Results 1 to 13 of 13
Thread: oscam moare dupa 2-3 ore va rog ajutati-ma
    Standard RSP member tmdmitza's Avatar
    05 Feb 2010
    Default oscam moare dupa 2-3 ore va rog ajutati-ma
    2010/12/13 13:29:25 1905 r02 detect native nagra card
    2010/12/13 13:29:25 1905 r02 -----------------------------------------
    2010/12/13 13:29:25 1905 r02 |id |tier |valid from |valid to |
    2010/12/13 13:29:25 1905 r02 +----+--------+------------+------------+
    2010/12/13 13:29:25 1905 r02 |2111|0040 |2013/01/31 |2011/03/27 |
    2010/12/13 13:29:25 1905 r02 |2111|0065 |2013/01/31 |2011/03/27 |
    2010/12/13 13:29:26 1905 r02 |2111|BDCA |2011/08/31 |2011/03/27 |
    2010/12/13 13:29:26 1905 r02 |2111|0083 |2011/08/31 |2011/03/27 |
    2010/12/13 13:29:26 1905 r02 -----------------------------------------
    2010/12/13 13:29:26 1905 r02 WARNING: For NAGRA2 cards you will have to set 'cardmhz = 368' in oscam.server
    2010/12/13 13:29:26 1905 r02 ROM: D N A S P 1 8 0
    2010/12/13 13:29:26 1905 r02 REV: M e r 0 0 0
    2010/12/13 13:29:26 1905 r02 SER:
    2010/12/13 13:29:26 1905 r02 CAID: 1880
    2010/12/13 13:29:26 1905 r02 Prv.ID: 00 00 20 11 (sysid)
    2010/12/13 13:29:26 1905 r02 Prv.ID: 00 00 00 00
    2010/12/13 13:29:26 1905 r02 Prv.ID: 00 00 21 11
    2010/12/13 13:29:26 1905 r02 [nagra-reader] ready for requests
    2010/12/13 13:29:26 1905 r02 exit with signal 11
    2010/12/13 13:29:26 990 s PANIC: reader lost !! (pid=1905)
    2010/12/13 13:29:26 990 s restarting digi reader in 5 seconds (index=0)
    este vorba de :
    OSCAM 0.99.4svn build #3086
    server ubuntu 10.04 lts, reader card phoenix
    oscam.server
    [reader]
    label = digi
    enable = 1
    protocol = mouse
    device = /dev/ttyS0
    caid = 1880
    boxid = .........
    rsakey = ......................................
    boxkey = ..............
    detect = CD
    mhz = 357
    cardmhz = 357
    ident = 1880:002111,002011,000000
    group = 1
    emmcache = 1,3,0
    ecmcache = 1
    lb_weight = 100
    audisabled = 1
    oscam.conf:
    [global]
    logfile = /tmp/oscam.log
    disablelog = 0
    disableuserfile = 0
    usrfileflag = 0
    clienttimeout = 6600
    fallbacktimeout = 6500
    clientmaxidle = 120
    bindwait = 120
    netprio = 0
    clientdyndns = 0
    resolvedelay = 30
    unlockparental = 0
    nice = -10
    serialreadertimeout = 6500
    maxlogsize = 12400
    waitforcards = 1
    preferlocalcards = 1
    saveinithistory = 1
    readerrestartseconds = 5
    lb_mode = 0
    lb_save = 0
    lb_nbest_readers = 2
    lb_nfb_readers = 2
    lb_min_ecmcount = 5
    lb_max_ecmcount = 500
    lb_reopen_seconds = 900
    resolvegethostbyname = 0
    am incercat mai multe versiuni de oscam toate moare dupa cateva ore,iar daca restartez servrul iara merge un timp ,si daca dau restart la reader tot asa face cu "panic reader lost"
    vre-o idee ????
    23 Apr 2007
    P3X-888
    sa nu cumva sa-ti faca probleme readerul phoenix
    05 Feb 2010
    readerul nu imi face probleme pentru ca am avut cardul pus cu sbox si cam 3 saptamani a mers non stop fara probleme dar oscam imi place mai mult e mult mai complex si are multe facilitati pe care sbox nu le are si deaia nu vreau sa renunt la oscam
    alte pareri??
    29 Mar 2009
    Austria - TM
    ai incercat sa urci card mhz ?
    eu stiam ca 1880 merge cu mai mult
    pune versiune 4xxx oscam!
    05 Feb 2010
    am incercat cu mai multe versiuni inclusiv cu 4..... astea mai noi moare mai repede decat credeam dupa 20-30 minute ....
    cardul nu pot sa il pun la mai mult de 3.57 mhz pentru ca atata stie phoenix-ul
    ce spuneti setarile sunt ok este gresit pe undeva??
    comparati va rog setarile mele cu ale dvs. poate gasit vreun defect ca eu am umblat in setari de l-am innebunit
    deci teoretic readerul il initializeaza corect dupa care nu ii convine ceva la oscam...
    Am avut probleme similare cu un card ND$ de $ky DE si in final ..... am schimbat calculatorul .
    Era pus pe USB readerul, se pare ca nu avea curent destul !!!
    29 Mar 2009
    Austria - TM
    Pai mai repede pui un Hub si primeste curent destul cititorul
    Dar na in vreme de criza
    oscam.server
    [reader]
    label = digi
    enable = 1
    protocol = mouse
    device = /dev/ttyS0
    caid = 1880
    boxid = .........
    detect = CD
    group = 1
    emmcache = 1,3,2
    lb_weight = 100
    audisabled = 1
    pune asa
    23 Apr 2007
    P3X-888
    Quote Originally Posted by tmdmitza View Post
    alte pareri??
    de exemplu mie reader phoenix cu convertor serial-usb mi-a mers super bine card akta pus in oscam dar card focussat nu vrea , vede cardul dar nu decodeaza din card , ar fi fost super daca gaseai un alt reader diferit ( sa nu fie tot phoenix ) sa incerci . eu am testat oscam pe router topex
    05 Feb 2010
    Am pus cardul in dreambox i-am dat mai multe frecvente... i-am mai umblat prin setari... tot asa face pe un alt forum am citit ca la oscam nu ii prea place de rom 180.postarea respectiva era doar de o luna pe forumul respectiv deci nu pot sa spun ca era veche...
    pe un alt forum am vazut un tip care avea aceeasi problema ca mine si nu a putut sa rezolve situatia decat cu un script care vedea cand ii cadea readerul si scriptul acela ii restarta oscamul
    Oare o fi adevarat sa nu ii placa la oscam de rom 180 ??
    Cu aceasta ocazie rog pe cineva care are rom 180 ,caid 1880, si foloseste cartela cu oscam sa imi confirme daca este adevarat daca acest rom ii place sau nu la oscam.
    29 Mar 2009
    Austria - TM
    Cine a zis ca nu-i place de oscam
    Putina atentie la config numai
    Personal nu am 180 dar am pus la multi in DM
    Pe DM 500 se lasa mai greu da merge pe 800 nu mai vb depinde si de imagine Gemini,DE,
    Toate numai cu smargo
    2010/09/19 0:41:40 188 c01 dvbapi: Start descrambling CAID: 1880 PID: 1037
    2010/09/19 0:41:42 188 c01 anonymous (1880&000000/03EB/89:67B2): found (385 ms) by sci0 ()
    2010/09/19 0:41:52 188 c01 anonymous (1880&000000/03EB/89:321E): found (387 ms) by sci0 ()
    2010/09/19 0:42:02 188 c01 anonymous (1880&000000/03EB/89:FE61): found (394 ms) by sci0 ()
    2010/09/19 0:42:12 188 c01 anonymous (1880&000000/03EB/89:581A): found (385 ms) by sci0 ()
    2010/09/19 0:42:22 188 c01 anonymous (1880&000000/03EB/89:21A8): found (386 ms) by sci0 ()
    2010/09/19 0:42:32 188 c01 anonymous (1880&000000/03EB/89:9A65): found (383 ms) by sci0 ()
    Pe 500 mai da rateuri da merge
    05 Feb 2010
    pai atunci ce spui sunt ok setarile???
