Page 4 of 4 FirstFirst 1234
Results 46 to 51 of 51
Thread: Oscam SH40 binary
  1. #46
    r5605 | docmarius | 2011-07-11 17:36:19 +0300 (Mon, 11 Jul 2011) | 1 line
    r5604 | JrCs | 2011-07-11 16:14:44 +0300 (Mon, 11 Jul 2011) | 1 line
    Update .gitignore file
    r5596 | docmarius | 2011-07-10 21:29:51 +0300 (Sun, 10 Jul 2011) | 4 lines
    Entitlement list: id changed to 64 bit for Seca PBM, class changed to 32 bit for Conax classes
    Webif: adapted to show longer Seca PBM in tooltips and new entitlement structure
    Reader-conax: reads also classes into entitlement list
    Reader-seca: reads PBM into entitlement list
    r5595 | Admin | 2011-07-10 20:39:44 +0300 (Sun, 10 Jul 2011) | 1 line
    Save errno before sleeping and restore it thereafter as some OS (especially MacOSX) seem to change errno to ETIMEDOUT when sleeping.
    r5591 | docmarius | 2011-07-10 18:27:16 +0300 (Sun, 10 Jul 2011) | 1 line
    WebIf: Added tooltips to reader status based on new entitlements lists
    r5589 | docmarius | 2011-07-10 15:18:09 +0300 (Sun, 10 Jul 2011) | 1 line
    Added Seca and DRE new entitlements
    r5584 | docman | 2011-07-10 08:56:26 +0300 (Sun, 10 Jul 2011) | 1 line
    Small update in 'oscam.dvbapi' example.
    r5583 | pattex | 2011-07-10 05:04:28 +0300 (Sun, 10 Jul 2011) | 2 lines
    WebIf: unlimited number of graphs can now be displayed. user graphs now without labels.
    on mouseover of a graph the label is displayed.
    r5582 | pattex | 2011-07-10 01:56:38 +0300 (Sun, 10 Jul 2011) | 1 line
    WebIf: typo fix. thx to Bit@Streamboard
    r5581 | pattex | 2011-07-10 01:52:51 +0300 (Sun, 10 Jul 2011) | 1 line
    WebIf: graphs of user ecm times can now viewed via USERS menue. More datapoints for longer history.
    r5580 | pattex | 2011-07-10 01:17:12 +0300 (Sun, 10 Jul 2011) | 1 line
    WebIf: false idle time was used. it was the idle time of the connection, not the time of the last ecm.
    r5579 | pattex | 2011-07-09 21:45:52 +0300 (Sat, 09 Jul 2011) | 1 line
    WebIf: small graph improvements
    r5577 | alno | 2011-07-09 15:19:19 +0300 (Sat, 09 Jul 2011) | 1 line
    Failban: correct count Ticket #1992 (THX kpc)
    r5576 | alno | 2011-07-09 14:38:46 +0300 (Sat, 09 Jul 2011) | 1 line
    correct blockemm-bylen parameter
    r5574 | alno | 2011-07-09 00:17:45 +0300 (Sat, 09 Jul 2011) | 1 line
    Failban: add listener Port to IP information
    r5572 | alno | 2011-07-08 21:45:56 +0300 (Fri, 08 Jul 2011) | 1 line
    Config: fix invalid errormessage
    r5571 | lareq78 | 2011-07-08 16:01:17 +0300 (Fri, 08 Jul 2011) | 1 line
    revert my last commit .
    r5570 | lareq78 | 2011-07-08 14:03:32 +0300 (Fri, 08 Jul 2011) | 1 line
    try quick fix for newcamd connection close
    r5569 | docmarius | 2011-07-08 01:21:26 +0300 (Fri, 08 Jul 2011) | 1 line
    Viaccess reader: Corrected missing entitlement clear on entitlement list generation (refresh entitlements)
    r5568 | pattex | 2011-07-08 01:10:23 +0300 (Fri, 08 Jul 2011) | 2 lines
    expdate check fixed (2 hour diff problem).
    r5567 | alno | 2011-07-07 22:03:45 +0300 (Thu, 07 Jul 2011) | 1 line
    Add listener identifier for modules
    r5565 | zetack | 2011-07-07 21:45:28 +0300 (Thu, 07 Jul 2011) | 2 lines
    fix 2 wrong memset commands
    r5564 | zetack | 2011-07-07 21:38:20 +0300 (Thu, 07 Jul 2011) | 2 lines
    cccam: fix false start of share updater with disabled cccam listener
    r5562 | pattex | 2011-07-07 18:22:10 +0300 (Thu, 07 Jul 2011) | 2 lines
    Change: in oscam.user, expdate=2011-07-31 is now interpreted a little different.
    2011-07-31 means the user can connect till 2011-07-31 23:59:59.
    r5560 | Deas | 2011-07-07 13:21:40 +0300 (Thu, 07 Jul 2011) | 1 line
    entitlements: add "valid" string before date in new output
    r5559 | docman | 2011-07-07 10:27:20 +0300 (Thu, 07 Jul 2011) | 1 line
    Added hint in documentation for ECM and EMM support with size > 256 bytes.
    r5558 | alno | 2011-07-07 00:21:05 +0300 (Thu, 07 Jul 2011) | 1 line
    WebIf: set entitlement startdate to n/a (not applicable) if no date exist
    r5557 | lareq78 | 2011-07-07 00:03:05 +0300 (Thu, 07 Jul 2011) | 1 line
    add log for duplicate user
    r5556 | alno | 2011-07-06 23:53:09 +0300 (Wed, 06 Jul 2011) | 1 line
    Add entitlement structure to videoguard provided by docmarius (SB) http://streamboard.gmc.to/wbb2/threa...517#post386517
    r5554 | alno | 2011-07-06 02:06:34 +0300 (Wed, 06 Jul 2011) | 1 line
    WebIf: extend entitlement with class
    r5553 | alno | 2011-07-06 02:00:52 +0300 (Wed, 06 Jul 2011) | 1 line
    Add classes to via entitlements. Again THX 2 docmarius (SB) for contribution http://streamboard.gmc.to/wbb2/threa...384#post386384
    r5552 | alno | 2011-07-06 00:59:39 +0300 (Wed, 06 Jul 2011) | 1 line
    some code readability and whitespaces
    r5551 | docman | 2011-07-05 23:58:37 +0300 (Tue, 05 Jul 2011) | 1 line
    Update for html documentation.
    r5550 | docman | 2011-07-05 23:42:48 +0300 (Tue, 05 Jul 2011) | 1 line
    Documentation for new parameter 'blockemm-bylen'.
    r5549 | alno | 2011-07-05 21:02:49 +0300 (Tue, 05 Jul 2011) | 1 line
    Add new entitlement structure to viaccess. THX docmarius (SB) for the code: http://streamboard.gmc.to/wbb2/threa...330#post386330
    r5548 | alno | 2011-07-05 20:52:21 +0300 (Tue, 05 Jul 2011) | 1 line
    New Reader Parameter in oscam.server 'blockemmbylen = 10,20,30,40,...' blocks all EMM with the defined lengths independent of g/s/u. Values as dezimal. 10 values allowed (can be extended if needed)
    r5546 | lareq78 | 2011-07-05 20:11:21 +0300 (Tue, 05 Jul 2011) | 1 line
    r5424: fix some emm problem caid 0x18 , reported in oscam.to
    r5545 | lareq78 | 2011-07-05 18:51:17 +0300 (Tue, 05 Jul 2011) | 1 line
    regard #1993 , #1981 revert newcamd r5424 . please test the result
    r5544 | Deas | 2011-07-05 17:17:39 +0300 (Tue, 05 Jul 2011) | 1 line
    entitlements: commit cryptoworks fix researched here: http://streamboard.gmc.to/wbb2/threa...tuser=0&page=4
    r5543 | lareq78 | 2011-07-05 13:52:29 +0300 (Tue, 05 Jul 2011) | 1 line
    fix #1991 (ecm.info cw length)
    r5542 | alno | 2011-07-05 02:06:24 +0300 (Tue, 05 Jul 2011) | 1 line
    Fix Conax entitlement (THX docmarius SB) on some cards related to http://streamboard.gmc.to/wbb2/threa...236#post386236
    r5541 | Admin | 2011-07-05 01:09:51 +0300 (Tue, 05 Jul 2011) | 1 line
    Fix for nagra provid in new entitlement struct.
    r5540 | alno | 2011-07-05 00:30:03 +0300 (Tue, 05 Jul 2011) | 1 line
    Entitlements: reset in nagra reader
    r5539 | alno | 2011-07-05 00:27:03 +0300 (Tue, 05 Jul 2011) | 1 line
    WebIf: Entitlements related to http://streamboard.gmc.to/wbb2/threa...204#post386204 I have implemented the already existing reset in irdeto, conax and cryptoworks reader. The suggestion related output I have committed THX to docmarius in Streamboard
    r5538 | alno | 2011-07-04 20:39:50 +0300 (Mon, 04 Jul 2011) | 1 line
    WebIf: fix Year displaying in Entitlements
    r5537 | alno | 2011-07-04 20:20:33 +0300 (Mon, 04 Jul 2011) | 1 line
    WebIf: add missing linebreak.
    r5536 | alno | 2011-07-04 19:46:30 +0300 (Mon, 04 Jul 2011) | 1 line
    WebIf: some formating in entitlement to show possibilities
    r5535 | Deas | 2011-07-04 17:55:08 +0300 (Mon, 04 Jul 2011) | 1 line
    entitlements: fix wrong provid on nagra, extend year to 4-digit as suggested by Alno here: http://streamboard.gmc.to/wbb2/threa...172#post386172
    r5534 | pattex | 2011-07-04 17:30:38 +0300 (Mon, 04 Jul 2011) | 2 lines
    WebIf: description value in reader section is now transported into Template variable ##CLIENTDESCRIPTION##.
    New attribute in API desc='description'
    r5533 | alno | 2011-07-04 09:37:33 +0300 (Mon, 04 Jul 2011) | 1 line
    remove failing debugmessage THX vr4b4c http://streamboard.gmc.to/wbb2/threa...157#post386157
    r5532 | alno | 2011-07-04 09:29:48 +0300 (Mon, 04 Jul 2011) | 1 line
    Fix compiler warning in irdeto module
    r5531 | alno | 2011-07-04 09:22:43 +0300 (Mon, 04 Jul 2011) | 1 line
    try fix irdeto entitlements
    r5530 | Deas | 2011-07-04 02:25:21 +0300 (Mon, 04 Jul 2011) | 1 line
    corrected links in readme
    r5529 | alno | 2011-07-04 02:23:42 +0300 (Mon, 04 Jul 2011) | 1 line
    temporarily remove ll_entitlements from videoguard readers. Seem to be an issue there
    r5528 | alno | 2011-07-03 22:53:35 +0300 (Sun, 03 Jul 2011) | 1 line
    Add ll_entitlements to videoguard readers !untested!
    r5527 | docman | 2011-07-03 21:37:28 +0300 (Sun, 03 Jul 2011) | 1 line
    Added documentation in html format.
    r5526 | docman | 2011-07-03 21:23:58 +0300 (Sun, 03 Jul 2011) | 1 line
    Added new parameter 'dropbadcws' to documentaion.
    r5525 | alno | 2011-07-03 21:02:41 +0300 (Sun, 03 Jul 2011) | 1 line
    fix bug in last commit
    r5524 | alno | 2011-07-03 20:49:23 +0300 (Sun, 03 Jul 2011) | 1 line
    insert different naming in WebIf output of entitlements
    r5523 | alno | 2011-07-03 20:19:48 +0300 (Sun, 03 Jul 2011) | 1 line
    enhance last commit
    r5522 | alno | 2011-07-03 20:05:26 +0300 (Sun, 03 Jul 2011) | 1 line
    Add ll_entitlements to conax !untested!
    r5521 | alno | 2011-07-03 15:47:40 +0300 (Sun, 03 Jul 2011) | 1 line
    Add ll_entitlements to nagra reader !untested!
    r5520 | alno | 2011-07-03 15:23:57 +0300 (Sun, 03 Jul 2011) | 1 line
    Add ll_entitlements on cryptoworks !untested! i havn't such card
    r5519 | alno | 2011-07-03 15:03:55 +0300 (Sun, 03 Jul 2011) | 1 line
    Activate new ll_entitlement on irdeto reader (additional to cs_ri_log()) legacy entitlement out put shouldn't be affected. In webif the new output is shown below legacy output on entitlements of irdeto readers
    r5518 | alno | 2011-07-03 12:48:15 +0300 (Sun, 03 Jul 2011) | 1 line
    Add function to calc an entitlement date but not active. Just for discussion
    r5517 | Admin | 2011-07-03 02:32:23 +0300 (Sun, 03 Jul 2011) | 1 line
    Fix too small date buffer on cw logging.
    Attached Files Attached Files
  2. #47
    31 Oct 2007
    Pentru toti cei care folosesc pluginul oscam pe Amiko 8900 Alien si apar blocaje , intreruperi ,va recomand sa folositi varianta de mai jos.Este foarte stabila.Restul nu sunt stabile.Sper ca v-am putut fii de folos.
    Functioneaza perfect pe E2 cat si pe Spark
    http://www.megaupload.com/?d=GOLLK3T3
  3. #48
    09 May 2011
    Why not work on the SPARK.
    Do you need something else to do?
  4. #49
    31 Oct 2007
    you must set attribute "755" and put the oscam configuration files in "/root/plugin/var/tuxbox/config"
  5. #50
    09 May 2011
    Now that is ok
    Thank you!
  6. #51
    12 Aug 2008
    In fata calculatorului
    nu merge linkul, plz
    poate ai mila, si il mai pui odata
