Dislikes:
AVerDiGi EB1304MD SATA
Produs: AVerDiGi EB1304MD SATA
Descriere:
Item
EB1304MD SATA
Operation System
Embedded RTOS
Video Compression
MPEG4
Video Inputs
4
Video Outputs
Composite TV x 1 / VGA x 1
Audio In/ Audio Out
1/1
Sensor In/ Relay Out
4/1
Display Resolution (NTSC/PAL)
720x480/ 720x576
Display Frame Rate (NTSC/PAL)
120/100 fps
Recording Frame Rate (NTSC/PAL)
D1: 60/50 fps
CIF: 120/100 fps
Recording Mode
Continuous/ Sensor/ Motion / Schedule (00:00~24:00 set by hour)
Video Search
Date/ Time/ Event (Infinite)
Video Quality Settings
Hue/ Brightness/ saturation/ Contrast
Video Enhancer Software
iEnhance/ iStable
Backup Function
USB backup via PC
Number of HDDs Support
1 (Standard 3.5” SATA HDD)
Accessories
IR Extension cord (optional), Remote controller
Testing verification
EMI, ESD, CE, FCC, Thermal, Dropping
Dimensions
235mm(W)x160mm(D)x50mm(H)
(Only 50% of existing DVRs)
Net Weight
0.580 Kgs
(Only 20% of existing DVRs)
Others
Image verification software included (Watermark)
Accesorii: tot ce este in cutie
Pret: 150 EURO
Garantie: verbala
Alte detalii: Se da 2 camere cu infra exterior.
Schimb cu: bani
Contact: Pe PM sau pe E-mail-ul de la profil.
Inca valabil
