Results 1 to 4 of 4
Thread: Oscam azbox hd
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Default Oscam azbox hd
    OSCAM 1.00-unstable_svn build #4733_dvbAPI
    Version: 1.00-unstable_svn Rev. 4733/OFW
    Maxpid: UNLIMITED
    Active modules:
    Webif support:             yes
    OpenSSL support:           no
    Dvbapi support:            yes
    Dvbapi with stapi support: no
    Gbox support:              yes
    Anticasc support:          yes
    ECM doublecheck:           no
    Irdeto guessing:           yes
    Debug:                     yes
    Log history:               yes
    Monitor:                   yes
    Camd33:                    yes
    Camd35 UDP:                yes
    Camd35 TCP:                yes
    Newcamd:                   yes
    Cccam:                     yes
    Radegast:                  yes
    Serial:                    yes
    ConstCW:                   yes
    Cardreader:                yes
    Nagra:                     yes
    Irdeto:                    yes
    Conax:                     yes
    Cryptoworks:               yes
    Seca:                      yes
    Viaccess:                  yes(ttyUSB0)
    Videoguard:                yes
    Dre:                       yes
    Tongfang:                  yes
    WebIF skin's(cateva bonus ):
    /PLUGINS/OpenXCAS/oscamCAS/black.css (se schimba prin webif)
    sau
    /PLUGINS/OpenXCAS/oscamCAS/skin/black.css
    (se schimba prin FTP/restart_oscam)
    black.css, blue1.css, blue2.css, dark.css, glacier.css, harvest_round_Firefox.css,  harvest_round_Firefox_V2.css, light-blue-3d-button-style.css, light-blue-3d.css
    Instalare:
    se dezarhiveaza, se copiaza "oscamCAS" in PLUGINS/OpenXCAS/
    se da 755 la tot
    add reader, user & ENJOI
    preconfigurat (exemple!) £oKus/tv®
    webif:
    httpport                      = 808
    httpuser                      = root
    httppwd                       = azbox
    Download:
    merge excelent ca server/client/dvbapi
    26 Oct 2009
    Walachia / Paname
    Default Cron (autorestart pentru oscam)
    Autorestart OSCam
    se copiaza in: /EMU/OpenXCAS/
    chmod 755 /EMU/OpenXCAS/Cron/*
    Check_Oscam.sh
    USB Flash Disk(./DATA/usb1/sda1/):
    #!/bin/sh
    if ps x |grep -v grep |grep -c oscam ;
    then
    echo `date` "Oscam working" >> /DATA/usb1/sda1/Check_Oscam.log
    else
    echo `date` "Restarting Oscam..." >> /DATA/usb1/sda1/Check_Oscam.log
    /EMU/OpenXCAS/oscamCAS/oscam &
    fi
    HDD intern(./DATA/hdb1/):
    #!/bin/sh
    then
    echo `date` "Oscam working" >> /DATA/hdb1/Check_Oscam.log
    else
    echo `date` "Restarting Oscam..." >> /DATA/hdb1/Check_Oscam.log
    fi
    DOM (./tmp/)
    #!/bin/sh
    then
    echo `date` "Oscam working" >> /tmp/Check_Oscam.log
    else
    echo `date` "Restarting Oscam..." >> /tmp/Check_Oscam.log
    fi
    cron.tab
    SHELL=/bin/sh
    PATH=/sbin:/bin:/usr/sbin:/usr/bin
    HOME=/EMU/OpenXCAS/Cron/
    # run-parts
    */10 * * * * /EMU/OpenXCAS/Cron/Check_Oscam.sh
    ./Check_Oscam.log
    Fri Mar 4 00:14:02 UTC 2011 Restarting Oscam...
    Fri Mar 4 00:15:01 UTC 2011 Oscam working
    Fri Mar 4 00:16:02 UTC 2011 Oscam working
    Fri Mar 4 00:20:02 UTC 2011 Oscam working
    Download:
    Cron.rar
    04 Mar 2011
    Default Oscam
    Salutare,
    Poate ma ajuta cineva si pe mine; am un Azbox Elite cu un card f..sat full as vrea sa-l pun in server cu oscamul de mai sus(configurare ect.)
    Mai e nevoie de multicas sau ajunge doar oscam-ul ptr. a citi cardul de pe slotul intern?
    Setari ptr. router la dyndns.org mi-am facut; am nevoie de un partener. ptr. schimb de linii(de preferat cu ceva de la 1°W) ajutor la configurare, setare. Pingul meu e sub 30ms.
    Mersi anticipat!
    26 Oct 2009
    Walachia / Paname
    merge atat in combinatie oscam+multicas, sau doar oscam.
