Thanks Thanks:  27
Likes Likes:  27
Results 31 to 45 of 83
Thread: Oscam - setari deosebite
    叛徒 kosar's Avatar
    25 Feb 2013
    覆盆子灌木
    Am uitat sa mentionez ca merge cu:
    PMT Mode: 6
    pe ultima imagine RSP !
    Exista si alte versiuni compilate cu pmt mode 6 sa functioneze ?
    ---------- Post added at 17:47 ---------- Previous post was at 17:27 ----------
    Am gasit versiunea cu pmtmode 6.
    16 Dec 2012
    Buna Baietii.Am nevoie de sfaturile voastre in setarea oscamului.Am un alien1 pe care ruleaza oscam cu doua linii C.Problema este urmatoarea pe una din linii primesc focus in hop 1 si merge ok pe cea dea doua imi vine in hop 2 si doar ma incurca ca intra peste si blocheaza.Intrebare? Ce setari sa fac si unde anume sa pot bloca caid 0b02 doar pe cea dea doua linie care este hop 2 si sa-mi mearga de pe prima linie, ca nu reusesc sa-i dau de cap deloc?Multumesc
    services...varianta pe caid nu e indicata pentru tine
    16 Dec 2012
    Ok si ce sa-i fac la services ca le am trecute acolo?
    ---------- Post added at 17:53 ---------- Previous post was at 17:52 ----------
    Spune-mi cum pot rezolva?
    pui pe ignore..!(cum ai tu trecut la focus)
    16 Dec 2012
    dvb api P: 0604:000000
    P: 0629:000000
    P: 0602:000000
    P: 4AE1:000000
    P: 0100:00A821
    P: 0100:00A825
    P: 0100:003311
    P: 0100:003315
    P: 0100:003317
    P: 0100:000068
    P: 0100:00006a
    P: 0100:004106
    P: 0500:042800
    P: 0500:041700
    P: 0500:042700
    P: 0500:032830
    P: 0500:043800
    P: 1722:000000
    P: 1803:000000
    P: 1833:000000
    P: 1834:000000
    P: 1861:000000
    P: 1810:000000
    I: 1802:000000
    P: 183D:005411
    I: 1815:000000
    I: 0919:000000
    I: 093B:000000
    P: 09CD:000000
    P: 1702:000000
    P: 098C:000000
    P: 09C4:000000
    P: 09C7:000000
    P: 09AF:000000
    P: 0963:000000
    P: 0960:000000
    P: 093E:000000
    P: 090F:000000
    P: 0BAA:000000
    P: 0B02:000000
    P: 0B02:000000
    P: 0D97:000000
    P: 0B00:000000
    P: 0B01:000000
    P: 0D02:000000
    P: 0D03:000000
    P: 0D05:000010
    I: 0100:000030
    I: 0B00:000000:1006
    I: 0B00:000000:106A
    P: 0B02:000000:1006
    P: 0B02:000000:106A
    #M: 1880:000000 1880:002111
    P: 1880:000000 # Digi N4
    #M: 1802:000000 1802:002111 services [focussat]
    caid=0b02
    provid = 000000
    srvid = 00CB,00CC,01F5,01F9,01FC,01FD,01FE,01FF,03EF,03F6,03F7,03F8,0B60,77ED,77EE,77F6,77F7,7853,7856,7858, 785E,78B8,7855,78BD,7797,77F5,78BC,78C2,76D0,772C,0B77,0EDE,1006,106A,12C5,791F,7920,03EC,03F1,03F3, 03F4,0407,040A,040B,040D,040E,040F,0410,0411,0412,041D,041E,041F,0029,03EB,03ED,03EE,03F5,0648,0726, 76C2,76C3,76C4,76C5,76C6,76C7,76C8,76C9,76CA,76CB,76CC,76CD,7725,7726,7727,7728,7729,772A,772B,772D, 772E,7730,7731,7733,7789,778A,778B,778C,778E,7791,7792,7793,7794,7795,77FA,7857,785B,785F,78B5,78BA, 78C3
    asta ai tu in dvb.api????
    man treci pe 3C...cccam
    iar a doua la mana sterge naiba lini aaia a doua daca focusu se blocheaza....e de tot rahatu
    30 Mar 2007
    Bun sfat da, sa treaca pe 3c ... , poate compilezi tu 3c pentru Alien si o dai la toti.
    iaca ca sa vezi am gresit...eu i as da si un alt sfat,sa cumpere alt receptor daca tot vrem sa facem ceva
    16 Dec 2012
    La multi ani si multumesc pentru ironii "meseriasilor"
    17 Nov 2008
    ALBA
    Quote Originally Posted by iannys View Post
    Cred ca cea mai buna setare este la loadbalancer setezi pe 1 atunci se fac cereri de pe readerul cel mai rapid.
    aloooo meseriasu,cine ti a raspuns TI-E cu ironii????
    deocamdata scriam eu cu ovidiu si nu erai cam deloc implicat
    revenind ontopic,pai daca tu stai cu un asemenea dvb.api eu nu mai am cuvinte si ti am dat 3 sfaturi,nici macar untr un config default oscam api nu scrie ce ai tu prin dvb,api,le ai pus tu sau ti le a pus altu??
    1.in cazu de fata cu un api asa grozav si fara cunostinte elemetare despre oscam te am intrumad spre 3c ca e mai simplu,insa am uitat ca esti pe alien
    2.cumpara alt receptor pe care sa te poti juca cu mai multe emulatoare
    3.sterge linia aia cu focusu din hop 2,de ce?ptr ca daca focusu in hop 2 iti blocheaza sau iti face freez e de toata jena,adica e fake(facatura,reprodusa,cum vrei tu sa i zici)sau macar blocheaza caidu de focus
    la 17 posturi cu un join date recent si cu 2 linii in alien tind sa cred ca esti client pay
    un an nou bun sa fie
    Changeset 9184
    In constcw module, we are now supporting the standard format again which is CAID:PROVIDER:SID:PMTPID:ECMPID::CW.
    For Enigma2 receivers, we are parsing the PMTPid so that the standard files should work correctly even for problematic channels which only differ by PMTPid.
    For other receivers which don't provide the PMTPid and thus have it set to 0000 (or if PMTPid would not be enough to distinguish), there is an extended format for constcw where you can put the VPID inside (you can obtain it from OSCam log). However, this should only be used for problematic channels and not for the majority.
    The extended (OSCam-specific) format is: CAID:PROVIDER:SID:PMTPID:ECMPID:VPID:CW.
    07 Sep 2013
    https://t.me/blackhatshiller
    Default Austar (caid 0604)+ tweak keys
    [reader]
    label                         = austar
    enable                        = 1
    protocol                      = internal
    device                        = /dev/sci0
    services                      =
    caid                          = 0604
    tk0                           = 8DEC1C9BDF0A497B
    tk1                           = 4C96976BB2B88CB4
    rsakey                        = 00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    detect                        = cd
    mhz                           = 600
    cardmhz                       = 600
    ident                         = 0604:000000
    group                         = 1
    emmcache                      = 1,1,2
    blockemm-g                    = 1
    lb_weight                     = 100
    auprovid                      = 000604
    07 Sep 2013
    Default TNTSAT si HD+
    [reader]
    label                         = tntsat
    protocol                      = internal
    device                        = /dev/sci0
    services                      = csatsd
    caid                          = 0500
    detect                        = cd
    mhz                           = 500
    ident                         = 0500:030B00
    aeskeys                       = 0500@030B00:0,0,0,0,0,0,0,0,0,0,0,0,0,2504B382B16D8C6758DB960E311E9351
    group                         = 1
    lb_weight                     = 1000
    cccreshare                    = 1
    [reader]
    label                         = hdplus
    enable                        = 1
    protocol                      = internal
    device                        = /dev/sci0
    services                      =
    fallback                      = 1
    caid                          = 1843
    rsakey                        = 84A5C9E066B9B19FD8C5E0FC2337176B8BE536287A718F4DBB6E9C1C35CA0ADEA1B1C059B0BEB1BAB9A5CE4BE5A5F9E07CCDBE2FA931DBACD602A8895EBFF777
    boxkey                        = 061D895574AED2B0
    detect                        = cd
    mhz                           = 500
    cardmhz                       = 500
    ident                         =
    group                         = 1
    emmcache                      = 1,1,2
    ecmcache                      = 1
    lb_weight                     = 100
    .....secretosilor
    ---------- Post added at 14:38 ---------- Previous post was at 14:33 ----------
    [reader]
    label                         = ctecka
    enable                        = 1
    protocol                      = internal
    device                        = /dev/sci0
    device_out_endpoint           = 0x 0  wtf???
    key                           =
    password                      =
    pincode                       = none
    readnano                      =
    services                      =
    smargopatch                   = 0
    showcls                       = 10
    fallback                      = 0
    logport                       = 0
    caid                          =
    boxid                         =
    fix9993                       = 0
    rsakey                        =
    force_irdeto                  = 0
    boxkey                        =
    atr                           =
    ecmwhitelist                  =
    detect                        = cd
    nagra_read                    = 0
    mhz                           = 500
    cardmhz                       = 0
    ident                         =
    chid                          =
    aeskeys                       =
    showcls                       = 10
    group                         = 1
    emmcache                      = 1,5,2
    blockemm-unknown              = 0
    blockemm-u                    = 0
    blockemm-s                    = 0
    blockemm-g                    = 0
    lb_weight                     = 100
    savenano                      =
    blocknano                     =
    deprecated                    = 0
    audisabled                    = 0
    auprovid                      =
    ndsversion                    = 0
    ratelimitecm                  = 0
    ratelimitseconds              = 0
