Page 7 of 7 FirstFirst ... 34567
Results 91 to 100 of 100
Thread: Amiko 8900 AR-Projekt Enigma2
  1. #91
    27 Sep 2007
    O noua imagine de la AR-Projekt E2 for AMIKO_SHD-8900 :
    1., Fixed kernel, check on the possibility of 36° East who were key problems.
    2., fixed button TV / radio
    3., Added option to move to spark the menu
    4., Added a plugin from a technician on tv kartina, thanks to him for work. out of the plug-button TV / radio
    5., fixed samba. try.
    6., Added mgkamd1.37
    7., fixed SoftwareManager
    8., Added NetworkBrowser
    9., Changes in ap / panel
    10., All skins and plugins you can download it from pluginmenedzher
    11., The button also sends a spark to the spark.
    12., Fixed receiver off the full menu.
    13., Added support for long press the buttons. (optional keymap.xml Edit the spread on the benefit of others.)
    Download
  2. #92
    27 Oct 2011
    AR-Projekt E2 for AMIKO_SHD-8900 24.10.2011
    Version 1.2.31.03 AR-P
    Fixed spark boot
    Fixed skins...
  3. #93
    Standard RSP member samuell's Avatar
    23 Sep 2010
    caransebes.CS-ghencea
    Default oscam
    de unde downloadez un oscam svn 755 pentru imaginea ar-p.multumiri anticipate
  4. #94
    23 Apr 2007
    P3X-888
    755 este un atribut care sa da unui fisier si o poti face in urmatorul fel ... cu ajutorul un client FTP transferi oscam in alien si apoi dai click dreapta pe fisierul transferat in Alien si apoi in fereastra care se deschide alegi Proprietati sau Permisiuni File ( eu folosesc FileZilla si WinSCPC ca si clienti FTP la celelalte softuri nu stiu sigur cum este ) si acolo in loc de 644 treci 755 .
  5. #95
    Standard RSP member satbox4all's Avatar
    10 Jan 2011
    AR-Projekt E2 for AMIKO_SHD-8900 28.11.2011
    fixed audio
    Download
  6. #96
    Almelo
    only fixed audio
    when will they come whit a good cardreader?
    and why is this image so slow?
    DM800HD pvr
    T90
    Amiko Alien
  7. #97
    30 Jun 2011
    Pe imaginea AR-Projekt E2 for AMIKO_SHD-8900 28.11.2011 incerc sa mountez un folder din retea. In Setup-System-Network-MountManager folderul apare adaugat ok, dar nu inteleg cum pot sa ajung la el in media player. Am intrat in InternalFlash/Mnt dar aici nu am nici un CIFS doar HDD,NFS,USB.
    Am mai incercat sa intru cu filezila in Var/config ca sa modific fisierul amnt.cfg dar aici am doar emu.conf si language.conf.
    ---------- Post added at 11:33 ---------- Previous post was at 11:31 ----------
    Nu am gasit nicaieri o optiune ca sa activez CIFS si nici nu inteleg cum pot sa ajung la ROSU > RSP TEAM MENU > USER OPTIONS > GENERAL OPTIONS (daca ar mai fi disponibil pe imaginea asta)
  8. #98
    23 Apr 2007
    P3X-888
    Imaginea AR-Project este diferita ca organizare panel de imaginea RSP si de aici lipsa unor optiuni .
  9. #99
    30 Jun 2011
    Inteleg acest lucru. Totusi cum as putea sa rezolv problema pentru imaginea AR-Project?
  10. #100
    19 Aug 2011
    UTC+13
    Cel mai bine ar fi sa te adresezi lor. Acolo ai putea primi un raspuns mai exact.
    muta sobolanu` de aici
