Results 1 to 15 of 15
Thread: Topex cu openwrt cu boot de pe stick
    19 Jul 2009
    Default Topex cu openwrt cu boot de pe stick
    Buna.
    Am un router topex cu openwrt.Conform tutorialul lui Rsofty am facut sa booteaza de pe stick si am instalat cccam.
    Cineva are un tutorial pentru instalare samba si mondtare hdd extern (NTFS)
    Multumesc
    Moderator sorin8m's Avatar
    22 Apr 2007
    Instalare SAMBA
    root@OpenWrt:/# opkg update
    root@OpenWrt:/# opkg install luci-app-samba
    Installing luci-app-samba (0.8.8-1) to root...
    Downloading http://downloads.openwrt.org/kamikaz...8-1_mipsel.ipk
    Connecting to 10.1.1.1:8080 (10.1.1.1:8080)
    luci-app-samba_0.8.8 100% |*************************************************************************************************** ******| 2866 --:--:-- ETA
    Installing samba3 (3.0.24-2) to root...
    Downloading http://downloads.openwrt.org/kamikaz...4-2_mipsel.ipk
    Connecting to 10.1.1.1:8080 (10.8.39.5:8080)
    samba3_3.0.24-2_mips 100% |*************************************************************************************************** ******| 456k 00:00:00 ETA
    Installing libpthread (0.9.29-14.3) to root...
    Downloading http://downloads.openwrt.org/kamikaz...4.3_mipsel.ipk
    libpthread_0.9.29-14 100% |*************************************************************************************************** ******| 19340 --:--:-- ETA
    Configuring libpthread
    Configuring luci-app-samba
    Configuring samba3
    preluat de pe alt forum, autorul tutorialului este tivcol
    In legatura cu hdd exter partitionat NTSF, eu ti-as recomanda sal partitionezi EXT3, findca openwrt kamikaze (kernel 2.4) NTSF poate doar sal citesca nu si sa scrie (este READ ONLY, RO).
    Dupa cum ai scris presupun ca ai instalat openwrt kamikaze kernel 2.4
    19 Jul 2009
    Mersi Sorin.
    Atunci de aia nu vede pe hard.Si o problema ca samba nu a aparut in webinterface.
    19 Jul 2009
    Sorin,
    Daca fac fat si nu ext3.O sa fie tot read only?
    19 Jul 2009
    Primesc eroarea urmatoare cand dau comanda dmesg din putty.Totul am facut conform tutorial.
    NU stiti de ce?
    usb.c: USB disconnect on device 01:02.0-1.3 address 6
    hub.c: new USB device 01:02.0-1.3, assigned address 7
    WARNING: USB Mass Storage data integrity not assured
    USB Mass Storage device found at 7
    usb.c: USB disconnect on device 01:02.0-1.3 address 7
    hub.c: new USB device 01:02.0-1.3, assigned address 8
    USB Mass Storage device found at 8
    FAT: bogus logical sector size 0
    19 Jul 2009
    UDP: bad checksum. From 78.174.30.222:8403 to 192.168.0.3:41534 ulen 106
    usb.c: USB disconnect on device 01:02.0-1.3 address 8
    hub.c: new USB device 01:02.0-1.3, assigned address 9
    USB Mass Storage device found at 9
    Nu stie nimeni raspunsul?
    19 Jul 2009
    root@OpenWrt:/# /etc/init.d/usbhdd start
    Mounting USB drive: mount: mounting /dev/scsi/host0/bus0/target0/lun0/part1 on /share failed: Invalid argument
    Stie cineva cum se rezolva problema?
    27 Feb 2011
    Miercurea Ciuc
    Ce fel de hard disk ai?
    Intreb fiindca eu am doua HDD-uri externe: unul de 2.5" si altul de 3.5". Primul n-are sursa, deci se alimenteaza prin portul USB, al doilea are sursa externa. Am constatat ca sursa micuta a routerului Bytton Topex nu poate alimenta un HDD extern prin USB.
    Poate asta-i problema si la tine. Incearca un hard cu sursa proprie, si vezi daca reusesti.
    19 Jul 2009
    Are sursa proprie.
    Member Addicted Member
    11 Feb 2007
    Șoseaua Kiseleff nr. 10
    Quote Originally Posted by battila View Post
    ...mount: mounting /dev/scsi/host0/bus0/target0/lun0/part1 on /share failed: Invalid argument
    Aici e tot secretul; " on /share failed: Invalid argument "
    19 Jul 2009
    Bine Zappa.Zi-mi si mie care este secretul acolo.:P
    19 Jul 2009
    Attached scsi disk sdb at scsi1, channel 0, id 0, lun 0
    out of order segment: rcv_next 20A3A6BA seq 20A3A700 - 20A3A708
    SCSI device sdb: 312581808 512-byte hdwr sectors (160042 MB)
    /dev/scsi/host1/bus0/target0/lun0: p1 < p5 >
    Asta am observat cand am dat comanda dmesg. Ce inseamna p5 la sfarsit?
    17 Jun 2011
    Bacau
    Quote Originally Posted by birrbert View Post
    Dupa ce ai deconectat modemul GPRS ai rezolvat cumva si cu alimentarea HDD-ului?
    Tvicol mai propunea o solutie:
    Quote Originally Posted by tvicol
    Sursa interna de 5V am lasat-o nemodificata. In schimb am modificat sursa ajustabila.
    Pentru a scoate 5V, R22 si R21 trebuiesc eliminate si in locul lor montati un rezistor de 4k7.
    Scurt intre pinul 3 si pinul 5 de la LM2596adj pentru a trece stabilizatorul pe ON.
    http://imageshack.us/f/593/img3512u.jpg/
    22 Apr 2007
    Eu vas recomanda hdd extern cu sursa proprie. Eu am unul de 1.5TB si merge perfect.
    17 Jun 2011
    Bacau
    Am incercat si eu cu un hdd extern de 1TB(cu alimentare proprie) si functioneaza perfect.
    Totusi daca tot nu folosesc modemum GPRS as vrea sa ii folosesc alimentarea si sa las un hdd mai mic tot timpul(pentru ftp).
