Thanks Thanks:  52
Likes Likes:  26
Dislikes Dislikes:  1
Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 107
Thread: emuVu
  1. #61
    OSCam 11.581-r0 emu r798
    ALL Images mips - arm
    11581
    -Fix Using gbox protocol the last byte is missing from the odd CW in the ecm debug string
    enigma2-softcams-oscam-all-images_11.581-emu-r798-arm+mips_all.ipk.zip
    https://mega.nz/file/GAcm3QaZ#8o8CR6...yMTWcCBRnWzQWw
    enigma2-softcams-oscam-all-images_11.581-emu-r798-arm+mips_all.deb.zip
    https://mega.nz/file/jANmWYwA#Qn3d8o...GSd5MVi4HWwuyQ
    thanks @audi06_19
  2. #62
    Softcam Manager IPK for teamblue
    https://www.mediafire.com/file/ep67l...s32el.ipk/file
  3. #63
    Changeset 11581
    support CCCam.cfg patch by firebird
    -Add repetitions_forced option
    -This option allowed to Enable/Disable the ncam to read same Cline servers from both file (ncam.server and CCcam.cfg)
    -The default option is (enable) you can change it from webinterface of ncam (http://DeviceIP:8181/config.html) then (Repetitions forced
    -Or from ncam/config file to change value to (0)
    enigma2-plugin-softcams-oscam_11.581-emu-r798-CCCam.cfg_all.ipk
    https://mega.nz/file/2dtmUC7D#y-mdaJ...UJGZYgQaNtvjUs
  4. #64
    Fix show CCcam.cfg in menu list of other files..
    You can edit files manually direct from webinterface under:
    FILES > other files > CCcam.cfg
    https://mega.nz/file/GZcBiQYQ#ipCuyW...XQoqp_RadSv1wA
    enigma2-plugin-softcams-oscam-osdreambox.deb
    https://mega.nz/file/qENlnQ7K#8AsfCB...y285l8Cy_g3diI
    enigma2-plugin-softcams-oscam_11.581-emu-r798-CCCam.cfg_v3
    All Images_ mips_ arm_ sh4
    Add CCcam.cfg Enable/Disable option + change repetitions_forced to cc…
    1-You can Enable/Disable use CCcam.cfg from (CONFIGURATION > CCcam.cfg) Enabled is the default.
    Or you can add in (ncam.conf) file this line (1 = Enable , 0=Disable) cccam_cfg_enabled = 1
    2-About Path for CCcam.cfg: If you want to ncam read it from default config path (/etc/tuxbox/config) leave the option blank OR remove from (ncam.conf) file this line cccam_cfg_path = In this case you will see the CCcam.cfg in the list of other files on webinterface. P.s: If you change the path of CCcam.cfg to other path for example to /etc (Then you can not find CCcam.cfg option in the list of other files to edit from webinterface)
    3-About repetitions_forced change it to cccam_cfg_repetitions_forced option. So in (ncam.conf) file should be add it like this And the default of option is (0) Disable cccam_cfg_repetitions_forced = 1
    enigma2-plugin-softcams-oscam_11.581-emu-r798-CCCam.cfg-v3_all.ipk
    https://mega.nz/file/HJcFlQ5a#N2REVa..._vSjLfKn_MU5a8
    https://mega.nz/file/mRN31IRD#pIcS4T...w0xdh6vr8G4q00
    svn11581+git1837+119cb36-r0
    ***for PLi base images
    emu798
    -[osemu] • powervu-Fixed-emm-algo
    enigma2-plugin-softcams-oscam-emu_svn11581+git1837+119cb36-r0_mips32el.ipk
    Código:
    https://mega.nz/file/OA8GQQCK#s3E6mT...gNGBPKEqsXiY_0
    enigma2-plugin-softcams-oscam-emu_svn11581+git1837+119cb36-r0_armv7ahf-neon.ipk
    https://mega.nz/file/uFsiUQAb#QPMFfQ...ztZYU97cKgvezQ
    enigma2-plugin-softcams-oscam-emu_svn11581+git1837+119cb36-r0_aarch64.ipk
    https://mega.nz/file/HItCEagL#feZRx1...Xx5mdPlV4OmLFw
    build: enigma1969 & medousa89
    support CCCam.cfg & cacheex_aio-v09.2.5 & powervu Fixed emm algo
    AFN ON
    enigma2-plugin-softcams-oscam_11.581-emu-r798-CCCam.cfg-v3-cacheex_aio-v09.2.5_all.ipk
    https://mega.nz/file/TVFCBADD#mRLpn7...OTl2CTwmwhp_ek
    https://mega.nz/file/jUckyaSK#gKjOu-...CzG7uMDg4HLPRk
    Oscam-EMU OE1.6/2.0/Fpu/PLI4.0 (DM500HD,800,7025,8000 & VU)
    Changeset 11581 with emu PowerVu fix
    [powervu] Fixed emm algo
    build juli13
    oscam-11581-mipsoe20-emu.zip
    https://mega.nz/file/GI8nWBzb#xSxLy0...Pxq0ZRE3ASjaBk
    oscam-11581-openpli40-emu.zip
    https://mega.nz/file/eUlXVDra#vnFAgz...u30BijDx739rSw
    Oscam Arm DM900/920UHD/VU4K
    build juli13
    oscam-11581-arm_dream-emu.zip
    https://mega.nz/file/7QcX1QIL#ZuuXdg...dmV6Yqq23NLKbc
  5. #65
    enigma2-plugin-softcams-oscam_11.582-emu-r798
    [gbx]
    -repeat to ask all gbox readers again during fallback time
    thx to @chimpie232 for providing the patch
    enigma2-plugin-softcams-oscam_11.582-emu-r798-ipk.rar
    https://mega.nz/file/TVlBTSjI#_BrjPV...HXJE7ieiz6K3GI
    enigma2-plugin-softcams-oscam_11.582-emu-r798-deb.rar
    https://mega.nz/file/WF0XEITC#YT4ujZ...BmC7f29fwDThWM
  6. #66
    Black Hole OSCam 11.582-r798
    Black Hole OSCam 11.582-r798 mips.zip
    https://mega.nz/file/yd1FDZZL#kwoc4j...g5HB4dK9mKkmgQ
    Black Hole OSCam 11.582-r798 ARM.zip
    https://mega.nz/file/2N91HZLS#ivMZOY...RQ3QruFqOL6lic
  7. #67
    Oscam-emu for gx chip
    -For all gx boxes
    change log oscam-emu:
    Thanks the Edision and OScam developers
    Unzip and upload in folder /home/gx/local/oscam/ with executable rights.(755)
    build : .:MadMax:. & medousa89
    https://www.mediafire.com/file/sceyo...MMfix.zip/file
    Keydata.bin for MCAS app
    New keys
    Discovery Europe - 4.8E - 12322 V 27500
    https://www.mediafire.com/file/oo04u...ydata.zip/file
  8. #68
    Softcam & MR keys Update kargo.25 (01-08-2020)
    * Bulsatcom (0604/0000) Irdeto2 New Key 04 (39.0°E) ->12214 V 30000 7/8 & 12271 H & 12482 V 30000 7/8
    * MBC HD Feed (2600/1FFF) Biss New Key (21.6°E) ->11564 V 3333 5/6 (MPEG-4/HD)
    * SRTV Feed (2600/1FFF) Biss New Key (16.0°E) ->12643 V 27500 2/3 (MPEG-4)
    * SISLink (0E00/0000) PowerVU Active Key 01 (4.8°E) ->12149 & 12418 H 27500 3/4
    * Discovery Networks (0E00/0000) PowerVU Next Key 01 (4.8°E) ->12322 V 27500 5/6 (MPEG-4)
    * All Keys Full Updated...
    https://www.mediafire.com/file/08tek...-2020.zip/file
  9. #69
    Oscam r11583 DM9x0 / Vu+ 4K Patch cx aio v9.2.4
    https://www.mediafire.com/file/zf1ho...9.2.4.zip/file
  10. #70
    enigma2-plugin-softcams-oscam_11.583-emu-r798
    Commit patch that fixes some URL's from ticket #4800
    enigma2-plugin-softcams-oscam_11.583-emu-r798_all.ipk.rar
    https://mega.nz/file/vRVCEIpS#PYIVOQ...bPa2wPxJOf8_wM
    enigma2-plugin-softcams-oscam_11.583-emu-r798_all.deb.rar
    https://mega.nz/file/zQNmDSZK#cM1arA...xO3JHV20UNznJE
  11. #71
    DreamOSat keyUpdater SoftCam.Key plugins(oscam,wicard,powervu,tandberg,biss)
    Version 2.7
    Citar
    - Updete the plugin
    - Add support python3
    - Fix some bugs
    - Language support added
    Now fully compatible with python 2.7 and python 3
    enigma2-plugin-extensions-dreamosat-keyupdater_20200808-r2.7_all.ipk.rar
    https://mega.nz/file/Wd9DgCJI#4okuDq...N0dfvDf0RrDJ70
    enigma2-plugin-extensions-dreamosat-keyupdater_20200808-r2.7_all.deb.rar
    https://mega.nz/file/DMlXmKgY#KdHWXX...S2v-xrI10z3dHQ
    thanks audi06_19
    AddKey plugin V3.9
    Citar
    -Update
    Command to install last version
    wget http://tunisia-dreambox.info/TSplugi...y/installer.sh -O - | /bin/sh
    or manually using the attach file
    cd /tmp
    tar -xzf AddKey-V3.9.tar.gz -C /
    AddKey-3.9.tar.gz
    https://mega.nz/file/PF9RwAwS#oTwttv...qANnxWngPulccI
    oscamsvn 11583-emu-arm-mips-sh-_hard
    oscam-svn11583-arm_dream-webif-dvbapi-libusb-emu798
    oscam-svn11583-dreambox_fpu-webif-dvbapi-libusb-emu798
    oscam-svn11583-dream_one-webif-dvbapi-libusb-emu798
    oscam-svn11583-hd51-webif-dvbapi-libusb-emu798
    oscam-svn11583-openpli40-webif-dvbapi-libusb-emu798
    oscam-svn11583-osmio4k-webif-dvbapi-libusb-emu798
    oscam-svn11583-rasb_hard-webif-dvbapi-libusb-emu798
    oscam-svn11583-sh4-webif-dvbapi-libusb-emu798
    oscam-svn11583-solo4k-webif-dvbapi-libusb-emu798
    oscamsvn11583-emu-arm-mips-sh-rasb_hard.zip
    https://mega.nz/file/fUsDkLKa#i58rC4...nI3tKFXEsYYJZs
    thanks @Levi45
  12. #72
    OSCam 11.584-r0 emu r798
    @audi06_19
    11584
    small fix for CAK7 Cards HD03/04/05
    refresh valid to date
    -the recommendation remains to enable shared and disable global emm
    enigma2-softcams-oscam-all-images_11.584-emu-r798-arm+mips_all.ipk.zip
    https://mega.nz/file/Pc1BHSzL#1ggXYj...9pQ-vtUVEDDrKE
    enigma2-softcams-oscam-all-images_11.584-emu-r798-arm+mips_all.deb.zip
    https://mega.nz/file/2FlnBCyA#jBpAIs...XW1EiPt18qevYg
    thanks audi06_19
    enigma2-plugin-softcams-oscam_11.589-emu-r798_all
    Changeset 11589
    Message: restore config.h to 11580
    Changeset 11588
    Message: redo fixed version
    Changeset 11587
    Message: w33dburn buildfix
    enigma2-plugin-softcams-oscam_11.589-emu-r798_all.ipk.zip
    https://mega.nz/file/mZ9DzTAB#PhK2xv...Fk-pdOBz4gDiI4
    enigma2-plugin-softcams-oscam_11.589-emu-r798_deb.zip
    https://mega.nz/file/eUlhBBYK#5_XPu5...o8Warmex7hraMU
  13. #73
    enigma2-plugin-softcams-oscam_11.590-emu-r798_all
    update wiki links
    enigma2-plugin-softcams-oscam_11.590-emu-r798_IPK.zip
    https://mega.nz/file/WUUGWAIS#pOfHXK...FCSyg0-FgLQufA
    enigma2-plugin-softcams-oscam_11.590-emu-r798_DEB.zip
    https://mega.nz/file/WNVkGAgJ#XEorZf...EXM9tvs3x_xJ3g
    Oscam emu for Amiko A3/A4/A5
    http://www.mediafire.com/file/ymyxt0...ibusb.zip/file
    http://www.mediafire.com/file/fwbvln...ibusb.zip/file
    http://www.mediafire.com/file/hy3x0j...ibusb.zip/file
    Oscam Emu binary Wetek Play 2 (Android)
    Oscam 11590 emu798
    http://www.mediafire.com/file/5leql1...ibusb.zip/file
    Oscam-EMU Mipsel (DM500HD,800,7025,8000 & VU)
    Changeset 11590 with emu
    update wiki links
    build juli13
    http://www.mediafire.com/file/6q1w0f...0-emu.zip/file
    http://www.mediafire.com/file/a3lnhe...0-emu.zip/file
    OScam/EMU Arm DM900/920UHD/VU4K
    Changeset 11590
    update wiki links
    build juli13
    http://www.mediafire.com/file/y1sjll...dream.zip/file
    http://www.mediafire.com/file/il31m6...m-emu.zip/file
    Oscam Mipsel (DM500HD,800,7025,8000 & VU)
    Changeset 11590
    update wiki links
    build juli13
    http://www.mediafire.com/file/ytobun...soe20.zip/file
    http://www.mediafire.com/file/prrhd7...pli40.zip/file
    Satlodge OScam_Emu
    Oscam-emu-satlodge team.11589-patch798
    enjoy your satlodge team
    http://www.mediafire.com/file/pmp1e0...lodge.zip/file
    http://www.mediafire.com/file/qzytg4...lodge.zip/file
    http://www.mediafire.com/file/iz0840...98-zg.zip/file
    http://www.mediafire.com/file/z1p34p...lodge.zip/file
  14. #74
    Lastest softcm key by Kargo.25
    Softcam & MR keys Update kargo.25 (30-08-2020)
    *TNTSat France (0500/030B00) Viaccess4 Keys (19.2°E) ->11817/11856/11895/12168/12207/12402 V 29700 & 12551/12728 V 22000 2/3
    *Tajik Package (2600/1FFF) Biss Keys (57.0°E) ->10973 H 11700 2/3(MPEG-4)
    Football HD
    TV Khatlon
    TV Badakhshon
    TV Kulob
    *HNL Feed (2600/1FFF) Biss New Key (16.0°E)->10721 H 30000 3/4 (MPEG-4)
    http://www.mediafire.com/file/mni0oi...-2020.zip/file
    Technomate Softcam by kobenan27
    28.06.2016
    For Technomates Series 1000, 3000, 5200, 5300, 5400, 5600, 6800, 6900 7100 and Super
    http://www.mediafire.com/file/uid72m...ftcam.rar/file
    Softcam for Clarke-Tech by kargo.25
    (softcam clarke-tech Normal and Plus usb BY kargo.25)
    28.08.2020
    >TNTSat Fix (19.2E)<
    >Bulsatcom 39 east new key<
    http://www.mediafire.com/file/a03h5y...-2020.rar/file
    OSCam Aarch64 Binaries for Edision Os Mio4K & Mio Plus4k
    OE2.0, ARM/Aarch64 Binaries for
    # Edision OS: (Mio 4K)
    oscam-svn-lates_version-aarch64_osmino4k-webif-dvbapi-libusb-emu-upx.tar.gz
    @audi06_19
    http://www.mediafire.com/file/jx8lje...98.tar.gz/file
  15. #75
    Oscam Emu All images Ipk & Deb
    OSCam 11.595-r0 emu r798
    @audi06_19
    11595
    -fix for reset readerstats @webif thnx to uf2k
    -fix for client send cmd 0x50 after server restart
    -fix client au + client auth
    enigma2-softcams-oscam-all-images_11.595-emu-r798-arm+mips_all.ipk
    https://mega.nz/file/rE1HFDqY#Ctntfm...jkTx5COQBQSv9o
    enigma2-softcams-oscam-all-images_11.595-emu-r798-arm+mips_all.deb
    https://mega.nz/file/aBkzHbab#VQibq1...AMp0hi4lNSOuNs
    perfect oscam (patch)
    New patch with redesigned hidecards acocs, this is for 11595
    Build: MOHAMED_OS
    enigma2-plugin-softcams-oscam_11.595-emu-r798_all.ipk
    https://mega.nz/file/zVkCzYTY#JGoB3y...m-XS6PfJCEjVjs
    enigma2-plugin-softcams-oscam-osdreambox (1).deb
    https://mega.nz/file/2Q8CmShL#2iRGhR...8L2bPpXx6JVia0
    Oscam_Ver 11595 with emu
    That build works on every mipsel image, it has libcrypto inside, so you do not need specific libcrypto in your image.
    build juli13
    http://www.mediafire.com/file/i96v5k...c_lib.zip/file
    -For all gx boxes
    http://www.mediafire.com/file/v9ae3w...5-798.zip/file
    Softcam & MR keys Update kargo.25 (04-09-2020)
    *MBC HD Feed (2600/1FFF) Biss New Key (21.6°E) ->11564 V 3333 5/6 (MPEG-4/HD)
    * SISLink (0E00/0000) PowerVU Active Key 00 (4.8°E) ->12149 & 12418 H 27500 3/4
    *Discovery Networks (0E00/0000) PowerVU Next Key 00 (4.8°E) ->12322 V 27500 5/6 (MPEG-4)
    *Discovery Networks (0E00/0000) PowerVU Next Key 01 (4.8°E) ->12360 V 27500 5/6 (MPEG-4)
    * Discovery Networks Europe (0E00/0000) PowerVU Next Key 01 (0.8°W) ->12303 V 27500 5/6 (MPEG-4)
    http://www.mediafire.com/file/5zavbv...-2020.zip/file
    The LATEST OSCAM-EMU FOR VARIOUS PLATFORMS
    OE2.6, ARM/Aarch64 Binaries for
    # DreamOS: ( dream-one UHD 4K) Dreambox >
    oscam-svn-lates_version-aarch64_dream_one-webif-dvbapi-ssl-emu-upx.tar.gz
    OE2.5, ARM Binaries for
    # DreamOS: ( dm9x0 4K) Dreambox >
    oscam-svn-lates_version-arm_dream-webif-dvbapi-ssl-emu-upx.tar.gz
    Binar OpenSSL version: 1.0.2r
    @audi06_19
    http://www.mediafire.com/file/2u18aa...98.tar.gz/file
    http://www.mediafire.com/file/zqp679...98.tar.gz/file
    @audi06_19
    http://www.mediafire.com/file/ogy7gx...98.tar.gz/file
    Changeset 11595
    thanks to w33dburner
    build juli13
    http://www.mediafire.com/file/obkfws...dream.zip/file
    http://www.mediafire.com/file/3tybmw...m-emu.zip/file
    Changeset 11595
    build juli13
    http://www.mediafire.com/file/eyhi6u...soe20.zip/file
    http://www.mediafire.com/file/eyb1is...pli40.zip/file
    New keys
    Discovery Networks - 4.8E- 12360 V 27500
    Discovery Networks - 0.8°W- 12303 V 27500
    http://www.mediafire.com/file/buka7e...ydata.zip/file
