BlackHole Vu+ Duo v. 1.4.6 Multiboot
WHAT'S NEW?
- New Skin Army Curve hd
- Drivers 20110321
Based on Official image Ver 5.7
Open Embedded
- Libraries and drivers update
- Update e2 to the latest version.
- For other details, please take a loot at git log.
Duo/Solo Driver update
- Use linuxtv api dvr device instead of misc/pvr device
- Fix incorrect VFD icon display(duo)
- Fix tuning problem at channels with low symbol rate(solo)
- Fix slow trick play(time shift, ts playback)
- Increase the number of demux device
Added WiFi B/G/N USB dongle Realtek 8712 driver (list of supported devices here)
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Download NFI :
http://www.filehost.ro/1837176/Black...bm750_nfi_zip/
Download USB :
http://www.filehost.ro/1837170/Black...bm750_usb_zip/
