Page 1 of 5 12345 LastLast
Results 1 to 15 of 63
Thread: Spark Edit - channels editor for Spark
    24 Nov 2008
    Default Spark Edit - channels editor for Spark
    Spark Edit
    Channels editor for Spark version 1.1.38 or higher .
    This is the first beta version ... please make a backup of your XML files before using this tool.
    I hope that will be useful.
    Features :
    Add new channels to favorites
    Change favorites position
    Remove channels from favorites
    Rename favorites
    Etc. ...
    Usage :
    1. Export from spark the database to XML using your remote control
    2. Open SparkEdit
    3. Select the folder/disk where the XML files are located
    4. Modify your favorites channels
    5. Save XML files
    6. Import XML to Spark database using your remote control
    Things to do in next version:
    1. Update sat.xml from satellites.xml ( http://satellites-xml.eu )
    2. Support for Radio Favorites
    3. Drag-Drop functionality
    4. Load / Save settings directly to Spark
    5. Add user profiles option
    6. Add parental control for channels
    Download :
    https://rapidshare.com/files/2803333...arkEdit1.0.zip
    09 May 2011
    For Windows7 not working ...
    24 Nov 2008
    what is not working ?
    can you send me a print screen ?
    i also have Windows 7 and its ok.
    Standard RSP member Meridian's Avatar
    01 Sep 2010
    Andromeda
    Windows Xp...Error! Gluma de santier...poate vede vreun moderator!
    23 Apr 2007
    P3X-888
    nu este gluma de santier .... @ecokey chiar stie ce face dar este un program beta care sunt sigur ca-l va rezolva .
    30 Mar 2011
    Slovakia
    Unhappy Error with Windows 7
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: SparkEdit_beta.exe
    Application Version: 0.0.0.0
    Application Timestamp: 2a425e19
    Fault Module Name: KERNELBASE.dll
    Fault Module Version: 6.1.7600.16385
    Fault Module Timestamp: 4a5bdaae
    Exception Code: 0eedfade
    Exception Offset: 00009617
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1051
    Additional Information 1: 0a45
    Additional Information 2: 0a453574efbfb079cb107ad519fb8209
    Additional Information 3: 5ddd
    Additional Information 4: 5dddf1a2892123a77799669d38664371
    and Error window:
    Application Error:
    Exception EDOMParseError in module SparkEdit_beta.exe at 0017F773.
    The system cannot locate the resource specified.
    Line ()
    I have English Windows 7 Ultimate.
    24 Nov 2008
    da. are o eroare . o rezolv intr-o ora.
    si nu e gluma
    ---------- Post added at 19:14 ---------- Previous post was at 19:07 ----------
    Sorry for this.
    Just a little mistake.
    Please download from here the correct version :
    https://rapidshare.com/files/4201047541/SparkEdit.zip
    Rog un moderator sa schimbe linkul in primul post cu asta. 10x
    01 Sep 2010
    Andromeda
    Eroarea in Xp:
    AppName: sparkedit_beta.exe AppVer: 0.0.0.0 ModName: kernel32.dll
    ModVer: 5.1.2600.5781 Offset: 00012afb
    09 May 2011
    Quote Originally Posted by ecokey View Post
    On Windows 7 threw me this error:
    Application Error
    Line:0
    24 Nov 2008
    Thanks
    01 Sep 2010
    Andromeda
    La ultima 'revizie' nu mai da nicio eroare pe windows xp sp 3. Eu sunt corect...prima data in afara de eroarea semnalata nu se intampla nimic.
    24 Nov 2008
    One more small bug :
    The file tv_fav.xml is not saved where all the xml files are.
    This file is saved where the application executable is saved.
    After Save xml ... you need to copy the tv_fav.xml on your usb stick or HDD where the rest of the files are.
    I will make a new version tomorrow to fix this.
    Once again, sorry for this smals bugs, but i have done this program in a verry short time .
    Si in romana :
    Un alt mic bug pe care il voi rezolva maine :
    fisierul tv_fav.xml nu e salvat unde trebuie cand se apasa butonul.
    El se salveaza acolo unde e salvat si programul SparkEdit.
    Trebuie sa copiati si acest fisier acolo unde sunt restul fisierelor xml (pe stick sau HDD) inainte de a importa in spark.
    Scuze pentru aceste mici probleme ... dar nu am avut mult timp la dispozitie sa il finisez.
    01 Sep 2010
    Andromeda
    Nu stiu unde se afla acel tv_fav.xml...cum se procedeaza mai exact?
    24 Nov 2008
    Acolo unde ai salvat programul SparkEdit.exe
    tot acolo e si fisierul . Sa zicem ca ai dezarhivat in C:\temp ... tot in C:\temp va fi si fisierul xml.
    Procedura e asa :
    Exporti fisierele XML din spark de la "Database Transformer"
    fisierele se salveaza pe stick sau HDD ... ce ai tu
    apoi deschizi acele fisiere cu programul Sparkedit
    editezi cum vrei apoi dai save xml.
    Aici chestia e ca fisierul tv_fav.xml nu se salveaza tot pe stick (adica acolo de unde s-a deschis)
    ci se salveaza tot acolo unde e si programul.
    Trebuie doar sa copii acel fisier inapoi pe stick ... apoi dai import din Spark .
    01 Sep 2010
    Andromeda
    Miracol !!! Contribui si eu cu ceva...
    Apoi se apasa pe butonul rosu...pentru export spre stick. Pe verde cand vrei sa pui pe Spark ce ai pe stick!
