Thanks Thanks:  10
Likes Likes:  4
Page 16 of 19 FirstFirst ... 61213141516171819 LastLast
Results 226 to 240 of 271
Thread: Openbox s9 hd pvr
  1. #226
    Poti sa pui... dar deschide numai daca e introdus in conserva originala!
  2. #227
    Standard RSP member sergio_qqq's Avatar
    11 Nov 2010
    Default Lista de canale
    10 sateliti: 39E, 28,5E, 23,5E, 19,2E 16E, 13E, 5E, 0,8W, 7W y 30w.
    https://rapidshare.com/files/4063207242/TP_PROG.rar
  3. #228
    Standard RSP member MCT's Avatar
    12 Oct 2011
    Iti multumesc merge foarte bine si imi place mult lista de canale
  4. #229
    20 Sep 2007
    Default lipsa semnal
    Nu mai am semnal, dupa ce merge vreo 5 minute.
    Dupa ce il opresc cateva ore, merge iar vreo 5 - 10 minute, apoi iar "no signal".
    S-a busit tunerul sau poate fi si altceva ?
    Va multumesc !
  5. #230
    17 Nov 2008
    ALBA
    tunerul nu este busit poate fi din sursa sau din integratu ala ce alimenteaza tunerul.
  6. #231
    20 Sep 2007
    Mersi, inseamna ca trebuie sa caut pe cineva care se pricepe la electronica.
  7. #232
    @petrica arunca un ochi aici , hai ca nu este mare lucru sa inlocuiesti un termistor
    I’ve traced the problem of low LNB voltage that causes the S-9 to work for a while then drop off. There is a small part that looks like a disc capacitor near the tuner that actually is a PTC thermistor that goes bad.
    This part provides short circuit protection, but when bad it trips off at loading well under the max rating of 500ma. The two bad ones I have found so far are marked M60 065.
    On my own OpenBox that is still working, this part is larger and is marked JK60 065. Digi-Key engineer crossed this to a “Little Fuse” brand part # F1993CT-ND. It costs 58 cents!
    This part can be changed from the top side of the board. Just snip the old one off.
    Then tack solder the new one to the solder pads.
    I then tested the S-9 by operating into a variable power resistor.
    Ran it at 19v. @ 460ma. For two hours. The voltage and current held and the thermistor ran cool.
    The S-10 uses the same part, M60 065, and is mounted on the tuner board. It has been confirmed that this Digi-Key part will fix the S-10 as well.
  8. #233
    20 Sep 2007
    Mersi mult, bonou2.
    Voi posta rezultatul.
    ---------- Post added at 08:57 ---------- Previous post was at 07:12 ----------
    Se gaseste pe la noi acest model de termistor, JK60 065, sau trebuie comandat de afara ?
    the correct part number from DigiKey is actually F1990CT-ND which is a polyfuse rated for 650ma. The F1993CT-ND part will still work but it is a polyfuse rated for 1100ma which is way over spec for a 450mA rated circuit
  9. #234
    http://www.supertech-elec.com.tw/ele...c/PTC/JK60.htm , poti folosi orice termistor cu aceleasi caracteristici.
  10. #235
    20 Sep 2007
    Am comandat astea, , si merge foarte bine. Daca mai doreste cineva, mai am 3 bucati.
    Multumesc inca o data pentru ajutor.
  11. #236
    Nu reusesc sa-i dau de cap cu un card 1802, datele necesare introduse atat cu FTP Tool cat si cu telecomanda direct in meniul receptorului. Am incercat mai multe firmware, incepand cu cel din septembrie 2011 si terminand cu cel din aprilie 2012; in meniu frecventa cardului setata la 3.57 / ID Provider 2011, deocamdata ecran negru. Ma gandesc ca poate mi-a scapat ceva si primesc o mana de ajuor de la cei ce au reusit. Multumiri anticipate.
  12. #237
    01 Oct 2012
    Quote Originally Posted by petrica View Post
    Am comandat astea, http://imageshack.us/photo/my-images/832/img0040er.jpg/, si merge foarte bine. Daca mai doreste cineva, mai am 3 bucati.
    Am eu nevoie de o bucata.
  13. #238
    30 Jul 2009
    Am sun Openbox S9 si o cartela tvr care nu mai merge de cateva zile. Am sunat la tvr si mi-au zis ca o "autorizeaza". Apoi am mai sunat o data si au zis ca o mai activeaza o data. Insa tot nu merg canalele tvr.Trebuie sa fac ceva din meniul receiverului? La smartcard information apare provider, class 0a, date: 04.04.2012-26.09.2012.
  14. #239
    11 Nov 2010
    Default open
    Salut, din cate stiu eu cu openbox-ul nu poti activa nicio cartela, eu am incercat cu jsc sport si cu asta de tvr si... nimic. am reusit sa activez cardul de tvr doar cand am bagat un diablocam in openbox.
    salutare!
  15. #240
    30 Jul 2009
    Pe un alt site am gasit asta:
    "Openbox s9/s10 HD + card TVR HD (viaccess)
    Am reusit din prima sa pornesc un card TVR HD (via) cu un Openbox s10HD.
    Se baga doar serialul cardului in setari (din telecomanda) si porneste instantaneu.
    Menu/Tools/CA Slot Setting/Edit Smartcard Config/Add/Key Type (se alege Viaccess)/ Serial (se baga serialul cardului pe care il detineti , mai putin ultima cifra care este a 11-ea din cele 10 propuse); Pin code-ul ramane cel default 0000/ se confirma prin OK .
    Cardul se baga in slot in cip-ul spre sus. La frecventa am pus 3,57 MHz."
    Insa am incercat si eu dar tot nu merge
