Page 2 of 18 FirstFirst 12345612 ... LastLast
Results 16 to 30 of 261
Thread: e2 Alien RC1
    Member Beginner googgi's Avatar
    22 Feb 2011
    Austria
    Thanx for that - it´s looks good.
    bug-reports:
    * autoswap causes boot-freezer every 2. boot
    * hd_glass16 looks very good, but navigation in menu is tricky, jumping to next item in row is often not possible
    Amiko Alien with RSP-Image
    14 Mar 2011
    Menu->Setup->HD Glass Setup->Menu style: list
    22 Feb 2011
    Austria
    30 Mar 2011
    Slovakia
    Thumbs down
    I try power off after night, but with the same result - restarting.
    I will wait for your new version with old kernel settings.
    Thanks for your work.
    P.S.: But I don't understand, if the hardware is same, why I have this problem and the others no.
    I also try ProtoLux_v2.1 and had the problem with bootlogo version, restart during boot.
    Almelo
    when you flash de orginal fw first
    and than the RC1?
    DM800HD pvr
    T90
    Amiko Alien
    30 Mar 2011
    Slovakia
    I was trying flash Spark 1.1.35 first, then RC1 (long power off after first run), but with the same result - reboot after load modules on display. May this relate to the boot logo?
    Thanks for the next help.
    05 Feb 2007
    Super tare noul RC1 Enigma2. Este stabil , merge bine, MULTUMIM!!!!!!
    Skinul HD-Glass 16 este f. fain.
    Se poate instala si pluginul pentru subtirari DD-subt?
    Multumiri pentru munca depusa
    Am scos DD-subt pentru ca uneori nu mai pornea e2 de la el si nu am avut rabdare sa studiez problema.
    HD-Glass 16 e frumos, util pentru informatiile sale, dar mananca 10 mega de ram in plus si ceva procesor.
    Si, am uitat sa mentionez in primul post, acum subservices functioneaza pe VERDE.
    ---------- Post added at 12:18 ---------- Previous post was at 11:48 ----------
    Am mai uitat si FLAC in media player, si multe altele adaugate in ultima luna.
    10 Apr 2011
    Tanks i tested this versión anr report Log
    Am uitat sa mentionez ca nu se mai poate face inregistare accidental in flash, nici timeshift.
    Sunt implicit dezactivate la boot pentru ca accidental se putea face recording in flash!
    Pentru inregistrari trebuie sa stiti urmatoarele:
    - se poate inregistra doar pe partitii EXT2, EXT3 si FAT32 (cu limitare la 2Giga a unui fisier la FAT32)
    - Daca partitia pe care inregistrati are LABEL = RECORD e montata automat la boot.
    - O alta metoda este sa creati un director movie pe prima partitie !
    ---------- Post added at 16:32 ---------- Previous post was at 15:17 ----------
    I forgot to mention that accidental recording in flash or timeshift recording start is no longer possible.
    These are now disabled by default on boot.
    To be able to use recording function, you must know the following:
    - can be done only on EXT2, EXT3 and FAT32 partitions (with 2GB file limit applied on FAT32).
    - If the recording partition is labeled RECORD it will be mounted on boot.
    - Another method is to create a folder named movie on your first partition.
    14 Mar 2011
    Default cifs
    How to connect network hdd (cifs)? (timeshift,record)
    Standard RSP member spiry's Avatar
    15 Apr 2009
    bukowinen
    Default card conax
    cine a testat,stiti ceva citeste cardul conax ?? exemplu pocus?? asta pentru cei care au servere cu card local?? oricum multumim maestre zildan pt munca depusa !!!
    @rudi77
    For CIFS mount:
    -enable CIFS in User options (RSP menu)
    -edit /var/config/amnt.cfg
    -restart box
    For RECORDING read previous page
    Timeshift need a lynk in image, momentan is disabled.
    @spiry
    Nu cred, inca nu am rezolvat total card readerul. Testate sunt vi@ si n@gr@
    10 Apr 2011
    Default E2 RC1 boot
    Buna,
    Dupa instalare numai "boot-loading modules", am incercat de mai multe ori dar nu merge mai departe.Variantele anterioare au mers din prima.Oare sunt diferente hardware?
    Thx
    20 Mar 2011
    Default movie folder. deleted movie.....
    I had a movie folder on my Hard disk. I copied a movie in that folder. And now all of a sudden, it is deleted. It is no longer there.
    Also the hard disk is not mounted on boot. Very anoying.
    Can you explain how to format the hard disk? So I can use the Record, time-shift, media-player and also use Swap?
    Or maybe you can make a menu item in the next image?
    Because it is not clear to me now.
