Results 1 to 11 of 11
Thread: PKT UFS 910/912 Enigma2 Nibiru Image
    29 Nov 2008
    Cu capu' in nori
    Default PKT UFS 910/912 Enigma2 Nibiru Image
    05/03/2011
    Image is designed for installation in USB/SATA disk
    Added by sh4 Duckbox Team:
    - new player3 179
    - [libeplayer3] fix blocking at end of file
    - [eplayer3] add mapping for ff and fr
    - [libeplayer3] fix fast reverse begin of file
    - [libeplayer3] fix audio output with fast reverse
    - [libeplayer3] fix .srt subtitle, seg fault if subtitle line is empty
    - [libeplayer3] fix reverse
    - [libeplayer3] change fast reverse to show the first frame on bof
    - [libeplayer3] fix fast reverse loops
    Added by PKT:
    - add support for FTDI & PL2303 in BP Menu
    - add EPG saving
    - add CrossEPG 0.6.1 (default off; Enable/Disable in BP->Settings->CrossEPG; main CrossEPG setup Menu->Setup->CrossEPG)
    - update WIFI driver RT3070 & RT2870
    - add RT73 WIFI support (test only - propably not work)
    - update DVDPlayer
    - add record & timeshift patch @ Main Menu->Setup
    - update InfocenterPKT
    - update PKT Emu Manager v1.02
    - update PKT Skin Setup
    - add VidBrowser to MediaCenter
    - update all PKT Skins
    - add PKT ChannelControl (new tool to adjust volume separately on selected channel)
    - add PKT_KeyMapper (new tool to mapping Color buttons):
    default keys definition:
    *short key_red=Radio
    *short key_green=Aspect Ratio
    *short key_yellow=Audio Selection
    *short key_blue=Blue Panel
    Known Issues:
    - long key don't work @UFS910
    UFS 910 :
    http://e2.pkteam.pl/index.php?dir=IM...biru_Image.zip
    UFS 912 :
    09 Jan 2010
    so far, excellent.
    12 Jan 2010
    Default Pkt ufs 910/912
    gracias, la pruebo ahora mismo (test this moment)
    Standard RSP member bliviu27's Avatar
    03 Feb 2009
    constanta
    Default un mare fissssssssss
    din pacate ecran verde cand activez oscam indiferent de versiune asa ca pt mine este o imagine inutila pe partea de media se misca binisor din pacate degeaba.
    04 Apr 2009
    ai activat driverele usb PL2303. azi am puso si eu cu ultima versiune de oscam si n-am nici o problema
    03 Feb 2009
    constanta
    Default degeaba
    am activat si driverele am incercat cu toate oscam de la panel si mgcam degeaba cand dau buton verde start/restart cam ecran verde si o eroare de genul ca nu poate aloca memorie
    imaginea e singura pe un stick de 512mb asa ca nu cred ca nu-i ajunge memoria
    04 Apr 2009
    incearca sa fii pe un program FTA cand faci asta. oricum imaginea nu prea merita...mie desi mi-a pornit oscam , se ingreuneaza groznic in doar cateva minute si ma cam omoara rotita. se invarte minute intregi. nu stiu daca e de la nr mare de linii pe care il am pt ca AAF MME2 merge binisor pana acu fata de asta.
    03 Feb 2009
    constanta
    Default da
    pe fta am incercat vroiam doar o comparatie cu ultima aaf insa m-ai convins ca nu merita aaf e peste cu mult merge cu multe linii si nu ingreuneaza ms
    katy ufs91o hd + topex premium + phoenix
    Bliviu27 vezi ca faci ceva gresit , am instalato de 2 ori si am descarcat/instalat oscam-ul din panelul lor ( la emu ) si functioneaza OK
    In schimb la ultima vers, aaf mme v2 avand doar 4 sateliti din "fabrica" am inlocuit fisierul satellite.xml cu unul gata facut si am intampinat prb. apoi
    Am impresia ca la ultima vers. aaf mme sa schimbat "scheletul" imaginii , o sa mai incerc din nou alte variante legat de prb. descrisa
    09 Jan 2010
    09 Jan 2010
