Results 16 to 30 of 45
Thread: CCcam.cfg
    dMd
    Guest
    @pGsm deschide un log de oscam si vezi daca intr-adevar ai cardul la 3,57Mhz, de obicei oscam detecteaza frecventa maxima a cardului in reader-ul intern.
    Moderator sorin8m's Avatar
    22 Apr 2007
    Diferentele de timp de deschidere difera de la o versiune la alta a OSCam-ului sau CCcam-ului, depinde ce intrebuintati.
    Trebuie facute incercari si vazut cu care versiune va merge mai bine.
  3. #18
    23 Apr 2007
    P3X-888
    sorin din testele facute de tine pe cardul focussat care a fost cel mai bun timp obtinut... eu sub 150 ms nu am obtinut testat cu cccam , oscam , sbox si newcs
  4. #19
    10 Jan 2009
    Log de la oscam
    Code:
    2011/02/02 11:59:03   1217 s   >> OSCam <<  cardserver started version 1.00, build #4654 (i686-pc-linux)
    2011/02/02 11:59:03   1217 s   version=1.00, build #4654, system=i686-pc-linux, nice=-1
    2011/02/02 11:59:03   1217 s   max. clients=509, client max. idle=120 sec
    2011/02/02 11:59:03   1217 s   max. logsize=unlimited
    2011/02/02 11:59:03   1217 s   client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
    2011/02/02 11:59:03   1217 s   shared memory initialized (size=4340106, id=131072)
    2011/02/02 11:59:03   1217 s   auth size=4772
    2011/02/02 11:59:03   1217 s   services reloaded: 0 services freed, 8 services loaded
    2011/02/02 11:59:03   1217 s   userdb reloaded: 0 accounts freed, 5 accounts loaded, 0 expired, 0 disabled
    2011/02/02 11:59:03   1217 s   signal handling initialized (type=sysv)
    2011/02/02 11:59:03   1217 s   92 service-id's loaded
    2011/02/02 11:59:03   1217 s   can't open file "/share/oscamfocus/oscam.tiers" (err=2), no tier-id's loaded
    2011/02/02 11:59:03   1217 s   1 provid's loaded
    2011/02/02 11:59:03   1217 s   monitor: initialized (fd=5, port=988)
    2011/02/02 11:59:03   1217 s   camd 3.3x: disabled
    2011/02/02 11:59:03   1217 s   camd 3.5x: disabled
    2011/02/02 11:59:03   1217 s   cs378x: disabled
    2011/02/02 11:59:03   1217 s   newcamd: initialized (fd=6, port=, crypted)
    2011/02/02 11:59:03   1217 s   CAID: 0B02
    2011/02/02 11:59:03   1217 s   provid #0: 000000
    2011/02/02 11:59:03   1217 s   cccam: disabled
    2011/02/02 11:59:03   1217 s   radegast: disabled
    2011/02/02 11:59:03   1217 s   logger started (pid=1218)
    2011/02/02 11:59:03   1217 s   http started (pid=1219)
    2011/02/02 11:59:03   1217 s   reader started (pid=1220, device=/dev/ttyUSB0, detect=cd, mhz=357, cardmhz=357)
    2011/02/02 11:59:03   1217 s   waiting for local card init
    2011/02/02 11:59:03   1219 h   HTTP Server listening on port
    2011/02/02 11:59:06   1220 r02 card detected
    2011/02/02 11:59:10   1220 r02 ATR:
    2011/02/02 11:59:13   1220 r02 Maximum frequency for this card is formally 20 Mhz, clocking it to 3.57 Mhz
    2011/02/02 11:59:14   1220 r02 type: Conax, caid: 0B02, serial:, hex serial:, card:
    2011/02/02 11:59:14   1220 r02 Providers: 1
    2011/02/02 11:59:14   1220 r02 Provider: 1  Provider-Id: 000000
    2011/02/02 11:59:14   1220 r02 Provider: 1  SharedAddress: 002B8A95
    2011/02/02 11:59:14   1220 r02 Package: 1, id: 1010, date: 2011/01/01 - 2011/01/31, name: FocusSat
    2011/02/02 11:59:14   1220 r02 Package: 2, id: 2010, date: 2011/02/01 - 2011/02/28, name: ESS
    2011/02/02 11:59:14   1220 r02 [conax-reader] ready for requests
    2011/02/02 11:59:14   1217 s   init for all local cards done
    2011/02/02 11:59:14   1217 s   anti cascading disabled
    2011/02/02 11:59:14   1217 s   dvbapi: dvbapi disabled
    2011/02/02 11:59:14   1217 s   client(1) connect from  (pid=1221, pipfd=12)
    2011/02/02 11:59:14   1221 c01 Connection closed to client
    2011/02/02 11:59:14   1217 s   client(1) connect from 127.0.0.1 (pid=1222, pipfd=12)
    2011/02/02 11:59:14   1222 c01 encrypted newcamd:-client 127.0.0.1 granted (u_focus, au=focux)
    2011/02/02 11:59:14   1222 c01 user u_focus authenticated successfully (mgcamd)
    2011/02/02 11:59:14   1222 c01 AU enabled for user u_focus on reader focux
    2011/02/02 11:59:20   1217 s   client(2) connect from  (pid=1223, pipfd=13)
    2011/02/02 11:59:20   1223 c02 encrypted newcamd:-client granted (, au=0)
    2011/02/02 11:59:20   1223 c02 user showtime authenticated successfully (CCcam)
    2011/02/02 11:59:20   1223 c02 AU disabled for user showtime
    2011/02/02 11:59:22   1223 c02 (0B02&000000/7727/4C:3FF2): found (76 ms) by focux
    si aici din webif
    Code:
    2011/02/02 11:56:12   1134 c03  (0B02&000000/10D8/4C:FA48): found (75 ms) by focux
    2011/02/02 11:56:12   1133 c02  (0B02&000000/7727/4C:EDAC): found (74 ms) by focux
    2011/02/02 11:56:22   1134 c03  (0B02&000000/10D8/4C:0214): found (73 ms) by focux
    2011/02/02 11:56:22   1133 c02  (0B02&000000/7727/4C:DD63): found (75 ms) by focux
    2011/02/02 11:56:32   1133 c02  (0B02&000000/7727/4C:5671): found (74 ms) by focux
    2011/02/02 11:56:38   1134 c03  (0B02&000000/10D8/4C:764D): found (70 ms) by focux
    2011/02/02 11:56:42   1134 c03  (0B02&000000/10D8/4C:CA4B): found (73 ms) by focux
    2011/02/02 11:56:42   1133 c02  (0B02&000000/7727/4C:A012): found (108 ms) by focux
    2011/02/02 11:56:52   1134 c03  (0B02&000000/10D8/4C:616A): found (73 ms) by focux
    2011/02/02 11:56:52   1133 c02  (0B02&000000/7727/4C:E2C0): found (74 ms) by focux
    2011/02/02 11:56:55   1134 c03  (0B02&000000/10D8/67:9431): not found (55 ms)
  5. #20
    23 Apr 2007
    P3X-888
    super tare ... felicitari , jos palaria
  6. #21
    29 May 2007
    Quote Originally Posted by dolby View Post
    Chiar daca sunt un pic offtopic, incerc si eu o intrebare.
    Din experienta voastra, care este setarea cea mai buna la frecventa in newcs a unui card conax de upc alb complet (care sa deschida mai rapid dar sa nu prajeasca cardul si sa nu afecteze stabilitatea)?
    Eu am setat acum:
    <mhz>357</mhz>
    si imi deschide la cca 220-225 ms.
    Multumesc
    merge si la 6 mhz cu 160 ms
    baga mare..ca nu pateste nimic
  7. #22
    22 Apr 2007
    Quote Originally Posted by stargate View Post
    Din pacate am avut alte prioritati si momenta nu am incercat nimica cu card pe el.
    Cand o sa fac ceva o sa va zic si voie, fara grija.
  8. #23
    Standard RSP member techcenter's Avatar
    01 Feb 2008
    linia asta din log este foarte interesanta. n-am vazut niciun c()nax sa fie detectat asa de sus. poate de aici vine raspunsul la timpii mici de raspuns.
    succesuri!
  9. #24
    23 Apr 2007
    P3X-888
    eu ma gandesc sa nu cumva sa fie un bug al versiuni de oscam ... este totusi o frecventa destul de mare
  10. #25
    29 Mar 2009
    Austria - TM
    @techcenter
    este in smargo sau alt card reader ,intern cred ca se präjea de mult
  11. #26
    10 Jan 2009
    @stargate
    merge cu orice versiune de oscam cu aceiasi timpi si il folosesc cu phoenix / smartmouse , dar ideea interesanta este ca merge cu aceiasi timpi cu o linie N dar si cu 4 linii N.
  12. #27
    23 Apr 2007
    P3X-888
    ma bucur ca iti merge cu toate ca sigur este vreun bug ceva ... este un timp prea bun , oricum este bine ca merge ok si ai un super timp de raspuns .
    bafta
  13. #28
    04 Jan 2010
    mie imi deschide cu 107-110ms card rosu cu alb la 4.8 mhz intern in ipbox dar nicidecum ca la pgsm.foarte tare !
    011/04/12 23:51:21 c dvbapi (0B02&000000/7797/4C:BB52): found (109 ms) by localreader (of 1 avail 1)
    2-3 cutii cu linucsi hw:mips si sh4;sw: openwrt si tidegloE2
  14. #29
    30 Dec 2008
    Salut
    Am gasit acest thread cautand ceva review de OC pt cardul conax Focus. Este interesant ce am citit aici... dar nu am gasit ce ma interesa. De aceea intreb : a incercat cineva cardul la 1200 mhz ? Eu de ex am unul alb complet (ne e cu rosu) tinut in cccam la 600 mhz. Cardul e atasat unui PC cu linux si functioneaza in Smargo Smartreader+. Am vazut cateva postari mai sus ca daca sari de 480 mhz cu acest tip de card, "se prajeste". La mine nu s-a intamplat acest lucru nici in smargo, nici in cititorul intern de la DM800. Merge la ac frecventa de aprox 1 an.
    Deci repet intrebarea: a incercat cineva mai sus de 600 mhz (1200 de ex) ?
    LE: la 600 mhz cardul are timpi de la 0,140 , iar la 357 de la 0,190... La 480 am timpi de la 180 mhz..
  15. #30
    acuma explica mi mie logica de ce sa l ti asa de sus?una la mana ca ii faci viata mai scurta cautand un timp de raspuns diferit cu putin decat daca il folosesti in default
    eu am 150 in oscam la default,de fapt in oscam poti seta tu ce vrei ca tot cum vrea el il ia
    intradevar in 3c la default am 190-205
    e adevarat ca eu am cardu rosu dar am un prieten ce il tine in oscam la default cardu alb si are 140
    eu zic ca il ti prea sus si il omori repede.........si ptr ce
    TOP5: Zgemma H9,
