Page 2 of 8 FirstFirst 123456 ... LastLast
Results 16 to 30 of 119
Thread: Compilare oscam
    dMd
    Guest
    Default oscam-easy-build.v1.0.1e
    v.1.0.1.a
    - build fix
    (please del also all in /Patches, than 1-y-y-)
    v.1.0.1b
    - fix 3-build all
    - fix fonera showbuild on/off
    v.1.0.1c
    - fix internal-CR-support for mipsel+ppc+sh4, thx gfto
    (not needed for activating by osd, it will auto do it!)
    v.1.0.1d
    - hd+ turnout fix, thx irata
    v.1.0.1e
    - update to new oscam/streamboard url
    (please start make.sh in new empty folder, otherway it wont work!)
    Attached Files Attached Files
    Am gasit un alt script, poate mai simplu de utilizat si am trecut pe el
    Stie urmatoarele:
    supported platforms
    -native if compiler installed x86 x64 arm (dockstar)
    -dbox2, dreambox 500,500-S
    -dreambox 600,000,7020
    -dreambox 500HD,800,800se,8000,7025
    -openembedded 2.0 + new toolchain (gcc4.7 64bit build)
    -fritzbox 33XX
    -fritzbox 72XX
    -fritzbox 73XX
    -raspberry pi hard fpu
    -raspberry pi soft fpu
    -powerpc
    -dockstar
    -coolstream
    -sh4
    -sh_4 (new toolchain gcc 4.6.3 64bit build)
    -tplink (1043ND)
    -fonera
    -ddwrt 2.4
    -ddwrt 2.6
    -openwrt 3.4.6
    -openwrt 4.1.0
    -arm nslu2 unslug
    -arm nslu2 openwrt
    simplebuild 1.07
    IMPORTANT
    MUST INSTALL THIS PACKAGES BY HAND
    1. dialog
    2. uni2ascii
    3. xz-utils
    4. subversion
    5. awk gawk or mawk (gawk is debian default)
    6. lib32z1 (for 64bit)
      NATIVE
    7. libusb-dev for libusb support
    8. libssl-dev for ssl support
    cd /opt
    mkdir simplebuild
    cd simplebuild
    wget http://ss4200.homelinux.com/oscam/simplebuild
    chmod 777 simplebuild
    ./simplebuild checksys
    ./simplebuild menu
    Daca apare o versiune noua de script te anunta la pornire si poti face update, descarca oscam ultimul/versiune aleasa, meniuri simple si intuitive, viteza sporita la compilare
    Tnx @ Gorgone (Streamboardler )
    Se poate actualiza din script sau
    simplebuild 1.16
    -fix typo
    simplebuild 1.15
    -size check changet
    simplebuild 1.14
    -SVN online check changet
    simplebuild 1.13
    -adding a little bit fun for the console users (bouncing wait coursor on build)
    simplebuild 1.12
    -fix build sh4 with nostapi (thanks basta2k for report)
    simplebuild 1.11
    -add local remote compare to skipp checkout if equal (menu version)
    -change internal script structure with separate departments
    simplebuild 1.10
    -tryfix relinking lib path
    simplebuild 1.09
    -openwrt26 ddwrt410 reactivated
    -small fixes on commandline mode
    simplebuild 1.08
    -extended "./simplebuild checksys" now all packages
    simplebuild 1.17
    -try fix relink paths in console build (latte0815 reported)
    Download
    simplebuild 1.26
    please clear the toolchains/config/* if u have some trouble
    -config.extra used by default
    -pcsc console enable
    -extra custom_suffix used on console and pack
    -fixed directmenu="1" start with ./simplebuild menu
    -set back to default on empty custom_suffix
    -new console commands (if u have enabled on extra u can now disable on console)
    1. dvbapi_on dvbapi_off
    2. static_on static_off
    3. stapi_on stapi_off
    4. pcsc_on pcsc_off
    5. usb_on usb_off
    6. ssl_on ssl_off
    7. pack_on pack_off
    La adresa:
    instructiuni si sursa de la simplebuild
    s-a ajuns la 1.32
    simplebuild 1.33
    -add Synology Marvell 88F628x Toolchain with usb ssl pcsc and static support
    -oscam-svn url now in var editable for using mirrors
    -delete oscam-svn (urlchange to .tv)
    simplebuild 1.34
    -add TOUCH WEBIF (console support later)
    rm -rf toolchains/configs
    simplebuild 1.35
    -console checkout extension with revnumber (first try)
    ./simplebuild checkout 7123
    simplebuild 1.36
    -add MODULE_CCCSHARE (console support later sorry no time now)
    work with saved !
    first of all; if u have problems, begin with a empty directory and simplebuild script only
    CROSS COMPILE ONLY WITH x64 or x86
    Again, thanks Gorgone (Streamboardler )
    simplebuild 1.38
    -first try to fix ./simplebuild debinstall
    (this installs all needet packages i think)
    -another bugfix prepare for the new releases
    sper ca sa rezolvat problema de compilare ptr dm500
    cel putin eu nu am reusit deloc sa fac ptr dm500 cu 1.36
    Cu 1.36 am compilat eu de 2 ori pentru cineva de aici. Si i-au mers ambele...
    Poate nu ti-a mers:
    DOWNGRADE PACKS FOR PPC-OLD / DBOX2
    ppcold-ssl-0.9.8 ppcold-ssl-0.9.7
    just replace the files in the toolchain
    ppcold e pentru dm 500
    am facut si eu la inceput pe urma incepand cu vers 7688 parca nu a mai mers nimic..naiba stie
    vad ca si acum cu 1.38 sta sa ia toolchain ptr dm500 de vreo 10 min
    reinstalat de vreo cateva ori..nimic
    doar la 500 am problema asta..in rest ok
    pfff
    greu dar a mers pana la urma..vreo 15 min..
    simplebuild 1.41
    -allways menu remove
    -begin with
    ./simplebuild  reset_all
    -now all packages buildable on 32bit and 64bit
    -removed uni2ascii
    -replaced ppc-tuxbox-old now with ssl 0.9.7
    -replaced sh_4 toolchain (no 64bit needet anymore)
    -rewrite simplebuild.config (please check ur own paths)
    -first try to fix ./simplebuild debinstall (missing package installer ,this installs all needet packages i think)
    -fixed typos
    PS Salvati arhiva si ce mai doriti ca sterge tot!
