Results 1 to 12 of 12
Thread: PKT mod 1.1.1
    04 Jan 2010
    Default PKT mod 1.1.1
    A aparut mult asteptata versiune de la PKT :
    Mod is based on the image Tideglo rev 1.1.1
    change svn 415 pts
    - Added crossEPG (svn 202)
    - New EmuManager 1.02 - adding support vizacam and gbox
    - Optimization and acceleration of InfoCenterPKT
    - New version SkinSetup
    - Added FontFix in SkinSetup
    - Added plugin KeyMapper - can personalize the color keys, support for long / short press
    - Added plugin POINT Channel Controle - including Set individual volume controls for each channel
    - Fixes and cosmetic skins
    - Add SilverHD, GoldHD HDD temperature display infobar - default OFF
    - Fix detection satellite name for item 9E when the list of satellites is also the position 39E
    - Added ability to edit the recording options menu Paths HDD
    - Update Picon
    - Updated list of channels
    - Amendments EmuCamInfo
    - The permanent inclusion of the time 24 / VFD - because it was different from
    - Fixed output from TeleText'u (Teletext)
    - Other fixes performance and code optimization
    [KeyMapper - comments]
    Default, Media Player, Media Center, Permanent Clock, Channel Controle, Disabled" onmouseout="this.style.backgroundColor='#fff'">Red -> Default, Media Player, Media Center, Permanent Clock, Channel Control, Disabled
    Aspect Ratio, Screen Saver, Channel Controle, Disabled" onmouseout="this.style.backgroundColor='#fff'">Green -> Aspect Ratio, Screen Saver, Channel Control, Disabled
    Plugin Browser, Emu Manager, Skin Setup,Disabled" onmouseout="this.style.backgroundColor='#fff'">Yellow -> Plugin Browser, Emu Manager, Skin Setup, Disabled
    Blue Pane, Emu Manager, Skin Setup, Disabled" onmouseout="this.style.backgroundColor='#fff'">Blue -> Blue Pane, Emu Manager, Skin Setup, Disabled
    Each key can be assigned a separate action for the shares short / long press.
    [Controle Channel]
    Setting the call in KeyMapper by pressing red or green - depending on your preference.
    However, this version is pretty early, so not everything works including inability to set individual values for the channel Aspect Ratio.
    http://e2.pkteam.pl/index.php?dir=IM....415_usb_sata/
    2-3 cutii cu linucsi hw:mips si sh4;sw: openwrt si tidegloE2
    14 Jun 2008
    Baia Mare
    versiunea asta e bazata pe E2 rev. 1.0.0 nu pe E2 rev 1.1.1 asa cum scrie si pe site la pkt!
    Standard RSP member hydr0xygen's Avatar
    08 Sep 2010
    ìn IAD
    Default re:
    Se poate un mic ajutor la instalarea acestei imagini? am incercat sa copii fisierul tar.gz in /tmp si cu flash tools nici atat nu reusec, pentru ca ipbox 91 hd nu are serial.
    IpBox 91 HD - PkTeam Nebula v3
    Standard RSP member djczefre's Avatar
    09 Oct 2010
    Default ip box 91
    Off, da nu asa trebuie! Cauta aici topicul potrivit pt Ip boxuri , si este scisa cum trebuie intalat E2 pe ip boxuri. Daca chiar nu te descurci , cauta ma in privat.
    01 Apr 2007
    Asta cu copierea in /tmp nu o inteleg
    PKT este o imagine pentru USB
    Daca vrei sa instalezi imagini in stick_USB atunci :
    - descarci si instalezi de aici sau de aiurea
    * CreateMini_1.4 = este un utilitar pt windows care formateaza ext2 un stick_USB
    * dcce2_120 = DreamboxControlCenterEnigma2 care stie sa lucreze cu Ipbox_linux
    - formatezi ext2 un Stick_USB ( capacitate minima 512MB )
    - instalezi si configurezi dcce2
    - infigi Stick_USB in IpBox
    - din dcce2 in Telnet dai comenzile
    * umount /dev/sda1
    * mount /dev/sda1 /mnt/usb
    * mount
    - verifici ca Sticuk_USB cu partitia /sda1 sa fie montata in /mnt/usb
    - redenumesti in windows imaginea sa aiba un ume simplu , de ex.: pkt.tar.gz
    - din dcce2 cu FTP copiezi imaginea pkt.tar.gz in /mnt/usb
    - din dcce2 in Telnet te duci in directorul /mnt/usb cu comenzile
    * cd /mnt/usb
    * ls
    - dupa ce ai verificat cu comanda ls existenta fisierului pkt.tar.gz in /mnt/usb
    - dai comanda in Telnet
    * tar -xvzf pkt.tar.gz
    - dupa ce termina de lucrat Ipboxul si apare promptul in Telnet dai comanda
    * sync
    - dupa aparitia promptului opresti Ipboxul
    Acum ai instalata o imagine in Stick_USB
    Ca sa pornesti imaginea USB pornesti IpBox tinind apasata tasta numerica
    asignata in ubootul imaginii din flash pentru boot de pe /sda1
    daca ti se pare prea greu testeaza AAF-Multimedia2 in flash
    08 Sep 2010
    ìn IAD
    Multumesc, tocmai am instalat ultima versiune pt. usb de la PKT, e2PKT_1.0a_91_usb_all_noboot.img, dar acuma ma pun si cu asta. Iar imaginea de la AAF ultima pentru ipbox, din toate 4 imagini disponibile pentru acest receptor, cand dau sa o instalez de pe usb, primesc eroare E1 pe display.
    08 Sep 2010
    ìn IAD
    Am reusit sa o fac sa porneasca pana la urma PKT cu butonul 2, dar are cam 30 de minute de cand pe display scrie "tid" iar pe ecran a aparut logo'ul si clipeste un patrat. Sunt la primul boot. Mai astept putin, apoi ii dau reboot daca nu apare nimic.
