Dislikes: 0
Black Hole Vu+ Solo 1.6.2 Final
Based on Official Image 5.9
-- Vu+ drivers: 20110531
* Update OE tree
* Support DDP Codec
* Add hdmi_cec at udev-static
* Fix HDD recognition problem
* Fix misc. bugs
- Subtitles fixed
- Add Dolby Digital Plus Support
- Add Hdmi CEC (need the new Vu+ Universal Remote Control)
- Add Wifi drivers r8192cu
- Update kernel config (CONFIG_SCSI_MULTI_LUN=y)
- Add Kernel-module-i2c-dev
- Fix bug in Bhpersonalbackup when no devices found
- Fix bug in Bhepgproviders managment
- Add Blindscan util
- Update udev static devices
- Fix Zeroconf
- Fix Sata issue
- Update Vuplus Feed config
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
UPnP Client Djmount
UPnP Server Mediatomb
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Sandro Cavazzoni for Cross EPG
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
Download USB :
http://www.vuplus-community.net/boar..._usb-zip.3233/
Download NFI :
http://www.vuplus-community.net/boar..._nfi-zip.3234/
