BlackHole Vu+ Uno v. 1.5 Multituner
WHAT'S NEW?
Vu+ Uno drivers: 20110407
NEW NEW NEW: Dual Usb - Tuner support !!
Black Hole image is the first enigma2 firmware that support two usb tuner.
Black Hole image support:
- Single Usb stick dual tuner
- Two Usb Tuner sticks same model
-Two Usb Tuner sticks different models
WARNING:
The shots of this presentation are from a special Vu+ Uno prototype with two P&P tuners. But the normal production box will have one P&P tuner only.
WARNING:
The new 1.5 series Black Hole images skins are not compatible with above skin versions
Vu+ uno drivers History:
20110322
- Change file name
20110325
- Fix vtuner problem
20110327
- Fix DiseqC problem
- Clean & speed up frontend driver(DVB-S2)
- Set chipset info at /proc, which is 7405 with 3D
- Fix vumodel info
20110404
- Clean & speed up DVB-T/C driver
- Fix DVB-T/C detection problem(e2 booting problem)
- Remove debug log
- Fix VHF tuning problem(DVB-T)
- Fix SNR/AGC display(DVB-T/C)
- Fix DVB-S2 tuning problem(occurred only in some channels)
20110407
- Fix no audio problem at radio channel
- Fix AGC in DVB-S
- Change remote control type to advanced(Needs a config.misc.rcused=0 at
/etc/enigma2/settings)
- Change the model name(Reinstall of some plug-ins are needed)
- Fix BER problem(positioner plugin)
- Remove static udev devices(Needs a new image)
