am gasit pe un site un dispozitiv cu care te poti conecta la o retea wireles cu un dreambox 500 :
The Dreambox WiFi Bridge is the perfect accessory for every dreambox owner. Make you dreambox instantly wireless with our unique product. It works also with many other recievers including Azbox, Ipbox, Starview, Humax, Vu+ Duo, etc. It work on any Satellite Receiver that has power of between DC5V-15V Power.
Key Features:
It Supports WEP (64 bit), WEP (128 bit), WPA, WPA2 security.
Easy Setup – 5 Minute Setup
Very small and compact (9cm x 5cm x 1.5cm).
Box Contents:
Dreambox Wifi Bridge
Driver CD
Specification:
1 x 10/100 base Ethernet cable header
1 x USB Port for power in
1 x DC-2.0 female power port for power in
1 x DC-2.0 male power port for power out
Input Voltage: DC5V-15V
Consumed Power: Less than 1.5W
Transmission Distance Indoor: 30m
Uploaded with ImageShack.us
a mai folosit cineva ceva de genu asta?
la prima vedere pare interesant....
