Results 1 to 8 of 8
Thread: Telecomanda DM 500 - comenzi aiurea...
    15 Feb 2007
    Default Telecomanda DM 500 - comenzi aiurea...
    De ieri dupa ce am " frecat" putin setarile si meniul la DM 500 nu mai raspunde la comenzile pe care le dau conform cu butoanele care sunt pe telecomanda....marea buba este setarea pentru volum care a disparut cu totul, iar volumul il reglez din telecomanda TV.ului, ce e de facut?
    Cauta in /var/tuxbox/config/enigma fisierul config si compara ce ai acolo cu asta:
    i:/elitedvb/DVB/config/lnbs/0/12VRelaisOut=00000000
    i:/elitedvb/DVB/config/lnbs/0/DiSEqCMode=00000001
    i:/elitedvb/DVB/config/lnbs/0/DiSEqCParam=00000000
    i:/elitedvb/DVB/config/lnbs/0/DiSEqCRepeats=00000000
    i:/elitedvb/DVB/config/lnbs/0/FastDiSEqC=00000000
    i:/elitedvb/DVB/config/lnbs/0/IncreasedVoltage=00000000
    i:/elitedvb/DVB/config/lnbs/0/MiniDiSEqCParam=00000000
    i:/elitedvb/DVB/config/lnbs/0/SeqRepeat=00000000
    i:/elitedvb/DVB/config/lnbs/0/SwapCmds=00000000
    i:/elitedvb/DVB/config/lnbs/0/gotoXXLaDirection=00000000
    i:/elitedvb/DVB/config/lnbs/0/gotoXXLoDirection=00000002
    i:/elitedvb/DVB/config/lnbs/0/satellites/0/HiLoSignal=00000000
    i:/elitedvb/DVB/config/lnbs/0/satellites/0/OrbitalPosition=fffffff8
    i:/elitedvb/DVB/config/lnbs/0/satellites/0/VoltageMode=00000000
    i:/elitedvb/DVB/config/lnbs/0/uncommitted_cmd=00000000
    i:/elitedvb/DVB/config/lnbs/0/useGotoXX=00000001
    i:/elitedvb/DVB/config/lnbs/0/useRotorInPower=00002800
    i:/elitedvb/DVB/config/nocircular=00000000
    i:/elitedvb/audio/VCRvolume=0000000a
    i:/elitedvb/audio/ac3default=00000000
    i:/elitedvb/audio/mute=00000000
    i:/elitedvb/audio/volume=00000000
    i:/elitedvb/extra/autobouquetchange=00000001
    i:/elitedvb/extra/autoservicesupdate=00000000
    i:/elitedvb/extra/cahandlerReconnect=00000000
    i:/elitedvb/extra/extzapping=00000000
    i:/elitedvb/extra/fastzapping=00000001
    i:/elitedvb/extra/hideerror=00000001
    i:/elitedvb/extra/profimode=00000000
    i:/elitedvb/hidelocked=00000000
    i:/elitedvb/network/connectionType=00000000
    i:/elitedvb/network/dosetup=00000001
    i:/elitedvb/network/samba=00000001
    i:/elitedvb/network/usedhcp=00000001
    i:/elitedvb/network/webifport=00000050
    i:/elitedvb/network/wizard=00000001
    i:/elitedvb/pins/parentallock=000004d1
    i:/elitedvb/pins/setuplock=00000000
    i:/elitedvb/system/bootCount=00000032
    i:/elitedvb/wizards/diseqc=00000001
    i:/enigma/noac3recording=00000000
    i:/enigma/notimestampdetect=00000000
    i:/enigma/nottxrecording=00000000
    i:/enigma/plugins/needoffsets/bottom=00000221
    i:/enigma/plugins/needoffsets/left=0000002c
    i:/enigma/plugins/needoffsets/right=000002a3
    i:/enigma/plugins/needoffsets/top=0000001d
    i:/enigma/timeoutInfobar=00000006
    i:/extras/auto_cam=00000000
    i:/extras/cam_info=00000001
    i:/extras/ci_mess=00000001
    i:/extras/enable_rass=00000001
    i:/extras/epg_cache=00000000
    i:/extras/extra_field=00000001
    i:/extras/ezap_offset_x=00000005
    i:/extras/info_bar_ok=00000000
    i:/extras/mhwepg=00000000
    i:/extras/osd_crypt=00000003
    i:/extras/osd_extra_info=00000002
    i:/extras/radio_info_bar=00000000
    i:/extras/showSatPos=00000000
    i:/extras/showServiceSelector=00000000
    i:/extras/showmvipic=00000001
    i:/ezap/extra/autoplay=00000001
    i:/ezap/extra/disableSerialOutput=00000001
    i:/ezap/extra/teletext_caching=00000001
    i:/ezap/lcd/brightness=000000a1
    i:/ezap/lcd/contrast=0000001d
    i:/ezap/lcd/inverted=00000000
    i:/ezap/osd/alpha=00000080
    i:/ezap/osd/brightness=00000073
    i:/ezap/osd/gamma=00000073
    i:/ezap/osd/hideshortcuts=00000000
    i:/ezap/osd/showCurrentRemaining=00000001
    i:/ezap/osd/showOSDOnEITUpdate=00000000
    i:/ezap/osd/showOSDOnSwitchService=00000001
    i:/ezap/osd/simpleMainMenu=00000000
    i:/ezap/rc/repeatDelay=000001f4
    i:/ezap/rc/repeatRate=0000003c
    i:/ezap/serviceselector/showButtons=00000001
    i:/ezap/teletext/use_external=00000000
    i:/ezap/ui/lastmode=00000000
    i:/ezap/ui/playlistmode=00000000
    i:/ezap/ui/serviceSelectorStyle=00000002
    i:/ezap/webif/lockWebIf=00000001
    i:/ezap/webif/lockmessage=00000000
    u:/elitedvb/DVB/config/lnbs/0/lofH=00a1be40
    u:/elitedvb/DVB/config/lnbs/0/lofL=0094c5f0
    u:/elitedvb/DVB/config/lnbs/0/lofThreshold=00b28720
    u:/elitedvb/network/dns=c0a80101
    u:/elitedvb/network/gateway=c0a80101
    u:/elitedvb/network/ip=c0a80164
    u:/elitedvb/network/netmask=ffffff00
    u:/elitedvb/video/colorformat=00000002
    u:/elitedvb/video/disableWSS=00000000
    u:/elitedvb/video/pin8=00000002
    u:/elitedvb/video/tvsystem=00000001
    u:/elitedvb/video/vcr_switching=00000000
    u:/ezap/rc/TextInputField/nextCharTimeout=00000320
    d:/elitedvb/DVB/config/lnbs/0/gotoXXLatitude=0.000000
    d:/elitedvb/DVB/config/lnbs/0/gotoXXLongitude=0.000000
    s:/elitedvb/DVB/config/lnbs/0/RotorTable=
    s:/elitedvb/DVB/config/lnbs/0/satellites/0/description=Thor6/Thor3/5/Intelsat10-02 (0.8W)
    s:/elitedvb/language=C
    s:/elitedvb/timezone=(GMT+02:00) Bucharest
    s:/ezap/keyboard/mapping=/share/keymaps/eng.kmap
    s:/ezap/ui/modes/0/path0=4097:7:0:6:0:0:0:0:0:0:;4097:7:0:dbe57:0:0:0:0:0:0:/var/tuxbox/config/enigma/userbouquet.dbe57.tv;1:0:1:62c:2:1:fff831b3:0:0:0:;
    s:/ezap/ui/modes/1/path0=0:7:2:0:0:0:0:0:0:0:;-1:0:0:0:0:0:0:0:0:0:;
    s:/ezap/ui/modes/2/path0=0:7:3:0:0:0:0:0:0:0:;-1:0:0:0:0:0:0:0:0:0:;
    s:/ezap/ui/skin=/var/tuxbox/config/enigma/skins/new_blueline_skin_v3.esml
    Cauta sa vezi diferentele la ce te intereseaza
    15 Feb 2007
    La mine este asemanator...dar nu cred ca este de aici problema sau poate da?
    10 Nov 2007
    Vezi la setari sa nu fi pus telecomanda de Dm7020
    15 Feb 2007
    Unde mai exact la setari trebuie sa verific?
    10 Nov 2007
    Iaca nu stiu sigur ca nu mai ajuns de mult acolo dar stiu cu siguranta ca este o asemenea setare pe GP, o sa caut diseara cind ajung acasa
    buton albastru===extra setup si la capat ai 70xx remote control?
    15 Feb 2007
    Bravo.....o bere de la mine, asa era....era bifat optiunea cu dm 70xx...
    Multam .....
