Results 1 to 5 of 5
Thread: Subtitle Player 3.05
    Default Subtitle Player 3.05
    New in version 3.05:
    •Added support for 3D (you can use it on 3D movies)
    •Plugins skin is separated, and now you have the option to modify it
    •Skin is now no longer loaded with enigma but only when starting the plugin (RAM less load )
    •Unrar, *. pyo and *. pyc files are included in ipk installation file
    •Additional sync FPS improvement
    •Net fix (no more problems with the boot if you are missing the internet)
    Attached Files Attached Files
    05 Feb 2007
    merge perfect . Multumim tutror celor din echipa RSP. Acuma pentru mine cel putin imaginea a devenit suficient de perfecta
    tks to all
    06 Mar 2007
    BUNESTI-VL
    Default plugin
    salut
    cum se instaleaza acest plugin, ca am incercat in mai multe moduri si nu am reusit
    multumesc
    dolce, focus,digi, DM500s, dm7000, amiko shd-8900 alien, opticum 7300CI2CX, opticum 4100TSCR, opticum 4100C, srt6355, antena 1.2Al, lnb gold quatro twin0.2, H-H strong DM2100, MREV. 2.25, SS2
    23 Apr 2007
    P3X-888
    Desfaci zip-ul apoi cu ajutorul unui client FTP copiezi ipk-ul:
    ( enigma2-plugin-extensions-subtitleplayer_3.05_sh4.ipk ) in receptor in /tmp.
    Deschizi o sesiune telnet catre receptor, te loghezi si dai comanda:
     ipkg install /tmp/enigma2-plugin-extensions-subtitleplayer_3.05_sh4.ipk
    dupa instalare dai o noua comanda:
     rm /tmp/enigma2-plugin-extensions-subtitleplayer_3.05_sh4.ipk
    pentru a sterge fisierul din /tmp apoi restart gui din meniul receptorului si ai noul plugin instalat .
    bafta
    05 Feb 2007
    merge si direct du DCC >>>>Tools> ipkg install (faci un upload fisier si gata)
