Specifications:
- Based on the new official verion 5.3
-OE 1.6
- New Skin White Hd by Army
- New Boot logo by Army
- Integrated OpenEpg
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Button Red = Start Record
Addons
Infobar / OSD
Analog Clock Enigma2
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Manager Kernel Modules (Kernel module operator)
Black Hole Mount ****** (Mount points)
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
Usb Tuner Panel
Info Panel
1 - E2 Setting (Enigma2 configurations)
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Credits
Thanks to Llukkino (VDR-Italy) for the source code of OpenTV.
DISCLAIMER
THE IMAGE AND BLACK HOLE 'IS BASED ON OFFICIAL FIRMWARE + VU IN ACCORDANCE WITH THE LAWS OF THE SYSTEM AND ADDITIONS ONLY CONTAINS GRAPHIC CHANGES.
THE IMAGE OF BLACK HOLE DOES NOT CONTAIN ANY OTHER NE'ALCUN EMULATOR SYSTEM FOR VIEWING PAY TV WITHOUT A REGULAR OR SUBSCRIPTION FOR THE SO-CALLED CARD-SHARING.
THE IMAGE OF BLACK HOLE SYSTEM DOES NOT CONTAIN ANY FURTHER TO DOWNLOAD PLUGIN TO EXTERNAL SERVER OR SOFTWARE THAT MAY NOT BE USED FOR LEGAL PURPOSES.
LICENSE (TERM OF USE)
THE IMAGE AND BLACK HOLE 'ISSUED FOR THE FREE USE BY ALL USERS OF A PACT THAT WOULD NOT BE CHANGED IN ANY WAY AND THAT IS USED only for lawful purposes.
CHANGES OR ADDITIONS TO IMAGE BLACK HOLE INVOLVING ANY MAY NOT USE THE SAME AS CARD-SHARING EMULATORS AND ARE IN CONFLICT WITH THIS LICENSE AND result in immediate revocation of the same.
---------- Post added at 01:45 ---------- Previous post was at 01:11 ----------
nfi
http://www.filefactory.com/file/b41b...O_136D_NFI.zip
usb
http://www.filefactory.com/file/b41b...O_136D_USB.zip
cineva sa le puna sus.
