Project:Keynation
Project: vPlug Server
Description:
vPlug Server is a Windows based CCcam Server application for using the
vPlug modules (*.mdl - written by vahid) for including them into your
card sharing network.
Many thx to vahid for his great work on his modules!
No installation is required!
Required files:
..\vPlug Server\vPlug_Server.exe # main program
..\vPlug Server\vPlug_Server.xml # configuration file
..\vPlug Server\sqlite3.dll # database module
..\vPlug Server\vModules\*.mdl # vahid's vPlug modules
..\vPlug Server\v_keys.db # vPlug key file
libeay32.dll is also required! Copy it to your Windows\system32 folder.
Use right click to open a pop up menu to enable Autostart with Windows.
Configure CCcam server options and add your user/pass.
Also add the desired card to your list with the right CAID.
If more than one ProviderID will be available seperate them with ",".
Dislikes:
