Code:| Protocols: CAMD35 NEWCAMD CCCAM CCCSHARE CONSTCW | Readers : NAGRA IRDETO CONAX CRYPTOWORKS VIACCESS VIDEOGUARD | CardRdrs : PHOENIX INTERNAL SMARGO STAPI
Code:+------------------------------------------------------------------------------- | OSCam ver: 1.20-ZILDAN_ rev: 8694 target: sh4-linux | Tools: | CROSS = sh4-linux- | CC = sh4-linux-gcc | Settings: | CONF_DIR = /var/keys | CC_OPTS = -O2 -ggdb -pipe -ffunction-sections -fdata-sections | CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition | CFLAGS = | LDFLAGS = -Wl,--gc-sections | LIBS = -lpthread -ldl | UseFlags = | Config: | Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK LCDSUPPORT | Protocols: CAMD35 NEWCAMD CCCAM CCCSHARE CONSTCW | Readers : NAGRA IRDETO CONAX CRYPTOWORKS VIACCESS VIDEOGUARD | CardRdrs : PHOENIX INTERNAL SMARGO STAPI | Compiler : sh4-linux-gcc (GCC) 4.6.3 20120613 (STMicroelectronics/Linux Base 4.6.3-111) | Binary : Distribution/oscam-1.20-ZILDAN_8694-sh4-linux +-------------------------------------------------------------------------------
Code:+------------------------------------------------------------------------------- | OSCam ver: 1.20-ZILDAN_ rev: 8699 target: sh4-linux | Tools: | CROSS = sh4-linux- | CC = sh4-linux-gcc | Settings: | CONF_DIR = /var/keys | CC_OPTS = -O2 -ggdb -pipe -ffunction-sections -fdata-sections | CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition | CFLAGS = | LDFLAGS = -Wl,--gc-sections | LIBS = -lpthread -ldl | UseFlags = | Config: | Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK LCDSUPPORT | Protocols: NEWCAMD CCCAM CCCSHARE CONSTCW | Readers : NAGRA IRDETO CONAX CRYPTOWORKS VIACCESS VIDEOGUARD | CardRdrs : PHOENIX INTERNAL | Compiler : sh4-linux-gcc (GCC) 4.6.3 20120613 (STMicroelectronics/Linux Base 4.6.3-111) | Binary : Distribution/oscam-1.20-ZILDAN_8699-sh4-linux +------------------------------------------------------------------------------- Este versiunea cu dvbapi9v1fixed.zip patch de pe Streamboard
Cu aceasta versiune inauguram un nou mod de a posta oscam sh40 pe RSP forum.
Arhiva va contine executabilul si scriptul pentru imaginea RSP e2.
Pentru a instala in imaginea e2 RSP, stergeti .zip si apoi copiati in /tmp pe aparat
Instalati din meniul RSP Installer > rosu > 3
Apoi RSP > rosu > 4 pentru a strege arhiva din tmp.
Code:| Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK LCDSUPPORT | Protocols: CAMD35 NEWCAMD CCCAM CCCSHARE CONSTCW | Readers : NAGRA IRDETO CONAX CRYPTOWORKS VIACCESS VIDEOGUARD | CardRdrs : PHOENIX INTERNAL
Buna ideea. Admin ar trbui sa modifice in setarile forumului, sa se poata atasa si tar.gz
ZILDAN EDIT:
Intre timp s-a adaugat si tar.gz la atasamente.
Am un card HD+ in Alien cu E2 RSP si Oscam 8704. Imi da o eroare cand pornesc OSCAM-ul:
Warning: Card returned error on setting ifsd value to 160
Card-ul merge, insa ma deranjeaza acest Warning. De unde vine? Ce inseamna?
Eu clar nu stiu.
Poate raspund altii.
Changeset 8765
theparasol
Message:
Fix for pixalization / freezes on pmtupdate tnx BurnMasterRecords? for reporting and testing
Code:+------------------------------------------------------------------------------- | OSCam ver: 1.20-ZILDAN_ rev: 8765 target: sh4-linux | Tools: | Settings: | CONF_DIR = /var/keys | CC_OPTS = -O2 -ggdb -pipe -ffunction-sections -fdata-sections | CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition | CFLAGS = | LDFLAGS = -Wl,--gc-sections | LIBS = -lpthread -ldl | UseFlags = | Config: | Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK LCDSUPPORT | Protocols: CAMD35 NEWCAMD CCCAM CCCSHARE CONSTCW | Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD | CardRdrs : PHOENIX INTERNAL | Compiler : sh4-linux-gcc (GCC) 4.6.3 20120613 (STMicroelectronics/Linux Base 4.6.3-111) | Binary : Distribution/oscam-1.20-ZILDAN_8765-sh4-linux +-------------------------------------------------------------------------------
zildan un Oscam 8784+ RSP in curand? Ultimul pus aici nu merge din pacate cu HD+ dupa un timp da eroare, am citit ca a fost corectat in versiunile noi (si merge si TNT Sat cu versiuni dupa 8784)
Oscam 8783 si 8810
Mersi frumos, dupa primele teste se pare ca 8810 merge OK.
O intrebare de 10 puncte: sa spunem ca am un receptor gen VU+ Solo2 (vreau sa-mi cumpar una). Solo2 are 2 sloturi de cititor de carduri si un loc pentru CAM. Daca imi iau un CAM Conax si MTV Unlimited, pot sa citesc acest card cu OSCAM si sa fac reshare la card? Aici ma gandesc ca pastrez receptorul Alien 8900 actual si pun la un alt TV si sa vad CARDUL MTV din CAM-ul Conax si pe Alien. Sau este musai sa bag in cititorul de card internal (unde n-o sa am loc ca am si un card HD+ si TNT SAT)?
Nu poti sa faci share din CAM.Incearca varianta cititoarelor pe USB.
oscam8846
Code:+------------------------------------------------------------------------------- | OSCam ver: 1.20-ZILDAN_ rev: 8846 target: sh4-linux | Settings: | CONF_DIR = /var/keys | CC_OPTS = -O2 -ggdb -pipe -ffunction-sections -fdata-sections | CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition | CFLAGS = | LDFLAGS = -Wl,--gc-sections | LIBS = -lpthread -ldl | UseFlags = | Config: | Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK | Protocols: CAMD35 NEWCAMD CCCAM CCCSHARE CONSTCW GHTTP | Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD | CardRdrs : PHOENIX INTERNAL MP35 SMARGO STAPI | Compiler : sh4-linux-gcc (GCC) 4.6.3 20120613 (STMicroelectronics/Linux Base 4.6.3-111) | Binary : Distribution/oscam-1.20-ZILDAN_8846-sh4-linux +-------------------------------------------------------------------------------
Dupa vreo 2 ani de absenta in care am stat pe CATV din cauza pozitiei nefavorabile reiau si eu acest hobby .Observ ca Oscam-ul a ajuns la versiuni evoluate si ma intreb :
Pe receptorul meu ipbox910hd am un oscam ver 4743 si merge ok .Este vreo versiune mai noua la fel de stabila si rapida?
Imi poate explica cineva ce noutati au aparut intre timp ,de ex cache ex ,etc ?
Multumesc !
