = 30
    hideclient_to = 15
    monlevel = 2
    appendchaninfo = 0
    [newcamd]
    port = 34000@0B02:000000
    allowed =
    keepalive = 1
    mgclient = 0
    [cccam]
    port = 12000
    reshare = 1
    ignorereshare = 0
    forward_origin_card = 0
    version = 2.1.3
    updateinterval = 240
    minimizecards = 0
    keepconnected = 1
    stealth = 0
    nodeid = 3ECCE783102C14E4
    reshare_mode = 0
    [dvbapi]
    enabled = 1
    au = 0
    boxtype = dreambox
    user = alien
    pmt_mode = 0
    request_mode = 0
    [webif]
    httpport = 84
    httphelplang = en
    httpuser =
    httppwd =
    httpcert =
    httpcss = /var/keys/blue.css
    httpjscript =
    httptpl =
    httpscript =
    httprefresh = 10
    httpallowed = 127.0.0.1,192.168.0.1-192.168.254.254
    httpdyndns =
    httphideidleclients = 0
    httpreadonly = 0
    httpsavefullcfg = 1
    oscam.dvbapi
    # dvbapi configuration
    # types:
    # P - Priority
    # format:
    # P: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
    # I - Ignore
    # format:
    # I: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
    # M - Map
    # format:
    # M: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <target caid>:[<target provider>]
    # D - Delay
    # format:
    # D: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <delay (ms)>
    # mai jos este un exemplu de configurare pentru cardul tvr
    P:0500:000000:000f:0021 # TVR HD TVR Card(16E)
    P:0500:000000:0001:0021 # TVR 1 TVR Card (16E)
    P:0500:000000:0002:0024 # TVR 2 TVR Card (16E)
    oscam.server
    [reader]
    label = TVR
    description =
    enable = 1
    protocol = internal
    device = /dev/sci0
    key =
    password =
    pincode = none
    readnano =
    services =
    smargopatch = 0
    showcls = 10
    fallback = 0
    logport = 0
    caid = 0500
    boxid =
    fix9993 = 0
    rsakey =
    force_irdeto = 0
    boxkey =
    atr =
    ecmwhitelist =
    detect = cd
    nagra_read = 0
    mhz = 368
    cardmhz = 368
    ident = 0500:FFF720,025900,025910
    chid =
    class =
    aeskeys =
    showcls = 10
    group = 1
    emmcache = 1,2,4
    blockemm-unknown = 0
    blockemm-u = 0
    blockemm-s = 0
    blockemm-g = 0
    lb_weight = 100
    savenano =
    blocknano =
    ccchop = 0
    deprecated = 0
    audisabled = 0
    auprovid =
    ndsversion = 0
    ratelimitecm = 0
    ratelimitseconds = 0
    [reader]
    label = linie_c
    description =
    enable = 1
    protocol = cccam
    device = user.dyndns.org,12000
    key =
    user = user
    password = parola
    pincode = none
    services =
    reconnecttimeout = 30
    fallback = 0
    logport = 0
    caid =
    ecmwhitelist =
    ident =
    chid =
    class =
    aeskeys =
    showcls = 10
    group = 1
    emmcache = 0,0,0
    blockemm-u = 0
    blockemm-s = 0
    blockemm-g = 0
    lb_weight = 100
    savenano =
    blocknano =
    cccversion = 2.1.3
    cccmaxhops = 3
    cccmindown = 0
    cccwantemu = 0
    ccckeepalive = 1
    cccreshare = -1
    audisabled = 0
    auprovid =
    oscam.user
    [account]
    user = alien
    pwd = alien
    description =
    disabled = 0
    expdate =
    allowedtimeframe =
    group = 1
    hostname =
    uniq = 0
    sleep = 0
    monlevel = 2
    services =
    caid =
    betatunnel = 1833.FFFF:1702,1834.FFFF:1722
    ident =
    chid =
    class =
    suppresscmd08 = 0
    cccmaxhops = 10
    cccreshare = -1
    cccignorereshare = -1
    cccstealth = -1
    sleepsend = 0
    failban = 0
    keepalive = 1
    23 Apr 2007
    P3X-888
    ce este la tine in configuri te apuca groaza ... deci iti pun configuratia mea ( card TVR si o linie CCcam ) si care a mers super ok indiferent de varianta de enigma2 folosita . editezi si tu conform datelor tale
    oscam.conf
    [global]
    logfile = stdout
    disablelog = 1
    nice = -1
    saveinithistory = 1
    lb_mode = 1
    lb_save = 100
    [dvbapi]
    enabled = 1
    boxtype = dreambox
    user = alien
    pmt_mode = 1
    request_mode = 1
    [webif]
    httpport = 84
    httpuser = user
    httppwd = parola
    httprefresh = 10
    oscam.server
    [reader]
    label = tvr
    enable = 1
    protocol = internal
    device = /dev/sci0
    caid = 0500
    ident = 0500:fff720,025900,025910
    services = tvr
    detect = cd
    mhz = 368
    cardmhz = 368
    group = 1
    lb_weight = 100
    [reader]
    label = cccam1
    enable = 1
    protocol = cccam
    device = user.dyndns.tv,14000
    user = user
    password = parola
    group = 1
    cccversion = 2.1.3
    cccmaxhops = 1
    ccckeepalive = 1
    audisabled = 1
    lb_weight = 100
    oscam.user
    [account]
    user = alien
    pwd = amiko
    group = 1
    chid = 0604:000014,000069,0000F4,0000F5,0000FA
    cccmaxhops = 2
    keepalive = 1
    oscam.dvbapi ( acest fiser este similar CCcam.prio si se modifica in functie de ce carduri aveti in liniile pe care le introduceti in config )
    # types:
    # P - Priority
    # format:
    # I - Ignore
    # format:
    # M - Map
    # format:
    # D - Delay
    # format:
    P:0500:042200
    P:0500:043800
    P:0500:042700 #PENTHOUSE HD 9E
    P:0500:024f00
    P:0500:022f00
    P:0BAA:000000:3312:0E7D # Eurosport HD
    P:0919:000000:3312:0e7a # Eurosport HD
    P:0BAA:000000:3312:076f # Eurosport2 HD
    P:0100:000068:3B63 # Eurosport2 HD
    P:0100:000068:0001:0064 # Mtv HD (13E)
    P:0B02:000000
    P:1880 # DIGI (1W)
    P:1803:000000:43B4
    P:0100:000068
    P:0D03:000000
    P:1702
    P:1830
    P:1833
    P:0500:041700 #Dorcel TV (13e)
    P:0500:042800:00CD #XXL (13e)
    P:0500:043800 #Redlight 3D HD (13e)
    P:0500:032500 #RR SAT (13e)
    P:0100:00006A
    P:0500:032830
    P:093B #SKY ITALIA
    P:0919 #SKY ITALIA
    P:09C4 #SKY ITALIA
    P:0963 #SKY UK
    P:1803
    #P:0500:024f00:000f:0020
    #M:0500:000000:000f:0021 0502:025900
    #P:4AE1:000013 #PENTHOUSE HD 9E
    I:093B:000000:35C3:0660
    fa un test si mai vorbim . bafta
    14 Sep 2007
    Cluj Napoca
    Din pacate si cu setarile sugerate de tine tot asa face, mai exact la schimbarea programelor am observat ca se intampla.
    Si pe spark s-a blocat insa mai rar.
    Posibil de la oscam, posibil de la internet(timpii de update sunt destul de mari cateodata 3.000-4.000)
    21 Post(s)
    Eu zic asa :
    - cu siguranta linia folosita nu rupe gura targului ! dar nu cred ca ea este cauza ...
    - ar merita sa faci un test de "anduranta" ...pe un canal HD FTA ...de exemplu cele
    germane sau austriece de pe Astra 19.2e
    - eu banuiesc o defectiune aleatoare de sursa ! fa testul de mai sus ...si vedem !
    14 Sep 2007
    Cluj Napoca
    Revin legat de probleme observate la Alien cu enigma 2.
    Din cand in cand se intampla ca atunci cand schimb de pe un program codat(hd mai des) se intampla sa functioneze, dupa un timp ingheata imaginea (incep macroblocuri si apoi blank), iar daca schimb programul chiar si pe cele free, nu mai apare imagine deloc - ecran negru si asta chiar si dupa un restart gui.
    Daca ii aplic un hard reset (buton din spate sau reboot total din enigma) apare iar imaginea si minunea tine pana cand il apuca iar pandaliile - decodare, macroblocuri imagine, si apoi nimic.
    Mentionez ca in satfinder sau operatiunea de tune pe frecventa imi arata ca semnal este insa imaginea nu mai vrea.
    S-a mai intalnit cineva cu o problema de genul asta?
    Multumesc anticipat!
    14 Sep 2007
    Cluj Napoca
    Vesti bune!
    Dupa aproximativ jumatate de zi de butonat, dupa inlocuirea skin-ului Vali.HD.nano cu HDGlass16 integrata in imaginea RSP, si oscam varianta 5367 cu varianta 5726, NU se mai blocheaza receptorul l(pana acum) deloc. Am observat totusi din cand in cand un mesaj "tune failed" cand schimb pe cate un canal fie free fie codat cu semnal mai slab, caz in care imaginea ramane neagra desi in enigma imi indica semnal, repet fie ele canale free. Revine totul la normal dupa un reboot total.
    18 Mar 2009
    Aceeasi problema o am si eu cu un amiko alien si o linie C, imagine enigma 2 din 27.07.2011.Se vede imaginea 10-15-20 minute, apoi se blocheaza si nu mai revine dacat dupa 2-3 minute de la restartarea de la intrerupatorul de retea si o ia de la capat. Am observat ca ECM time difera de la un moment la altul si de la un program la altul. Acesta se incadreaza intre 170 ms si 1700 ms , cele mai mult sta in jurul a 700 ms. De cand am cumparat receptorul folosesc aceeasi linie si aproximativ 1 luna de zile a mers ok, apoi au inceput problemele. Nu stiu daca e de la linia C pe care o primesc sau de la conexiunea de internet. Nu am vazut sa fie modificari in deschiderea paginilor de internet sau a a downloadului pe pc. Cu imaginea spark se intampla acelasi lucru, doar ca nu pot sa vad valoarea Ecm time. Am deschis you tube cu spark si merge perfect fara intrerupere, deci ma gandesc ca nu e de la net. Daca aveti ceva sfaturi, ce ar trebui sa verific si ce sa corectez, va multumesc anticipat!
