Dislikes:
VTi "Vu+ Team Image" - V 2.3 OE 1.6
New VTi "Vu+ Team Image" - V 2.3 28.12.2010 OE 1.6
Enigma 23.12.2010
Treiber 21.12.2010
Plugins 28.12.2010
Skins 28.12.2010
Changes: VTi Bootlogos and new Radiomode Logo.
Multiple fixes at Imagesources and diffs, link from /usr/keys to /var/keys created and different litlle things in the image.
Vu+ Duo
Turn off LNB power at standby
Fix video event problem
Fix VFD display problem
Fix long press key problem
Adjust remote control response time a bit more
Fix virtual tuner problem.
Support Fancontorl interface at standby
Support pcm sound(needs additional kernel modules) in dolby digital downmix mode.
Clean up playback driver and fix misc. bugs.
Fix some diseqec switch problem.
Fix front rotary switch problem
Separate gcc 4.4.3 version and 4.1.1 version
Make screen blank when zapping
Enhance tuning algorithm
Support more mkv file formats.
Fix occasional "no audio" problem in playback
Fix "late audio play" problem in playback
Support EOS detection in playback driver
Fix mp3 playback problem
Support FF trick mode in playback
Adjust memory allocation
Support DTS Passthrough
From VTi Team
VTi Panel (Blue Button)
supported languages are Englisch, German, Dutch
short press on blue button opens VTi Panel, longer press opens Pluginmenu
Enhanced Multiboot support (BA and other)
Enhanced SATA-HDD recognition
Some Enigma2 fixes
Cronjobs full supported
No error massages while changeing the password
Pure audio disc playback - (USB CD Drive)
Kernel and system enhancements
OE1.6 QT-Webbrowser support
Many enhancements in network and networkbrowserplugin
Support for Windows 7 Samba (CIFS-Server)
Support for Vu+ Duo Imagebackup (USB/NFI-Restore) OE1.6 Fix
New Enigma2 Crashlogremover
Swapfile at /media/usb
IPK-Installer search at /media/usb/* too
Softwaremanager plugin is now build-in into the image
Rytec EPG
Fix FanControl settings problem after reboot
Some WLAN fixes
Support for FTDI chipset cardreader like smargo and easymouse2
Greenscreen fix when no softcam is installed and any color key will be pressed
New Skin Infobar/Renderfile
Running Softcam shown in the Infobar
Better support for MyTube, MetacafeDirect and other
Support for WLAN Stick with RT3070 chipset (802.11b/g/n)
Device Manager (THX to openee project for code base)
Download NFI
Download USB
alternative link for USB version
alternative link for USB version here
succesuri!
