- Posibilitatea redarii filmelor de pe un network drive ?
- Inregistrare pe un network drive (si usb) ?
- Se poate incarca vre-un client torrent ??
Mai sint si alte detalii de acest gen ?
Dislikes: 0
New firmware 6/5/11
[INDENT]New firmware 6/5/111.Optimize "read smart card function"
for example, Viaccess 4.0,NDS 2.0 , I***** 2.0, Conax 5, Sega ( i.e.Mediaguard 3)
Nagra 2 and so on
2. Add "FTP function', you can upgrade your software and files by internet,
including software, system file, TP_PRO.dbs, Cccam.cfg, softcam and so on
3.It adds some key files, and optimize "patch"
4. it adds several luanguage, i.e. Persian and so on
5. Bomb--Kill the clone
http://www.megaupload.com/?d=H4PLFMWQ
sanatate si virtute!
New firmware 6/5/11
Please DO NOT use this Firmware on CLONE Boxes. Use at your own RISK.
Nagra 2 and so on
Notes: regaring the rebooting of UK channels, we had gotten the T/S,maybe we will release new software on 15th May and solved it
Benkurd
First public release! 5.5.2011
STBHD Lan Memory Manager Tool (STBHD_LAN_MM.exe)
This program is freeware for ALI HD solution.
The program is exclusively for dealing with the ALI HD Solution over the network provides.
The use, especially of data to and from the ALI HDBOX is at your own risk.
Features:
Network Management
Script Management
Setiings Backup / Restore / Editor
Support Tools for ALI3329D/ALI3602/ALI3606 Flash
And much more ...
Attent:
Copy some files( like TP_Prog.dbs/ constant.cw /CCcam.prio/CCcam.cfg...)to the tool root list!
ALI3602 HDBOX please upgrade the newest firmware!!
O intrebare pentru cei care au acest receptor, de fapt mai multe...
1. Daca poate fi si server si client de share.
2. Daca partea de mediaplayer functioneaza bine si reda si de pe un harddisc de pe retea, sau usb, etc...
3. Daca browserul web (am vazut pe youtube ca ar avea asa ceva !!) functioneaza bine.
Si daca receptorul este atat de stabil (nu ca mediabox de la echosmart!!!) incat sa merite investitia si sa nu-ti manance nervii.![]()
Am un receptor openbox s9 hd de un timp canalele cu polaritate orizontala nu imi mai merg deci pornesc receptorul merge un anumit timp dupa care am lipsa semnal am schimbat lnb-ul crezand ca e defect dar tot asa face va rog cine poate sa ma ajute deja ma dispera va multumesc
Masoara tensiunile la intrarea tunerului. 13v pe vertical , 18v pe orizontal.
Dupa ce masori tensiunile pe tuner, masoara-le si pe cablu la lnb.
din pacate nu am asa ceva si nici nu ma pricep dar de ce cand scot cablul din receptor si bag la loc iarasi am semnal pt o jum de ora?
Alta data sa cauti inainte de a intreba.
Acest aparat are un topic dedicat pe forum.
Citeste aici ce are aparatul tau si cum il repari.
Citeste pana la sfarsitul topicului !
S9-le de care va scriu de multi ani era la taica-meu in resedinta de la tara.
Cred ca l-a lovit un traznet si s-a stricvat iesirea HDMI.
Am cumparat chipul buffer dar degeaba.
Acum merge doar pe SCART.
Am cautat pe net sa ii activez keyle si am gasit urmatoarele:
Code:Here is the method for enter BISS kiy in openbox S10/ S9 utilizing remote control (Example:ptv sports paksat 1r 38e ) 1. go to menu "System SETUP"- -CCCAM CLIENT SETUP" 2. go to MANAGE CCCAM CLIENT 3. Open constant.tw 4. Snap GREEN Button on remote For include BISSKEY After That enter the quality like given roar (THIS BISS kiy SETTINGS FOR PTV SPORTS PAKSAT 38E) caid : 2600 pROVid : 0000 SID : OOO1 PMT PID: 0000 ECM PID: 0000 EVAN : 2A 4D 6D CC 7E 3A 7F CC ODD : 2A 4D 6D CC 7E 3A 7F CC
