Page 9 of 12 FirstFirst ... 56789101112 LastLast
Results 121 to 135 of 166
Thread: Discutii pt aparitia lui Ipbox 9000 & 900
  1. #121
    02 Feb 2007
    Somewhere in Aegean Sea!!
    Default Re: AB IPBox 9000 HD PVR & 900hd
    Niste settings care au iesit acuma.
    List for IPBox HD DGS 42E-8W DiseqC up to 2008.07.12
    List for IPBox HD DGS 42E-8W DiseqC 2008.07.12.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  2. #122
    02 Feb 2007
    AB IPBox HD/9000HD_Images - official/AB_9000HD_110708_r7712_usb_all_noboot.zip
    File desciption
    Official image AB_9000HD_110708_r7712 for AB IPBox 9000HD
    Changelog:
    add:
    - New mp3 player - press "Music" button for start. Mp3 file copy to /media/mp3
    - FAT 32 support for external USB device
    - new options for edit music and picture files. You can copy files from external USB media
    - Power control menu. You can set up Shutdown or Standby fonction for Standby button. (Timer working in Shutdown mode too)
    - all audiotracks reco***ng
    - improved speed of control
    fixed,modify:
    - fixed Panic and freeze problem.
    - fixed mp3 freeze problem
    ftp login/password: root/ipbox
    Software upgrade from USB memory stick (host):
    • backup important data from memory stick before try to update. Remove all data from it.
    • copy "usb update.img" image to USB memory stick
    • run "remove h/w(memory stick)" function on PC. You can see icon on right bottom (left of clock) screen.
    • turn off the stb(Standby + OK) and insert the memory stick.
    • press and hold Standby button until front display shows “BOOTING” and press UP key
    (on the front side of the box, not on RC), then front display shows "USB UPGRADE" message..
    • uboot will update s/w with usb_update.img from memory stick
    • Wait until DONE message displays. Restart your receiver.
    New addon for AB image software for AB IPBox 9000HD 11/07/08
    Instalation
    copy "addon_version-9000HD_sh4_110608.ipk" to /tmp
    connect to box with webinterface ( write IP adress of your box to internet browser)
    use login/password : root/ipbox
    go to menu addons
    press install
    wait for STB reboot
    configuration files are located in var/tuxbox/config
    addon_version-9000HD_sh4_110708.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  3. #123
    02 Feb 2007
    Din informatii care avem de la ABcom.Enigma 2 pt ipbox 9000HD e gata.Acuma face pe ultime probe si cel putin in 2-3 saptaminii o sa fie dat pe public.(acuma daca dureaza ceva mai mult de 2-3 saptaminii asta e )In curind o sa fie publicate si imaginii cu enigma 2 care ruleze...
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  4. #124
    02 Feb 2007
    List for IPBox HD DGS 42E-8W DiseqC up to 2008.07.13b
    List for IPBox HD DGS 42E-8W DiseqC 2008.07.13b.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  5. #125
    02 Feb 2007
    Default Nlb 7712
    - Updated with SVN7712
    - bootup included - no need to install original
    DGS SVN to switch to NLB image boot.
    - Code updates
    - mgcamd 1.3d / newcs 1.60beta included (autostart!)
    remember to upload configs/files into /var/keys
    nlb7712.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  6. #126
    Standard RSP member Alextm's Avatar
    20 Dec 2007
    Timisoara
    Quote Originally Posted by otheitis View Post
    Cand imaginea cu enigma 2 o sa functioneze atunci o sa fie un concurent serios pt DM800...abia astept sa apara...cam pe cand ma intorc din concediul din Corfu...
  7. #127
    01 Apr 2007
    Quote Originally Posted by Alextm View Post
    Cand imaginea cu enigma 2 o sa functioneze ....
    Mai simplu dezvolta un program share p2p cu protocol ccam ( daca tot sint incapabili sa actioneze in directia MPCS/gbox )
    Pe acelasi tip de procesor E2 portata ar asigura compatibilitatea executabilelor ( cazul modelelor cu procesor PPC405 ) , acum E2 pe ST40 este tichie de margaritar pe capu' chelului .
  8. #128
    02 Feb 2007
    Imagina cu enigma 2 functioneaza.Acuma face niste cosmetizarile.in curind o sa aduc si poze cu enigma sa ruleze.Asa cum ati vazut povestea ipbox nu se asemana deloc cu povestea kathrein.La kathrein aparatul e foarte bun dar producatorul nu e prea interesant pt el.Asta se vede foarte usor cu citi updaturi a scos pt aparatul asta.In al doila rind multe lucruri banale nu sunt bagate la soft cum e diseqc 1,2 (asteapta kathrein sa fie rezolvat toate problemele de la simpli user care se ocupa ca hobby cu receptoare si cu plug in)DGS impreuna cu ABCom lucreaza mult si scoate firmware aproximativ fiecare saptamina.In al doila rind sunt 2 team unoficiale sifteam si NLB care se ocupa si ele.Enigma 2 o sa vine de la ABCOM si nu de la sifteam sau de la NLB.Cum o sa vedeti la ultimul firmware sunt modificate spre bine mp3 player si image view.Acuma lucreaza si pt divx player (adica o sa poate sa ruleze filme divx de la hard disk nu prin vlc)si pt IPTV.S-au observat ca plug in se misca cam greu asa s-au hotarit sa face un concurs cu cadouri pt cel mai bune plug in-uri.Asa cred ca in viitor o sa apare si plug in ca lumea.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  9. #129
    02 Feb 2007
    Sifteam 0.1.2 r7712
    *From 0.1.2:
    From default use DGS webif
    For use old webif ..connect to:
    h**p://DECODER_IP/sifteam.html
    New MP3 player use dir named "mp3"
    Please change /hdd/MP3 to /hdd/mp3
    Removed from addons-online:
    Skin @Crash
    Plugin Mp3-player
    usb_kernel_root_db.img
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  10. #130
    02 Feb 2007
    In curind o sa iese EPG 0.8b care o sa contine programul pt toate canale.Am o rugaminte am pe impresia ca e timp sa facem un section separat pt ipbox.Care sa putem sa punem pe settings,firmware,programe,news separat.Aica asa cum il bagam a inceput sa fie obositor si multii nu reuseste sa gaseste ce punem.
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  11. #131
    02 Feb 2007
    Default Sifteam 0.1.3 r7712
    *From 0.1.3:
    Modifyed Standby Hard Disk System
    From default is 0
    For change this value, ..create file:
    /var/etc/SifTeam/conf/time_sleep_hd
    And add your personel value
    Possible value is 12*M (M=minutes)
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  12. #132
    02 Feb 2007
    Default Nlb Svn 7473 900hd
    ***Asta versiuna e pentru ABcom 900HD***
    NLB release for IP900 using SVN7473 for CubeRevo mini. It has been tested and verified.
    Upgrade box using usb key.. image file should be named "usb_update.img"
    PS: Known issue on first boot startup of box. DHCP not working. You need to go into ip setup and choose save in ip setup for DHCP or STATIC, then all is ok.
    For the people who are thinking of testing every option from the WEBIF, please have the following warning in mind:
    Don't use mgcamd v1.29a or 1.29a patched since that will hang the receiver. If you use it, you can't change channels and when you kill it the receiver hangs hard. No panic on the display, only a poweroff will work. When you use 1.29a, you won't be able to reboot the receiver from webif. That will hang the receiver to.
    If you have selected 1.29a or the patched version. Remove the file /var/etc/use_mgcamd129 or /var/etc/no_lib_mgcamd using a telnet or SSH session. Then shutdown the receiver. That will give you the new and good mgcamd version
    In all other options, the image is very stable
    nlb7473mini.zip
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  13. #133
    02 Feb 2007
    Default ENIGMA 2 pentru abcom 9000HD
    Asa cum ati vazut enigma 2 o sa exista pt ipbox 9000HD.O sa revin cu mai multe fotografie care o sa trimite Tomma mechanicul de la abcom.Asta versiuna enigma 2 e scoasa de la firma abcom si nu din team sifteam sau nlb.Idea e ca ipbox o sa are support de la abcom pt enigma 2 in comparatia cu kathrein care enigma 2 e scos de la un team.Si pina acuma nu e evoluat deloc.
    Attached Images Attached Images
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  14. #134
    02 Feb 2007
    Default Re: ENIGMA 2 pentru abcom 9000HD
    Asta sunt inca niste noi foto exclusiv pt voi!De la menu.....
    AB IPBOX 9000HD
    DVB/S2-CABLE TUNER
  15. #135
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    poze mai mici nu ai gasit?
    RSP-TEAM
