De cateva zile a aparut pe alibaba clona DM800se, la preturi intre 196 si 204$, sau 245$ cu transportul inclus. Aveam in plan sa iau un dm800 pro, cu tuner M, dar parca imi face cu ochiul aceasta noua aparitie. Ceea ce ma retine, e faptul ca deja pe diferite forumuri straine multa lume se plange de probleme la acest receptor(nu functioneaza unul sau ambele cardreadere, probleme cu cccam, putine imagini pt acest receptor, s.a.).
Cineva spunea ca nu prea e recomandat sa cumperi, mai ales din primele loturi ale acestui produs, intr-un fel esti beta-tester pt chinezi, mai bine sa astepti sa se remedieze problemele semnalate de altii...
Ca idee, totusi, pe partea de tuner o diferenta intre tunerul M de pe dm800 pro si cel prezent pe dm800se , clona, evident se poate face? Care ar fi mai bun?
Iata specificatiile tehnice DM800se, clona:
10/100MBit compatible Ethernet Interface
HDMI connector
plug & play Tuner
colored OLED display
plug & play slot for an internal 2,5" SATA hard disk
additional an eSATA connector
Technical Feature
400 MHz MIPS Processor
Enigma 2, Linux Operating System
colored OLED - Display
MPEG-2 / H.264 Hardware decoding
Tuner: DVB-S, optional: DVB-C, DVB-T
Tuner Module, Plug&Play
2 x Smartcard-Reader (Dreamcrypt CA)
Mini USB for Service and software update
10/100Mbit Ethernet Interface
1 x Scart (RGB, FBAS or S-Video)
HDMI
2 x USB 2.0
analog modem
S/PDIF Interface for digital bit stream out (AC-3)
64 MByte Flash, 256 MByte RAM
2 x SATA
- for internal HDD 2,5
- one external eSATA
unlimited channel lists for TV/Radio
channel-change time < 1 second
automatic service scan
directly bouquet-lists
EPG (electronic program guide)
multiple LNB-Switching control (supports DiSEqC)
OSD in many languages and skin-support
Videotext Decoder
extern 12V power supply
technical data
DBS-Tuner mit DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 – 31 Mbaud/s (8PSK) , 10 –30 Mbaud/s (QPSK)-
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Mini USB service connector:
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
SATA Interface:
for internal 2,5" HDD and one eSATA
USB
2 x USB 2.0 Host
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V > 11,5V at 400mA
LNB Voltage horizontal < 20V > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
Power consumption
< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 225 mm x 145 mm x 52 mm
Weight: 940 g without HDD
Dislikes:
