Results 1 to 7 of 7
Thread: CLARKE-TECH 5000HD
    Member Beginner share's Avatar
    08 Nov 2010
    Default CLARKE-TECH 5000HD
    salve, la CLARKE-TECH 5000HD te pricepi? mu imi amintesc pinu stii cunva cum pot sal dezactivez? multumesc.
    23 Feb 2007
    CONSTANTA
    08 Nov 2010
    Post pin
    multumesc dar nu ma refeream la pinu de emu ci al decului, vreau sal resetez din fabrica dar imi cere pin si nu il mai amintesc.
    23 Feb 2007
    CONSTANTA
    Security Settings
    This submenu allows you to set password options and to lock or unlock access to menus
    (Note: PIN code and password are the same). <Figure 6.2.4>
    - Receiver Lock : Set ON to require entering a PIN code at powering on.
    - Install Lock : Set ON to require entering a PIN code to access the installation menu.
    - Channel Lock : Set ON to require entering a PIN code to access the channels menu.
    - Lock Channel Confirm : Set ON to require entering a PIN code to access a locked
    channel.
    - Age Limit : Set to prevent children or unauthorized people from watching programs.
    Select among (Free/ 8 above/12 above/15 above/18 above). When
    program information (age limit) is available from broadcaster and this age
    limit exceeds the selection, a PIN code is required to access the
    channel/program.
    - Current Password : To change your password, first enter your current password.
    - New Password : Enter the new password that you want to set.
    - Verify Password : Enter the new password again for confirmation.
    �� Note : The default password is ‘0000’.
    http://www.clarketech.altoma.biz/cm/...00.pdf?lang=en
    08 Nov 2010
    Post
    da dar cand vreau sa deschid setari securitate imi cere pin si eu nu il mai stiu pt. ca lam schimbat am incercat 0000, 1234 etc. nimic am schimbat si firmware nimic nu mai stiu ce sa incerc.
    23 Feb 2007
    CONSTANTA
    Ce setari securizate,meniu ascuns ptr share de exemplu?
    08 Nov 2010
    Post
    ceia ce mi-ai dat mai sus in engleza, nu am probleme cu menu ascuns, cu pinu recului lam uitat si nu pot sal schimb.
