Page 1 of 4 1234 LastLast
Results 1 to 15 of 51
Thread: Emulatoare
    Default Emulatoare
    Deschid acest nou topic pentru a sti ce anume deschid emulatoarele si sa le instalati in functie de necesitati;
    MGcamd 1.27-
    i2,b1,s1/2,cr,biss
    v2.3/2.4,n1/2,t*s
    CCcam 204-
    b1,s1/2,cr,biss v2.3/2.4,n1/2
    EVocamd 2.17-
    i2,b1,s1/2,cr v2.3/2.4,n1/2,biss
    Acestea sunt cele mai uzuale camuri folosite,restul le puteti vedea/descarca de aici;
    http://www.dreamboxworld.com/dbw/emu_dream.htm
    Default Re: Emulatoare
    CCcam 2.0.5
    -global share limits (see CCcam.cfg for details)
    -global minimum required downhops setting (see CCcam.cfg for details)
    -n2 AU fix (/var/keys/ROM120.bin required)
    -cryptoworks sc fix
    -90f sc fix
    -viaccess sc emm fix
    -changed 'double client login reject' mechanism
    -G line local sharing fixed
    -graceful shutdown
    descarca de aici;
    http://sateliti.org/upload/index.php...iles/Emulators
    CCcam 2.0.5
    -cryptoworks sc fix
    -90f sc fix
    -graceful shutdown
    descarca de aici;
    Acum disponibil si pe serverul geminii
    EMU Mgcamd 1.28
    aici
    http://www.ump2002.net/index.php?&di...directory=EMUs
    sau direct pe serverul geminii
    01 Apr 2007
    evocam 2.16 => i2 pe hotbird ( canalele pt adulti )
    Super Member genugeo85's Avatar
    01 Apr 2007
    Vagauna Romania
    OpenCam_2.0.9 ce deschide?
    Var cu Adolf, frate cu Iosif, prieten cu Kim
    cccam 2.0.6.zip
    Read ChangeLog - ChangeLog Datei lesen
    12.02.2008
    Acum si pe serverul geminii
    mgcamd_1.29
    2008/02/14
    v1.29
    MCT, enjoy while it lasts
    06 Jan 2007
    Mgcamd_1.29 direct link:
    DOWNLOAD
    06 Jan 2007
    A aparut si Cccam 2.0.7! Pe serverul gemini...
    Quote Originally Posted by Einstein View Post
    fixed camcrypt on static (non-openssl) version
    -fixed segfault reading config
    01 Apr 2007
    19 Nov 2007
    salut !
    spune-mi si mie unde copiez
    mgcmd? si soft cam ?...asta e ...inca mai am de invatat...
    01 Apr 2007
    la geminii in /var/bin - mgcamd ( atentie la numele original ) ; *.key in /var/keys
