Page 3 of 16 FirstFirst 123456713 ... LastLast
Results 31 to 45 of 226
Thread: Skinuri - DREAMBOX & COMPATIBILE
    Default Re: Skinuri - DREAMBOX & COMPATIBILE
    @maximuss
    nu e rau de loc!
    12 Aug 2007
    Asta e ultimul , imi ajunge timpul pierdut . Verificat pe gemini si pli (optibox ~Dream 500)
    maximuss skin g add 260108.rar - 0.17MB
    Last edited by maximuss; 26-01-08 at 16:05. Reason: mici modificari la font si un alt link
    nu stiu de cine e facut dar eu cred ca e elegant!
    Gemini
    Test version if ok final.
    Im not sure if DM500 users will have good colors.
    I have use spec multicolor backgrounds in OSD and Menus.
    I have test only on DM7000.
    OSD Alpha is abt in center for this skin.
    ByE MX
    Unzip>>copy tar.gz to /var/tmp Install with BP
    New version with all info for Gemini image
    For info
    Both versions using the same folders and file names
    New version will overwrite old.
    If you have old version.
    After install restart dreambox.
    26.01.08
    12 Aug 2007
    Default Nabilo skin
    Am reusit sa il fac sa mearga si pe nabilo . Este la upload pus.
    Standard RSP member imeDB's Avatar
    21 Aug 2007
    pina la urma cum se editeaza un skin va rog?
    personal folosesc skinul gbl3+ptest facut de choleen si mi-ar placea sa-l adaptez pt modul smart al lcd-ului meu, adica sa micsorez distanta dintre cele 2 bare de info
    am incercat cu dss, dar mi se pare deloc intuitiv, foarte greoi, datorita faptului ca trebuie sa iau totul pe incercate
    multumesc frumos
    12 Aug 2007
    Default Skinuri - DREAMBOX & COMPATIBILE
    Pentru NABILO 0.8 (DM 500) am facut unele modificari .
    x-generation.rar - 0.09MB
    12 Aug 2007
    Si varianta ptr Gemini Project .
    x-generation gp.rar - 0.12MB
    25 Jul 2007
    Netherland
    Am reusit ,multumesc mult!
    urasc skinuri cu bare si sus si jos ... imi plac cele cu scris mic si delicat gen Xline2
    BlackMatrix X DT Gemini image
    I think only Gemini skin with all this options.
    Test all options.
    In this skin you can have Basic and Expert Infos
    Basic >> Expert Top bar you can switch ON/OFF with extra field in general attitudes
    OSD Setup.
    All info s you can switch on and off
    You have to play with settings to find OSD settings you like.
    ByE MX
    12 Aug 2007
    un skin interesant...
    E interesant,dar....de unde il dai jos?
