Results 1 to 9 of 9
Thread: subtitle player
    11 Jan 2010
    Default subtitle player
    Stie cineva cum sa instalez subtitle player pt nabiloblackhole ?
    Golden Member Sunt_Oltean74's Avatar
    Oltenia
    Pui fisierul subtitle player in tmp dupa care tasta verde / tasta galbena si te duci la manual install ipk packges si acolo o sa gasesti subtitle player ii dai instal si dupa instalare restartezi dreamul.
    11 Jan 2010
    de o 100 am facut treaba asta,dupa ce termina i-mi arata;pacage enigma2-plugin-extensions-subtitleplayer (3.02) installed in root is up to date.Nothing to be done.Execution finished!!,dupa care il resetez si nimic,i-am dat si atribute 755
    Oltenia
    Si nu il gasesti in green panel ? Incearca sa pui subtitleplayer_2.52_
    11 Jan 2010
    aceasi problema,merci pt reply
    Standard RSP member sosozah's Avatar
    09 Mar 2008
    Default Problema asemanatoare - pe Ipbox 900
    Am avut aceeasi problema, dar nu pe dream, ci pe Ipbox 900 hd cu e2. Am rezolvat cu indicatiile date de producator - Damir - pe forumul unde e publicat pluginul.
    Code:
    Perhaps the problem is in the configuration of your ipkg.
    Try use telnet:
    copy enigma2-plugin-extensions-subtitleplayer_3.02_sh4.ipk in /tmp
    login to box from telnet
    cd /tmp
    ipkg install --force-overwrite --force-reinstall enigma2-plugin-extensions-subtitleplayer_3.02_sh4.ipk
    WBR
    DDamir
    In plus, a trebuit sa redenumesc extensiile fisierelor din *.pyo in *.pyc in folderul
    /usr/lib/enigma2/python/Plugins/Extensions/DD_Subt/
    Dupa aceasta, mi-a aparut in lista de pluginuri si a functionat brici.
    Standard RSP member messi's Avatar
    20 Apr 2008
    Aschaffenburg
    Default buna
    pentru imagine gemini pe o clona ce versiune merge ? si daca exista ceva indicatii de instalare. merci mult
    23 Apr 2008
    Bucharest West
    Slaut!
    eu pe dm500hd gemeni 5.1, am dezinstalat din telent manual 256, am pus 302, s a instlat corect, am dat reboot, dar tot nu merge..
    apar butoanele dar nu gaseste plugin..
    extensiile fisierelor sunt *.pyc in folderul
    alte idei?
    Vu+Zero4K, Offset Motor 1m
