Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: AnyDATA ADU-510L modem pe Asus WL-500G Deluxe router
    17 Nov 2008
    ALBA
    Asta imi arata inainte sa intru in router.
    17 Nov 2008
    ALBA
    Am rezolvat pana la urma cu ajutorul lui @ TKD29 de aici ii multumesc foarte mult ! multumesc si lui @dmd !
    Si acum eu pun si rezolvarea nu ca altii dupa ce au reusit pa nu mai zic nimic pe forum.
    Romtelecom Clicknet Mobile modem: Anydata ADU-510L
    Router testat: Asus WL-500W
    Firmware: 1.9.2.7-10-USB-1.71 Koppel
    0) setati la Wan& lan connection Mode: USB (cu automaticaly get ip address yes si automaticaly get DNS yes)
    dupa care urmati exact pasii astia si va functiona. Nu conteaza in ce port usb al routerului conectati modemul:
    1) USB Connection ->
    Automatic Dial On Boot – Yes
    GPRS/EDGE/UMTS
    Apply
    2) USB Connection -> GPRS/EDGE/UMTS Config
    Zero CD Configuration -> AnyDATA ADU-500A, ADU-510A, ADU-520A
    Connect
    Apply
    3) USB Connection ->
    CDMA
    Apply
    4) USB Connection -> CDMA Config
    username: (the one from the provider)
    password: (the one from the provider)
    Connect
    Apply
    Finish
    Save And Restart
    if it does not connect after 60 seconds since reboot and in Status & Log -> System log you see in one of the last lines like this
    Jan 1 02:00:11 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jan 1 02:00:11 kernel: Vendor: AnyDATA Model: CD-ROM Rev: 1.00
    Jan 1 02:00:11 kernel: Type: CD-ROM ANSI SCSI revision: 02
    Jan 1 02:00:11 kernel: USB Mass Storage support registered.
    then you have to do the following:
    start -> run -> telnet my.router -> admin/admin
    #urmatoarele linii trebuiesc luate ca atare cu copy paste
    echo usb_modeswitch -c /tmp/ppp/zerocdconf/AnyDATA_ADU/usb_modeswitch.conf >> /usr/local/sbin/post-boot
    #acum salvam ce am facut in memoria flash a router-ului
    flashfs save && flashfs commit && flashfs enable
    #restartam
    reboot
    Sa auzim de bine!
    Moderator sorin8m's Avatar
    22 Apr 2007
    felicitari pentru rausite si pentru tutorialul facut.
