BlackHole Vu+ Duo v. 1.5 Multituner
WHAT'S NEW?
NEW NEW NEW: Dual Usb - Tuner support !!
Black Hole image is the first enigma2 firmware that support two usb tuner.
Black Hole image support:
- Single Usb stick dual tuner
- Two Usb Tuner sticks same model
-Two Usb Tuner sticks different models
WARNING:
The new 1.5 series Black Hole images skins are not compatible with above skin versions
WARNING:
- Integrated OpenEpg
Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Addon Download Manager (Manager for package downloading)
Crediits
Thanks to bigroma (vuplus-community board) for rt3070 patches.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
BlackHole-1.5-bm750_nfi
BlackHole-1.5-bm750_usb
Dislikes:
