Results 1 to 15 of 15
Thread: Aaf me ufs910
    Default Aaf me ufs910
    AAF Multimedia Edition UFS910 FullUSB/USB
    Image Info
    AAF Enigma2 MultiMedia Edition (Image 25) Changelog:
    SH4 Duckbox Projekt:
    + Libeplayer3 (besseres Streaming Verhalten/mehr Stabilität bei Wiedergabe)
    + Better performance when jumping through recordings during playback
    + fix dma bug
    + Fixed sporadic hangs during playback also in Diff4
    + bugfix from Schischu regarding hanging while loop
    + fix help menu and softwaremanager
    + fix unknown mp3 audio selection
    + Fixed GS when Teletext is invoked an no tuner is configured
    + [ffmpeg] add videoshoot support and convert jpg > mvi support
    + [ufs912/atevio7000] merge stv090x; ORF bugfix
    + fix a bug in libeplayer3 handling
    +[ufs922] evremote2 --> must fix epg_key
    + [evremote2] Change atevio7000 handling
    +[nuvoton] now uses irq instead of polling
    + [micom] bugfix
    + [ufs912, 922] micom now uses irq to receive fp events. longkeypress support
    + [evremote2] enable longkeypress for Atevio7000
    + [ufs912] fix avi reboot bug
    + [ufs912] Tunertreiber aktualisiert
    AAF:
    + Overclock/Übertakten (außer UFS-912)
    + fix PIP zoom
    + PluginBrowser Preview Support (standard)
    + Cardreader Support (at700/7000)
    + AafPanel Icon Support
    MediaCenter Update:
    VideoPlayer:
    + Cover Ansicht (4x3 cover like Xbox Xbmc)
    + Fullcover Ansicht (like ProjektVallery)
    + Cover/imdb download von Imdb/TheMovieDbProvider/TheTvDbProvider/Mtv integriert
    + Cover und infos fuer Filme/Serien/Musikvideos
    + Automatisches Update der IMdb Daten moeglich
    + Special Folder support fuer Cover Ansicht (Ordner mit Serien/Section Bilder like Xbox Xbmc)
    + Random (Shuffle Support)
    + Verbesserte Steuerung
    + Apple Movie Trailer (außer TF7700)
    + MyVideo Player
    PicturePlayer:
    AudioPlayer:
    + Screensaver (Title Text)
    + Screensaver (PNG1)
    + Screensaver (PNG2)
    + Screensaver (MVI SAVER)
    + Screensaver (MVI IMDB)
    Webinterface Update:
    Webinterface auf version 1.6.2 upgraded
    + add AAF-Panel
    AAF-Panel:
    + add SoftcamPanel
    + add FlashUpdate
    + add Backup&Restore
    + add ImageInfo
    + add OverClock over WebIF (bis auf UFS-912)
    + Screenshot Video und ALL
    bekannte Fehler und Probleme:
    - Videoshoot im WebIF funktioniert (noch) nicht mit alllen HD Sendern
    - MyVideo ruckelt sporadisch
    Zum OverClock/Übertakten:
    Mit der grunen taste und OK taste, werden die einstellungen fest in die start-config geschrieben.
    Deswegen sollte vorher die frequenz mit der blauen taste getestet werden!
    Ihr konnt auch den Soft-StandBy takt ändern:
    266mhz
    200mhz
    166mhz
    133mhz
    Wie ihr sehen konnt, kann man die cpu runtertakten, um damit ein bisschen Strom zu sparen und die Lebensdauer der cpu zu erhohen.
    Wenn wer viel mit dem MediaCenter macht bzw. generell nicht nur TV schaut, sollte das Overclock mal ausprobieren.
    Es besteht auch kaum eine gefahr, da selbst bei 400mhz (standard 266mhz) die CPU nur 1° wärmer wird.
    Desweiteren falls wer ein Fehler macht, blockt der Kernel und es gibt ein error reboot sodass nichts kaputt gehen kann.
    Bitte auch beachten:
    - Nach Einrichten und Installieren das Nullmodem Kabel
    am Receiver abziehen. Bei gestecktem Kabel
    bootet der Receiver nur, wenn der PC an ist.
    - Fuer Ton ueber HDMI in den A/V Einstellungen
    SPDIF als Audio Source angeben
    Danke an Team Ducktales sowie allen, die im Duckbox SH4 Projekt
    am tollen Basisimage mitwirken. Und natuerlich an alle, die dieses
    Image ermoeglicht und getestet haben.
    Euer AAF Team
    - FullUSB - http://www.megaupload.com/?d=69UCJNE9
    - USB - http://www.megaupload.com/?d=GJSOTX3J
    09 Jan 2010
    so far very nice.
    New feature 'Apple Trailer' unstable.
    pană in prezent foarte frumos.
    Noua facilitate de "Apple Trailer" instabil.
    21 Mar 2009
    Thumbs down asa si asa ...
    nu merg mai multe, printre care subtitrarile, teletextul, etc ...
    04 Apr 2009
    pana acum se misca binisor. pe unde e new feature-u asta cu apple trailer? personal am incercat sa intru in youtube player si m-a luat cu ecran verde. probabil mai e de lucrat.
    09 Jan 2010
    Project Valerie is installed? /media/hdd/vale
    New features:
    Menu
    AFF MEDIA CENTER
    Apple Trailer
    My Video (streaming movies, xxx, music etc.)
    04 Apr 2009
    gata am gasit ...nu stiam ca e in mediacenter. din pacate ca si la youtube player ma tine din ecran verde in ecran verde.
    RSP Enigma Team & GM
    04 Feb 2007
    Din pacate o mare dezamagire pe partea de mediaplayer.Lent in comenzi , unele stari le ignora.(nu-mi apare in menu media player , subtitle ) ,sunet pe DTS cu intreruperi ,ecrane verzi.
    Pe partea de satelit nici macar nu merita sa dau o scanare.
    Astept o imagine by zildan cu stm23 si dts optical out.
    f11
    09 Jan 2010
    it looks nice but performance is poor. They should have fixed problems before release.
    Arata frumos, dar performanta este slabă. Ei ar trebui să rezolve bugurile inainte de lansare.
    04 Apr 2009
    dupa o zi mai intensa de testare a dat ochii peste cap de tot. foarte slaba imaginea din punct de vedere al stabilitatii. are de toate, da nu merge nici una cum trebuie. astazi a culminat cu imposibilitatea de a intra in soft-standby =)).
    17 Nov 2008
    Default AAF_MultiMedia_Edition_V2_UFS_910
    Code:
    GIT 1860
    - Neue Player Engine STM Havana Player 179
    - Fix STM23 MAC bug
    - Fix schnelles zuruckspulen
    - disable 2 unneeded processes
    - [Libeplayer3] ogg / flac Playback
    [libeplayer3] some changes regarding playback flushing after playthrough
    - Kartenleser Treiber
    - [libeplayer3]decrease debug level due to some performance problems
    - [libeplayer3] fix blocking at end of file
    - stm23 add ftdi_sio (Unterstutzung fur externe Kartenleser wie Smargo)
    AAF M5879:
    - enable libsmbclient
    - VideoPlayer fix play same file after eof
    - Tuner Treiber update
    - Frontpanel Treiber Update
    - Online Update Funktion
    - kleinere fixes
    - [mc] pictureplayer add mp3 support on slideshow
    ---------- Post added at 21:35 ---------- Previous post was at 21:32 ----------
    link
    http://www.sat-universe.com/showthread.php?t=196620
    surpriza la teste meniu bicolor la rasfoire canale,,,interesant
    Standard RSP member bliviu27's Avatar
    03 Feb 2009
    constanta
    Default lista sateliti
    de unde dascarc o lista completa de sateliti pt aceasta imagine ca are doar 4 sateliti initiali?
    eu nu am gasit nicaieri in meniu si nici nu are functia add satellite
    03 Feb 2009
    constanta
    Default subtitle!!!!!??????????????!!!!!!!!!!!
    cu sateltii am rezolvat-o multumiri celor ce m-au ajutat insa am gasit o alta buba(ori sunt eu chior} de unde bagi subtitle la prog de satelit ca nu gasesc functia??????????
    galben galben
    09 Jan 2010
    AAF MediaCenter Spring Edition UFS910
    Not tested by me
    Nu a fost testat de mine
    http://hotfile.com/dl/115843683/923d...llUSB.zip.html
    17 Nov 2008
    Default AAF MediaCenter Spring EditionV1 UFS910fix FullUSB
    imbunatatire.....
    http://hotfile.com/dl/116118967/dc9e...L_FIX.rar.html
