Results 1 to 4 of 4
Thread: nok
    Default nok
    Am trecut pe cccam si am o problema de intelegere pentru 0b02.
    Am cereri de ecm pentru 0b02 care stiu ca e focus si altii.
    Majoritatea imi apar ca nok, mai ales pentru altii. Exemplu 0b02:000000:4225 nok - nu stiu ce provider este.
    Cum pot sa blochez providerul si sa reduc nok-urile?
    23 Apr 2007
    P3X-888
    trebuie folosit in CCcam.cfg SMARTCARD SID ASSIGN si treci sid-urile canalelor pe care le deschide cardul tau focus conform cu abonamentul pe care il ai , doua exemple mai jos :
    asta am avut eu pe un card focus in phoenix
    SMARTCARD SID ASSIGN : /dev/usb/tts/0 44 { 7789, 778a, 778b, 78ba, 785b, 7857, 7791, 7794, 77fa, 76c2, 76c3, 772a, 772b, 778e, 76c4, 76c5, 7793, 772a, 76c6, 76c7, 76c8, 76c9, 76ca, 76cb, 76cc, 76cd, 7725, 7726, 7727, 7728, 7729, 00cc, 03ed, 772D, 772E, 7730, 7731, 7795, 03EB, 7733, 7792, 785f, 78b5, 7599 }
    iar acesta este exemplul din cccam.cfg
    # Configure limited list of accepted sids for smartcard
    # When omitted, all sids are allowed.
    # (can work together with LOADBALANCE configuration, or for standalone cards)
    # SMARTCARD SID ASSIGN : <device> <maxnumberofsids> { <sid1>, <sid2>, ... <sidn> }
    # <device> is the reader devicenode
    # <maxnumberofsids> limits the total number of sids assigned to the card (0 = use length of sid list)
    # { <sid1>..<sidn> } lists the sids that are assigned to the smartcard, when omitted, <maxnumberofsids> is used to auto assign sids
    # when <maxnumberofsids> is larger than the length of the sidlist, the remainder of the sids are auto assigned, till the list reaches <maxnumberofsids>
    # Check entitlement output for realtime assignment list
    # WARNING: when SMARTCARD SID ASSIGN config changes, restart is required before settings take effect
    #example1: smartcard in device /dev/ttyUSB0 only handles requests for sids df3, df4, df5
    # SMARTCARD SID ASSIGN : /dev/ttyUSB0 0 { 0df3,0df4,0df5 }
    #example2: smartcard in device /dev/ttyUSB0 handles requests for max 5 sids, auto assigned in the order of occurance. A request for a 6th sid will be denied.
    # SMARTCARD SID ASSIGN : /dev/ttyUSB0 5
    #example3: smartcard in device /dev/ttyUSB0 handles requests for max 5 sids, 3 of which are df3, df4, df5, remaining 2 are auto assigned
    # SMARTCARD SID ASSIGN : /dev/ttyUSB0 5 { 0df3,0df4,0df5 }
    Multam stargate.
    Scuze insa, am uitat sa spun ca eu am local akta si e vorba de ecm pe care le-as da din hop2 sau 3.
    Cum le blochez sa nu imi incarce serverul?
    Exemplu cerere 0b02:000000:2455 (nok) care imi apare de la doi clienti.
    23 Apr 2007
    P3X-888
    pune dupa exemplul de mai jos in linia F catre cei ce iti cer acel sid
    F: 1 0 0 { 0:0:2 } { 0b02:000000:2455 }
