BlackHole Vu+ Duo v. 1.4.2 Multiboot
WARNING BECAUSE OF NEW DRIVERS THIS IMAGE CANNOT BE INSTALLED IN MULTIBOOT. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
Specifications:
New drivers: 20101221
Enigma2 updated to: 20101124
Driver update
20101125
- Fix HD playback problem(solo)
20101203
- Support audio lipsync control
- Memory usage optimization(solo)
- Fix high cpu usage in ts playback
20101221
- Fix audio lipsync control(minus value)
- remove v4l-vuplus.patch in the v4l-dvb-modules
- Clean and speed up the demux driver(shoudl be used with new v4l-dvb-modules
driver)
- Speed up trick mode in ts playback
- Fix CI module recognition problem at bootup.
- Support high CI bitrate
- Support rf_switch proc interface
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount Wizard (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Llukkino (VDR-Italy) for the source code of OpenTV.
DISCLAIMER
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR IILEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
ANY CHANGES OR ADDITIONS TO BLACK HOLE IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
USB version:
http://www.multiupload.com/0CVDYW8KH0
